Energy Take Classic I/O 4 and 5 Outdoor Speakers
Energy Take Classic I/O 4 and I/O 5 Outdoor Speakers
Energy today announced their first-ever outdoor speakers with the debut of two budget-priced models: Take Classic I/O 4 (0.5-inch tweeter and a 4-inch woofer) and Take Classic I/0 5 (1-inch tweeter and 5.25-inch woofer). As weatherproof speakers, both feature UV-treated cabinets, rust-resistant grills, mounting brackets and five-way, gold-plated binding posts to withstand the elements for extended use.
The Take Classic I/O Series speakers are designed for maximum performance for backyard decks, sunrooms or other weather-exposed areas not suitable for regular home speakers. The white cabinets can also be painted to match any decor.
Specifications
Model Energy Take Classic I/O 4 Energy Take Classic I/O 5
MSRP $99.99 $149.99
System Type 2-way sealed outdoor weatherproof loudspeaker
Impedance (Ohm) 8 ohms nominal; 4 ohms minimum
Sensitivity 84 dB 86 dB
Inputs Dual 5-way gold-plated binding posts
Product Finish White UV Treated Polypropylene
Frequency Response (Hz, +/-3dB)  100 Hz – 22 kHz +/- 3 dB 80 Hz – 22 kHz +/- 3 dB
Included Accessories
Rust resistant grille, Rust Resistant Mounting Bracket, Rear Mounting Inserts
Tweeter One 1/2″ (12.7 mm) tweeter One 1″ (25.4mm) tweeter
Overall Dimensions (mm/in, HxWxD) 8.75″ (22.2 cm) H x 5.75″ (14.6 cm) W x 6.4″ (16.2 cm) D 10″ (25.4 cm) H x 6.5″ (16.5 cm) W x 7.3″ (18.5 cm) D
Woofer Size (inches) One 4″ (101.6mm) woofer
with polypropylene cone and rubber surround
One 5.25″ (133.3mm) woofer
Crossover Point 4.5kHz
Weight 3.5 lbs (1.6 kg) 4.5 lbs (2.04 kg)
Recommended Power up to 35 watts RMS up to 50 watts RMS
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
