Epson Home Cinema LS11000 UHD Laser Projector Unveiled
Epson Home Cinema LS11000 4K PRO-UHD Laser Projector
Following the release of its LS12000 flagship Pro Cinema UHD Laser projector earlier in 2022, Epson has announced the release of the Home Cinema LS11000. A lot of the features are the same, including the lens construction, light engine, and image processing, but the price tag is $1,000 less ($4,999.99 vs $3,999.99).
Some of the things included on the LS12000 but not included on the LS11000 are a ceiling-mount, anamorphic add-on lens option, rear cable cover, ISF calibration settings, slightly more light output, and a wider contrast ratio.
Also, Epson ProCinema Line Projectors require professional installation and Home Cinema projectors can be purchased through Epson or local authorized retailers for self-setup. Pro Cinema projectors are offered with a black finish and Home Cinema projectors are offered with a white finish.
That being said, if you are looking for a big-screen home theater experience, the Epson Home  Cinema LS11000 UHD laser projector may be more than enough to fulfill your needs.
Epson Home Cinema LS11000 4K PRO-UHD Laser Projector Front and Back
Inside the Epson Home Cinema LS11000
Here is a rundown of the key features and specifications of the Epson LS11000.
  • Tip: Just as the LS12000, the LS11000 does not include any “smart features” such as built-in WiFi, streaming platform and apps, Airplay 2, or Bluetooth.
Projector Placement Options: The LS11000 can be placed in several locations in relation to the screen including the front, front ceiling, rear, and rear ceiling.
Resolution: 4 UHD via Pro UHD Advanced Pixel Shifting using “precision shift glass plate technology”. This means that the projector incorporates three 1080p resolution LCD chips (red, green, and blue). Epson’s glass plate system is then used to shift the pixels rapidly so that visually a 4K UHD image is displayed.
Light Source: The LS11000 has a Laser/Phosphor light source. This means that a blue laser array is used in combination with a fixed yellow phosphor, dichroic mirrors, and color filters to create the needed red, green, and blue primary colors, which are then blended to create full-color images.
Epson Laser Phosphor Light Engine
Laser Light Source Life: 20,000 use hours
White Brightness: 2,500 ANSI Lumens
Color Brightness: 2,500 CLO Lumens
Video Processing: The LS11000 incorporates the Epson ZX Processor. This provides optimized color, contrast, HDR, frame interpolation, and resolution enhancement in real-time to present the source material in the best possible manner.
High Dynamic Range (HDR) Support: HDR10, HDR10+, HLG.  Real-time HDR curve adjustment allows for 16 steps of control to fine-tune the HDR performance regardless of the content.
Tip: What you need to know about HDR in video projectors.
Preset Color/Picture Modes: Dynamic, Vivid, Bright Cinema, Cinema, Natural
Refresh Rate: 120 Hz Refresh Rate (including 4K/120Hz). Frame interpolation is performed for sources below 120Hz.
Lens: The Epson VRX Cinema Lens has a proprietary zero light leakage 15-element precision glass structure for image clarity and edge-to-edge focus uniformity.
Viewable Image Size Range: Depending on the throw distance the LS 11000 can project image sizes from 50 to 300 inches.
Throw Distance: 4.9 feet to 62.4 feet. The throw distance is the distance range between the projector and the image on the screen (i.e., the distance that the image is “thrown”).
Keystone (Digital): Horizontal and Vertical +/- 30 degrees.
Lens Shift: The LS11000 has a 3-Axis motorized lens shift. This provides Horizontal +/- 47%, Vertical +/1 96% lens positioning without moving the projector or causing image shape distortion from excessive Keystone Correction. This is practical if the projector can’t be mounted directly in front of the screen.
Zoom/Focus: Motorized Zoom (2.1x)
Fan Noise:  22 – 30 dB. This is fairly quiet for a large video projector.
Epson Remote Control for LS12000 and LS11000 Projectors
Control: The LS11000 comes with a wireless remote (the same one that is also provided for the LS12000) and control buttons on the rear panel of the projector.
Projector Size (WxDxH): 20.5 x 17.6 x 7.6-inches
Projector Weight: 28 pounds
Connections
Epson Home Cinema LS11000 4K PRO-UHD Laser Projector Rear Connections
Here are the connections provided with the LS11000.
HDMI (ver 2.1): 2, one of which supports eARC/ARC. Full 48 Gbps bandwidth support is provided. 4K/120 Hz is also supported, along with input lag times below 20 ms. This projector is a great match for gamers.
Tip: The LS11000 doesn’t have a built-in speaker system, but will pass audio from HDMI-connected devices via HDMI-ARC/eARC to a compatible soundbar or another type of external audio system.
USB Type-A: (1) This can be used to power an optical HDMI cable (up to 300 mA) if needed and if the cable provides this option.
USB Type-A: (1) for 5 V, 2.0 A for power (such as charging compatible devices), and firmware updating.
Mini USB: (1) (for service only)
Trigger Out: (1) This provides On, Off control (12 V DC, 200 mA maximum)
Ethernet/LAN RJ45: 1
RS-232C: 1 for wired control.
Home Cinema LS11000 4K PRO-UHD Laser Projector Top
What Comes In The Box
Here is what you get when you unpack the LS11000.
  • LS11000 Projector
  • Detachable Power Cord
  • Remote Control with (2) AA batteries
  • Quick Setup Guide
Epson Home Cinema LS11000 Full Specifications (pdf)
Availability and Pricing
The Epson Home Cinema LS11000 4K PRO-UHD Laser Projector is available for $3,999 at ProjectorScreen, Best Buy/Magnolia and other authorized Epson dealers.
For more information: epson.com
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Projectors & Screens
Sony's VPL-VW6100ES BRAVIA Projector 8 offers stunning big screen home theater performance at a hefty price.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Epson brings a new focus to lifestyle projectors with its new LifeStudio line featuring five models (including a new UST) with prices ranging from...
LG CineBeam S is a compact 4K ultra short throw projector with RGB laser, smart streaming and Dolby Atmos for tight spaces.
With 5,000 ISO lumens, full DCI-P3 color, and support for screens up to 250 inches, the TITAN is built to handle almost any venue.
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
Setting up a backyard movie theater in 2025 is easier than ever thanks to new 4K projectors, portable screens, and wireless streaming. Here's what...
With true 4K resolution, a bright colorful image and a motorized lens for maximum flexibility, Epson's new Pro Cinema LS9000 offers a lot of...
