Emotn’s N1 Portable LED Projector Is Ideal For The Backyard
With an official license from Netflix, the $399 Emotn N1 might be a great home or outdoor 1080p projector for watching movies.
Emotn N1 1080p Netflix Outdoor Projector
Portable and outdoor projectors became very popular during the pandemic as families moved the movie theater outdoors. As we move closer to the summer, manufacturers have begun to announce the next generation of affordable models including the new Emotn N1, which is its first Netflix-licensed projector.
Tip: Emotn is a subsidiary of Dangbei, a China-based company specializing in hardware and software solutions for large-screen display products.
The Basics
Emotn N1 1080p Netflix Projector Black
The N1 can be used at home or on the go. With 1080p native resolution and built-in smart TV streaming features, you don’t need to plug anything else to start watching, just connect it to the internet and watch content from several streaming services including Netflix.
Tip: Netflix and other major streaming services require separate subscription fees.
In addition to Netflix, the N1 also includes direct access to Amazon Prime Video and YouTube via hot keys on the remote. Other pre-loaded apps include YouTube Kids, Toon Goggles, and TIKILIVE. There is also an APP store and Open Browser that provides access to more streaming content. In addition, you can also view content via screen mirroring, screencasting, HDMI, and USB. You can also use the N1 as a Bluetooth speaker.
Tip: The reason that the Netflix license is important is that although there are a growing number of projectors that incorporate smart features, not all of them can officially access Netflix. The XGIMI Aura, LG PF610P, and LG PF510QL  are examples of projectors that can’t guarantee Netflix access.
Emotn N1 Netflix - Stranger Things On-screen Menu
LED Light Source
To view images, no matter what the source, the N1 incorporates a 30,000-hour rated LED light source.
Three advantages of an LED light source over a lamp in a projector are:
  • LEDs are smaller than lamps, which is more practical than smaller projectors.
  • LEDs don’t have to be replaced periodically. This is a more cost-effective option than owning a projector that uses a lamp.
  • LED lights run cooler than traditional lamps so the need for a noisy fan is lessened.
Tip: In addition to the LED light source which facilitates color, the grayscale image information is provided by LCD chip technology with 1080p resolution support.
Emotn N1 1080p Netflix Projector White
Features and Specifications
In addition to the technologies used to project the image onto a screen or wall, here are the N1’s additional features and specifications.
  • Display Technology: LCD
  • Light Source: LED
  • Light Source Lifespan: 30,000 Hours
  • Light Output: 500 ANSI Lumens
  • Resolution: 1080p (1920×1080 FHD)
  • HDR Support: HDR 10 – It is important to note that with a modest 500 Lumen light output, the HDR effect will be minimal.
  • Throw Ratio: 1.25:1
  • Projector Distance: 1.67m  (5ft 6in) to 3.15m (10 ft 4in)
  • Image Size  Range: 60 to 120-inches
  • Weight: 4.24 lbs
  • Dimensions: 7.17 x 4.92 x 7.56 inches
  • Official Content Licenses: Netflix, YouTube, Prime Video, etc
Emotn N1 1080p Netflix Projector Screen Size
Emotn N1 1080p Netflix Projector Keystone
  • Audio:  2 x 5W built-in speaker system
  • Surround Sound Formats: Dolby Audio, Dolby Digital, Dolby Digital Plus (mix down within a 2-channel platform)
Emotn N1 1080p Netflix Projector Audio
Core System
  • RAM: 1GB DDR3
  • Storage: 8GB eMMC5.1
  • Operating System: Linux
Wired Connectivity
  • USB 2.0 x 1
  • HDMI IN x 1
  • DC-IN x 1
  • LAN x 1
  • Audio Line-Out x 1
Emotn N1 1080p Netflix Projector Connections
Wireless Connectivity
Operational Parameters
  • Operating Temperature: 5℃~35℃
  • Power Consumption: 110W
  • Noise: <26dB @25℃
Included Accessories
  • Power Plug 120W (19V/6.32A)
  • AC cord x1
  • Bluetooth Remote Control x1
  • User Manual x1
Price and Availability
The Emotn N1 is now available for $399.99 on Amazon. To celebrate the launch, Emotn is offering a $50 discount coupon.
Tip: The N1 will also be available at Amazon CA on Amazon UK in the coming months.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
At $499, the TCL A1 is a 1080p portable lifestyle projector that lets you bring big screen entertainment wherever you go.
At $1,899, the Dangbei DBOX02 is a featured packed portable 4K lifestyle projector that includes Netflix built-in for simplified streaming.
Daily Deals
XGIMI's portable projectors and lifestyle projectors are on sale this week with prices starting at $249.99.
If you are looking for a traditional style video projector, but updated with the latest tech, such as 4K resolution, laser light source, and...
Podcasts
Find out who won Best UST and lifestyle projectors of 2023, get the backstory on the competition, and how to interpret the scoring.
Debuting at CES 2024, LG's CineBeam Q delivers indoor or outdoor big screen entertainment on screens up to 120-inches in diagonal.
Now on sale for $359, Ultimea's Poseidon E40 smart projector brings Netflix movie watching to the backyard. Screen not included.
