Emotiva’s Airmotiv X Loudspeaker Lineup Has Been Completely Revamped
Priced from $399 to $1,999/pair, eight new Emotiva Airmotiv X loudspeakers feature a thinner new design for stereo or home theater setups.
Emotiva AirMotiv X Loudspeakers (2024 models)
Emotiva and SVS have carved out rather successful niches for themselves in the world of high-end loudspeakers by focusing on delivering performance at prices that most consumers can afford. That’s not to say that everything they offer is “affordable” but their key products which are offered direct to consumers are great values for the money.
Emotiva’s Airmotiv X loudspeaker lineup has been refreshed for 2024 and there are some notable changes which include a PVC laminated HDF enclosure, and new HDF 25mm baffle, which is extensively damped.
Airmotiv X Speakers
Emotiva Airmotiv X Loudspeakers Grille with Logo lower portion at base
The Airmotiv X loudspeakers feature a new design approach. The cabinets on the towers are slender and graceful. The front panels feature a bevelled edge that is designed to reduce diffraction.
The speakers also feature a satin lacquer finish on the front panels and smooth trim rings that conceal the driver mounting hardware helping with diffraction while providing a more sophisticated and finished appearance.
Features
The driver layout has also been optimized for superior sound quality, complemented by non-parallel midrange walls to reduce internal reflections.
The Airmotiv X Loudspeakers feature a rotatable folded ribbon tweeter with an improved waveguide and Neo Magnet System allowing users to configure the speaker to fit their specific system layout.
Emotiva folded ribbon tweeter
Every speaker includes an internal-mounted crossover and efficient wire routing, ensuring efficient performance and serviceability.
Midrange drivers incorporate woven cone diaphragms, aluminum voice coils, milled aluminum phase plugs, copper shorting rings, and NBR (Nitrile-Butadiene Rubber) surrounds.
Woofers incorporate the same structure as the midrange drivers with the addition of a long throw motor and progressive spider.
The over-one-inch thick multi-layer front panel of each enclosure ensures the proper rigidity for producing sound.
The tower speakers are reinforced with internal window bracing and lined with thick Dacron for better sound dampening.
Emotiva Airmotiv Xt2 Bi-wire/Bi-amp rear speaker terminals
Emotiva Airmotiv Xt2 Bi-wire/Bi-amp rear speaker terminals.
All of the Airmotiv X Series speakers (except the Xa2 surround speakers) have bi-amping terminals that enable you to access the woofer and midrange/tweeter sections of the speaker separately for bi-amping or bi-wiring.
Magnetically attachable/detachable black cloth over rigid frame grills are provided with each speaker.
Airmotiv X Models
Emotiva Airmotiv X Loudspeaker Diagram (All 2024 models)
The Emotiva Airmotiv X speakers line consists of eight models:
  • Airmotiv Xa2 Height / Surround / Ceiling Speakers (Pair) $399.00
  • Airmotiv Xb2 Bookshelf Loudspeakers (Pair): $499.00
  • Airmotiv Xc1 Center Channel Loudspeaker (Each): $399.00
  • Airmotiv Xc2 Center Channel Loudspeaker (Each): $599.00
  • Airmotiv Xc3 Center Channel Loudspeaker (Each): $899.00
  • Airmotiv Xt1 Floorstanding Tower Loudspeakers (Pair): $999.00
  • Airmotiv Xt2 Floorstanding Tower Loudspeakers (Pair): $1,299.00
  • Airmotiv Xt3 Floorstanding Tower Loudspeakers (Pair): $1,999.00
Tip: Early Adopter Special! 15% off two or more Airmotiv Loudspeakers.
Airmotiv X Surround and Bookshelf Speakers
Emotiva Airmotiv Xa2, xb2 Surround and Bookshelf Speakers
Emotiva Airmotiv Xa2 (left) Surround Speaker and Xb2 (right) Bookshelf Speaker (not to exact scale).
Xa2Xb2
MSRP$399/pair$499/pair
ConfigurationTwo-wayTwo-way
Cabinet TuningSealedRear ported
Tweeter1 x 25mm x 32mm 1 x 25mm x 32mm
Mid-Bass1 x 5.25” 1 x. 6”
Efficiency  (2.83V/1m)86 dB86 dB
Power Handling80W continuous
150W peak
125W continuous
200W peak
Recommended Amp Power40W or more50W or more
Impedance4-ohms (8-ohm compatible)4-ohms (8-ohm compatible)
Frequency Response (+/- 3 dB)75 Hz – 27 kHz55 Hz – 27 kHz
Crossover Frequency 3.2 kHz2.6 kHz
Speaker ConnectionsHeavy-duty compression styleDual 5-way speaker terminals for bi-amping or bi-wiring
Mounting Easy-Secure mounting with solid steel bracketShelf or stand-mounted
GrillBlack cloth over a rigid frame.Black cloth over a rigid frame.
Dimensions
HxWxD
12.5” x 7.15” x 8.5”
(Add 0.25” inch for the grill and 0.25” for the mounting bracket)
19″ x 17″ x 13″ (boxed pair)
12.8” x 8.5” x 11.5”
(Add 0.25” for grill)
24″ x 18″ x 16″ (boxed pair)
Weight22 lbs18 lbs
Airmotiv X Center Channel Speakers
Emotiva Airmotiv Xc1, Xc2, Xc3 Center Channel Speakers
Top to bottom: Emotiva Airmotiv Xc1, Xc2, Xc3 Center Channel Speakers (not to exact scale).
Xc1Xc2Xc3
MSRP$399$599$899
ConfigurationThree-wayThree-wayThree-way
Cabinet TuningRear portedDual rear portsDual rear ports
Tweeter1 x  25mm x 32mm 1 x  25mm x 32mm 1 x 28mm x 32mm H.).
Midrange1 x 4.5” 1 x 5.5” 2 x  5.25”
Woofer2 x 5.25” 2 x 6”4 x. 6”
Efficiency  (2.83V/1m)88 dB89 dB90 dB
Power Handling120W continuous
250W peak
150W continuous
300W peak
250W continuous
500W peak
Recommended Amp Power60W or more100W or more100W or more
Impedance4 ohms (compatible with 8 ohms)4 ohms (compatible with 8 ohms)4 ohms (compatible with 8 ohms)
Frequency Response (+/- 3 dB)50 Hz – 27 kHz45 Hz – 27 kHz40 Hz – 27 kHz
Crossover Frequency 620 Hz, 3.1 kHz600 Hz, 3.1 kHz370 Hz, 2.8 kHz
Speaker ConnectionsDual 5-way speaker terminals for bi-amping or bi-wiringDual 5-way speaker terminals for bi-amping or bi-wiringDual 5-way speaker terminals for bi-amping or bi-wiring
Mounting Shelf or stand-mountedShelf or stand-mountedShelf or stand-mounted
GrillBlack cloth over a rigid frameBlack cloth over a rigid frameBlack cloth over a rigid frame
Dimensions
HxWxD
7.5” x 26” x 9.5” deep
31″ x 14″ x 13″ (boxed)
8.5” x 31.5” x 10.25”
37″ x 15″ x 14″ (boxed)
9-1/4″ x 51-1/4″ x 12″
(Add 0.25” inch for grill)
57″ x 17″ x 15″ (boxed)
Weight25 lbs37 lbs64 lbs
Airmotiv X Tower Speakers
Emotiva Airmotiv Xt1, Xt2, Xt3 Floorstanding Loudspeakers
Left to right: Emotiva Airmotiv Xt1, Xt2, Xt3 Floorstanding Loudspeakers (estimated scale).
Xt1Xt2Xt3
MSRP$999/pair$1,299/pair$1,999/pair
ConfigurationThree-way Three-way Three-way
Cabinet TuningRear portedRear portedDual rear ports
Tweeter1 x 25mm x 32mm 1 x 25mm x 32mm 1 x  25mm x 32mm
Midrange1 x 4.5” 1 x 5.25” 2 x 5.25”
Woofer3  x  5.25” 3  x  6” 3  x  8”
Efficiency  (2.83V/1m)89 dB90 dB91 dB
Power Handling200W continuous
300W peak
250W continuous
500W peak
300W continuous
600W peak
Recommended Amp Power60W or greater100W or greater100W or greater
Frequency Response (+/- 3 dB)45 Hz – 27 kHz40 Hz – 27 kHz 30 Hz – 27 kHz
Crossover Frequency 410 Hz, 3.1 kHz430 Hz, 3.1 kHz300 Hz, 3.1 kHz
Mounting Permanently attached outrigger feet with neoprene non-mar pads.
Detachable, adjustable spikes included.
Dimensions
HxWxD
41.75” x 7” x 10”
(Add 0.75” height and 1.75” width for feet; add 0.25” for grill)
47″ x 16″ x 13″ (boxed)
44.75” x 8.5” x 12.25”
50″ x 17″ x 14″ (boxed)
48.7” x 10.75” x 16.75”
54″ x 22″ x 16″ (boxed)
Weight35 lbs49 lbs91 lbs
Where to buy: emotiva.com
More from Emotiva
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PD10 DAP might replace your streamer.
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
