Epson PowerLite Pro G-series Installation Projectors
Epson PowerLite Pro G6900WU Projector
Epson announced seven new PowerLite Pro G-series installation projectors which offer 4,500 to 7,000 lumens of color and white light brightness using a single lamp. Building upon the success of the previous generation of Pro G projectors, this new series offers advanced features such as edge blending, 360-degree installation, six optional lenses, and several connectivity options. The new projectors are designed for medium to large custom installations in corporations, higher education, houses of worship, and rental and staging.
“Venues using installation projectors require bright, flexible and reliable projection solutions, which is what we are delivering with the Pro G-series,” said Sean Gunduz, product manager, High Lumen Projectors, Epson America, Inc. “These installation projectors offer brighter solutions and integrate the most recent technological advancements in the industry, such as edge-blending technology for curved and corner screens and HDBaseT and HD-SDI connectivity options, which will benefit customers across many markets and maximize their ROI.”
Featuring a new design and improvements, including a new chassis and cooling system, the Pro G-series includes several advanced features from the Epson PowerLite Pro Z-series projectors, such as edge blending, 360-degree installation for more flexible setup, and Point and Arc image correction. The projectors are also equipped with features to enrich the video viewing experience, including frame interpolation to deliver sharper and smoother pictures during fast motion videos, and the Faroudja DCDi chipset to enhance video quality with deinterlacing. The Pro G-series also offer high image quality, including life-like color reproduction and C2Fine Technology for darker blacks, and are housed in black or white casing to easily blend into any venue.
Epson G-series connectivity
These new models also offer advanced features and functionality for high-end custom installation scenarios, including:
  • Short throw lens: With zoom and lens shift capabilities
  • Advanced adjustment capabilities: Includes color uniformity and pixel alignment adjustments
  • Lens shift lock: Prevents natural lens shifting due to vibration and/or gravity
  • Advanced Split Screen: Two side-by-side windows and three layout options; video and presentation materials run simultaneously; now supports two digital inputs
  • 3D Stackable: For stacked 3D applications using polarized passive glasses
  • Remote Control: Improved remote includes three user buttons for added customization
Advanced Connectivity Options
The PowerLite Pro G6750WU, Pro G6900WU and Pro G6800 include connectivity options for HDBaseT, a new technology that integrates full HD video and audio, Ethernet, and serial communication, into a single CAT 5/6 cable that can be extended up to 328 feet. HDBaseT eliminates costly and labor intensive cable extension process and signal repeaters for large venue installations. The Pro G6900WU and Pro G6800 integrate connectivity for HD-SDI, which is the standard for transmitting uncompressed broadcast-grade HD video and signals over short distances, predominantly used in professional television studios.
Support
Epson’s PowerLite Pro projectors come with a three-year limited warranty that includes two elite technical support services – Epson PrivateLine phone support where projector owners can directly access an expedited support telephone line by using a phone card that is included with the product, and a Road Service projector replacement program that includes projector exchange in one business day.
Product
Lumens
Resolution
Color
Pricing / Avail.
PowerLite Pro G6050W
5,500
WXGA
White
$3,799 (April 2013)
PowerLite Pro G6150
6,500
XGA
White
$3,599 (April 2013)
PowerLite Pro G6450WU
4,500
WUXGA
White
$3,999 (April 2013)
PowerLite Pro G6550WU
5,200
WUXGA
White
$4,999 (April 2013)
6,000
WUXGA
White
$5,999 (May 2013)
PowerLite Pro G6800
7,000
XGA
Black
$4,799 (July 2013)
6,000
WUXGA
Black
$6,499 (July 2013)
4 Comments
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
Epson's crusade against misleading specifications forces AWOL and JMGO to correct lumens output ratings on some of their projectors.
Ask an Expert
Before you buy a 4K video projector, you need to understand what Pixel Shift is.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 1 of a series covering booths and demos at CEDIA Expo 2024 including Epson, Klipsch, LG, Trinnov, Samsung, and Sony.
Formovie is not alone, Epson catches a number of projector competitors overstating brightness specifications.
Daily Deals
Just in time for backyard movie nights, Epson's EF12 mini projector with built-in streaming and sound by Yamaha is on sale for 30% off.
Compare every 2024 ultra-short throw (UST) 4K projector to decide which one is right for you.
