Empirical Audio Pace-Car 2 Reclocker
The Pace-Car 2 is a high-performance reclocker that can be used with virtually any digital source device, including CD Transports, iPod, Apple TV, Sonos, Squeezebox, Duet, Olive, Transporter, PCI cards like Lynx, direct from Mac-Mini, Macbook and many others. It reduces the jitter, or timing inaccuracies, in the datastream.
It is this jitter that makes digital audio sound “veiled” or fatigueing. Once it is eliminated, the result is like cleaning the film from a window, improving clarity, dynamics and 3-D as well as bass tightness.
The Pace-Car was primarily designed to address the deficiencies in the various WiFi devices on the market, but has much wider application, even extending to multi-channel synchronous streams to support computer-generated speaker crossover software.
The Pace-Car is legendary for reducing jitter to extremely low levels in digital music streams. Two audio magazine editors use the Pace-Car or Pace-Car 2 for their digital audio reference: Positive-Feedback and Stereo Times. Positive-Feedback did a comparison of several USB converters and the Pace-Car:
http://www.positive-feedback.com/Issue39/ramblings_computer.htm
The Pace-Car 2 improves on the original Pace-Car with new discrete and separate power regulation and improved grounding to further isolate the inputs from the outputs. A small switching supply has been replaced with a linear for lower noise.
The Pace-Car 2 is a buffer-memory device that temporarily stores the digital data stream in order to reclock it out using a local clock with very low jitter. The jitter on the inputs is not particularly important. The data is not modified in any way.
Pace-Car 2
There are three modes in which the Pace-Car can be used:
1) word-clock synchronous
2) master-clock synchronous
3) asynchronous tuned
Depending on the source device, one of these modes will be used.
The Pace-Car 2 supports 44.1kHz and 96kHz sample rates as standard (provided the clocks are present), with 88.2, 176.4 and 192 as optional.
Standard Inputs:
Toslink
S/PDIF coax
Standard outputs:
S/PDIF coax
Empirical Audio I2S
Word-clocks on one output
Master-clocks on two outputs
Included
Pace-Car 2
AC power supply
Toslink cable if applicable
word-clock cable if applicable
master-clock cable if applicable
Options
First Superclock4
Second Superclock4
First tuned Superclock4
Second tuned Superclock4
AES/EBU output jack in place of S/PDIF coax
NextGen output jack
Canare BNC output jack
Pricing
Pace-Car 2 $1200.00
Pace-Car 2 with one Superclock4 $1500.00
http://www.empiricalaudio.com
Nothing KEF Headphone 1 Lifestyle
Nothing challenges the Apple AirPod Max with the new Headphone 1 with Sound by KEF.
Cyrus Audio 40 PPA Phono Preamp Front Cyrus Audio 40 PPA Phono Preamp Front
At $2,899, Cyrus Audio makes a bold claim about its 40 PPA which supports MC and MM cartridges with balanced XLR outputs and upgraded...
iFi Go pod MAX wireless IEM Adapters iFi Go pod MAX wireless IEM Adapters
The iFi Go Pod Max turns wired IEMs wireless with Bluetooth 5.4, balanced amp, and high-res audio—elevating sound while exposing your IEMs’ true colors.
Dangbei MP1 Max 4K Projector Lifestyle Dangbei MP1 Max 4K Projector Lifestyle
At under $2,000, the Dangbei MP1 Max is a compact 4K lifestyle projector with Google TV, AI setup, and hybrid laser-LED tech for screens...
Yamaha YH-L500A Wireless Headphones Lifestyle Yamaha YH-L500A Wireless Headphones Lifestyle
With proprietary Sound Field technology, the Yamaha YH-L500A wireless headphones provide personalized cinematic audio for $229.
V-MODA M10 and M100 Pro DJ Headphones V-MODA M10 and M100 Pro DJ Headphones
Not all headphones are designed for all listening needs. The V-MODA M-100 PRO and M-10 are affordable headphones that provide the quality and durability...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
