5 New Emotiva BasX Amplifiers for Every Budget
Emotiva improves their affordable BasX series of power amplifiers priced from $449 to $699.
2021 Emotiva BasX 2nd Generation Power Amplifiers
Emotiva have announced a complete refresh of its best-selling BasX amplifiers with new 5 models for both 2-channel and home theater systems. The new 2nd generation Emotiva BasX amplifiers range from $449 to $699, offering two-channel stereo to seven-channels for home theater systems.
Emotiva’s 2021 BasX amps feature a beefed up linear power supply claiming even more power and better control with demanding loads. They use the same audiophile quality Class A/B output section, with a newly optimized input stage said to improve fine detail and transparency. Input sensing is also new, enabling auto turn-on. Visually, the front panels have been updated with a sleek more modern look.
BasX A2 ($449)
The BasX A2 is a two channel power amplifier that delivers 160 watts / channel into 8 Ohms and 250 watts / channel into 4 Ohms, with a rated THD+N of < 0.02%, and an A-weighted S/N ratio of 112 dB. The BasX A2, which replaces the A300, features a heavy-duty linear power supply, high-quality Class A/B amplification, transparent fault protection, and a trigger input and output.
It’s designed to serve as the foundation of a great-sounding stereo system, to power the front main speakers on a surround sound system, or to upgrade the front left and right channels of your favorite surround sound receiver.
The BasX A2 also offers a convenient feature that allows the amp to switch on when an audio signal is detected at its input – which is especially useful if your preamp or receiver doesn’t offer a trigger output.
Emotiva A2 Amplifier Rear
High quality industry standard unbalanced RCA inputs enable the BasX A2 to be used with almost any preamp or processor and audiophile grade five way speaker terminals accept banana plugs, spade lugs, or bare wire. These features combine to enable the BasX A2 to deliver true audiophile performance and sound quality at an amazingly affordable price.
BasX A3 ($499)
The BasX A3 is a three channel power amplifier that delivers 140 watts / channel into 8 Ohms and 200 watts / channel into 4 Ohms, all channels driven, with a rated THD+N of < 0.02%, and an A-weighted S/N ratio of 112 dB.
The BasX A3 has been designed to power a 3.1 channel system, to upgrade the front three channels of a surround sound receiver, or for anywhere where three channels of great sounding clean power are needed.
Emotiva A3 Amplifier Rear
The BasX A3 features a heavy-duty linear power supply, high-quality Class A/B amplification, transparent fault protection, and a trigger input and output. High quality industry standard unbalanced RCA inputs enable the BasX A3 to be used with almost any preamp or processor and audiophile grade five way speaker terminals accept banana plugs, spade lugs, or bare wire.
These features combine to enable the BasX A3 to deliver true audiophile performance and sound quality at an amazingly affordable price.
The BasX A3 is the ideal choice to power a 3.1 channel system, to upgrade the front three channels of a surround sound receiver, or for anywhere where three channels of great sounding clean power are needed
BasX A4 ($499)
The BasX A4 is a four channel power amplifier that delivers 100 watts / channel into 8 Ohms and 130 watts / channel into 4 Ohms, all channels driven, with a rated THD+N of < 0.02%, and an A-weighted S/N ratio of 115 dB.
The BasX A4 is the best option to power your surrounds if you’re building a new system and you’ve already committed to a more powerful amp, like our XPA-DR3, to power your front channels. It’s also a perfect solution if you need a high-quality amp to power your new height channels or two pairs of zone speakers.
Emotiva A4 Amplifier Rear
The BasX A4 features a heavy-duty linear power supply, high-quality Class A/B amplification, transparent fault protection, and a trigger input and output. High quality industry standard unbalanced RCA inputs enable the BasX A4 to be used with almost any preamp or processor and audiophile grade five way speaker terminals accept banana plugs, spade lugs, or bare wire.
These features combine to enable the BasX A4 to deliver true audiophile performance and sound quality at an amazingly affordable price.
The Emotiva BasX A4 is the perfect solution if you need a high quality amp to power your Dolby Atmos and DTS:X height channels. It is also an excellent choice to power your surrounds if you’re building a new system and you’ve already committed to a more powerful amp, like our XPA-3, to power your front channels or to power two pairs of zone speakers.
BasX A5 ($599)
The BasX A5 is a five channel power amplifier that delivers 95 watts / channel into 8 Ohms and 130 watts / channel into 4 Ohms, all channels driven, with a rated THD+N of < 0.02%, and an A-weighted S/N ratio of 116 dB. The BasX A5 features a heavy-duty linear power supply, high-quality Class A/B amplification, transparent fault protection, and a trigger input and output. High quality industry standard unbalanced RCA inputs enable the BasX A5 to be used with almost any preamp or processor and audiophile grade five way speaker terminals accept banana plugs, spade lugs, or bare wire. These features combine to enable the BasX A5 to deliver true audiophile performance and sound quality at an amazingly affordable price.
Emotiva A5 Amplifier Rear
The BasX A5 is a great choice if you’re looking for a high quality five channel amplifier to go with a processor in a new 5.1 channel surround sound system, or if you’re looking for an easy way to upgrade the amps in your existing surround sound receiver.
BasX A7 ($699)
The BasX A7 is a seven channel power amplifier that delivers 90 watts / channel into 8 Ohms and 125 watts / channel into 4 Ohms, all channels driven, with a rated THD+N of < 0.02%, and an A-weighted S/N ratio of 115 dB. The BasX A7 features a heavy-duty linear power supply, high-quality Class A/B amplification, transparent fault protection, and a trigger input and output. High quality industry standard unbalanced RCA inputs enable the BasX A7 to be used with almost any preamp or processor and audiophile grade five way speaker terminals accept banana plugs, spade lugs, or bare wire. These features combine to enable the BasX A7 to deliver true audiophile performance and sound quality at an amazingly affordable price.
Emotiva A7 Amplifier Rear
The BasX A7 is a great choice if you’re looking for a high quality seven channel amplifier to go with a processor in a new 7.1 channel surround sound system, or if you’re looking for an easy way to upgrade the amps in your existing surround sound receiver.
Comparison
All Channels DrivenTwo Channels Driven
Model8 Ohm4 Ohm8 Ohm4 Ohm
A2 Stereo Amplifier160 / channel250 / channel160 / channel250 / channel
A3 Three-Channel Amplifier140 / channel200 / channel150 / channel250 / channel
A4 Four-Channel Amplifier100 / channel130 / channel100 / channel175 / channel
A5 Five-Channel Amplifier95 / channel130 / channel120 / channel175 / channel
A7 Seven-Channel Amplifier90 / channel125 / channel120 / channel175 / channel
Learn more: emotiva.com
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Rega’s new Mercury and Solis flagship amps showcase peak engineering, but with a $50K full-system buy-in and no network amplifier in sight, the strategy...
The Mola Mola Ossetra is a $25,100 Class D mono amplifier delivering 350W into 8 ohms with ultra-low distortion, challenging Devialet in the high-end...
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
Building on the previously released DLC series controllers, the PLC Series offers more power and flexibility for larger room home theater setups and pro...
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Orchard Audio’s Starkrimson 25 Mono Premium delivers clean, efficient Class D power with precision and upgrade options for existing owners—no gimmicks, just performance.
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
The Mark Levinson 600 Series redefines American high-end audio with flagship power amplifiers and preamp engineered for purity.
