Elipson, the so-called “oldest French speaker brand” since 1938, remains a well-kept secret in the US. In Europe, they’re better known for their flashy, futuristic spherical Planet speakers—because why settle for boring boxes when you can have orbs? But don’t be fooled; Elipson also crafts affordable, more traditional loudspeakers in their Heritage, Legacy, and original Prestige Facet lines. Stylish enough to impress the French, practical enough to actually fill your room with sound.
The Prestige Facet speaker line debuted in 2016 as Elipson’s most affordable option—until the Horus line showed up in 2023 to steal that crown.
Now, Elipson has decided it’s time for an update. Enter the Prestige Facet II line, boasting 10 affordable models designed to cover every possible setup—from home theater to pure two-channel listening. According to Elipson, these new speakers are “designed for the most demanding audiophiles,” which is a bold claim coming from a brand known for blending style with practicality.
Ten new speakers at once might feel like overkill, but here’s how the Prestige Facet II lineup breaks down:
Elipson Prestige Facet II
Here’s the Prestige Facet II lineup in all its glory:
- Three Floorstanding Models: 34F, 24F, 14F
- Two Bookshelf Models: 8B, 6B
- Two Center Channel Models: 14C, 11C
- One Surround Model: 7SR
- One Height Channel Model: 6ATM
- One LCR (Left Center Right) Model: 14LCR
Now, let’s break down the improvements Elipson has packed into the Prestige Facet II speakers compared to the original Facet line.
Cabinets: Tougher, Stiffer, and Less Likely to Rattle
Elipson has beefed up the cabinet construction in the Facet II speakers with added internal reinforcement. This extra rigidity cuts down on unwanted vibrations, tightens up the bass, and delivers a more consistent, linear sound—especially when you crank the volume and expect the speakers to behave like professionals, not rattling tin cans.
Crossover Upgrade: Cleaner Signal Path for Smoother Sound
The Facet II speakers feature a redesigned crossover using higher-quality components like polypropylene film capacitors, metal-coated resistors, and low DCR inductors. This upgrade improves channel separation, delivers a smoother frequency response, and creates a more coherent and natural soundstage.
Internal Wiring: Better Conductivity for Clearer Sound
Each Facet II speaker is wired internally with 2.25 mm² OFC (Oxygen Free Copper) cables. This upgrade ensures optimal conductivity and minimizes signal loss between the crossover components and drivers. The improved wiring helps enhance overall fidelity and transparency, resulting in a cleaner, more detailed listening experience.
New Feet: Stylish Support That Cuts Vibration
The Facet II floorstanding models come with redesigned decoupling feet featuring a modern look that’s both visually lighter and mechanically stronger. These new feet improve isolation between the cabinet and the floor, reducing vibration transfer and helping to optimize low-frequency performance.
Finish Upgrade: Less Flash, More Class (à la Française)
Elipson has ditched the glossy front panels in favor of a refined satin finish on the Prestige Facet II speakers. The result? A more modern, understated look that won’t scream for attention in your living room. The smoother, streak-free surface brings a touch of French restraint—finally. Available in Matte Black, Matte White, and Matte Walnut for those who prefer their speakers to look as polished as they sound.
Elipson Prestige Facet II Floorstanding and Bookshelf Speakers
Prestige Facet II 34F | Prestige Facet II 24F | Prestige Facet II 14F | Prestige Facet II 8B | Prestige Facet II 6B | |
Size | Floorstanding | Floorstanding | Floorstanding | Bookshelf | Bookshelf |
Type | 3-way | 3½-way | 2½-way | 2-way | 2-way |
Design | Bass-reflex | Bass-reflex | Bass-reflex | Bass-reflex | Bass-reflex |
Price | €3,299.00 | €2,399.00 | €1,299.00 | €799.00 | €549.00 |
RMS Power Handling | 300 W | 250 W | 150 W | 85 W | 70 W |
Recommended Amplification | 70 – 350 W | 50 – 350 W | 40 – 200 W | 30 – 120 W | 20 – 100 W |
Tweeter | 1 x 25 mm | 1 x 25 mm | 1 x 25 mm | 1 x 25 mm | 1 x 25 mm |
Midrange | 2 x 170 mm | 1 x 170 mm | 1 x 170 mm mid-bass driver | 1 x 170 mm mid-bass driver | 1 x 140 mm mid-bass driver |
Woofer | 2 x 250 mm | 2 x 250 mm | 1 x 170 mm | Not Applicable | Not applicable |
Frequency Response (±3 dB) | 25 Hz – 25 kHz | 28 Hz – 25 kHz | 38 Hz – 25 kHz | 47 Hz – 25 kHz | 57 Hz – 25 kHz |
Sensitivity (1 watt @ 1 Meter) | 94 dB | 93 dB | 92 dB | 90 dB | 90 dB |
Nominal Impedance | 6 Ω | 6 Ω | 6 Ω | 6 Ω | 6 Ω |
Minimum Impedance | 5.3 Ω @ 88 Hz | 3.8 Ω @ 127 Hz | 4.5 Ω @ 220 Hz | 5.6 Ω @ 180 Hz | 5 Ω @ 220 Hz |
Crossover Points | 230 Hz, 4,500 Hz | 350 Hz, 600 Hz, 3,800 Hz | 600 Hz, 2,500 Hz | 2,700 Hz | 2,800 Hz |
Bass-Reflex Tuning Frequency | 26 Hz | 30 Hz | 35 Hz | 51 Hz | 60 Hz |
Connections | Silver-plated binding posts (bi-wiring / bi-amping compatible) | Silver-plated binding posts (bi-wiring / bi-amping compatible) | Silver-plated binding posts (bi-wiring / bi-amping compatible) | Silver-plated binding posts (bi-wiring / bi-amping compatible) | Silver-plated binding posts (bi-wiring / bi-amping compatible) |
Dimensions (WxHxD with feet) | 295 x 1230 x 376 mm | 320 × 1100 × 424 mm | 207 x 1030 x 303 mm | 207 x340 x 323 mm | 176 x 298 x 223 mm |
Weight (each) | 44 kg | 29 kg | 20.2 kg | 9 kg | 6.3 kg |
Elipson Prestige Facet II Center, Surround, Height, LCR Speakers
Elipson Model | Prestige Facet II 14C | Prestige Facet II 11C | Prestige Facet II 7SR | Prestige Facet II 6ATM | Prestige Facet II 14LCR |
Use case | Center | Center | Surround | Height | LCR |
Speaker Type | 2-way Laminar bass-reflex | 2-way Sealed cabinet | 2-way Bass-reflex | 2-way Sealed cabinet | 2-way Bass-reflex design |
Price | €549.00 | €349.00 | €499.00 | €499.00 | €469.00 |
RMS Power Handling | 150 W | 120 W | 80 W | 70 W | 150 W |
Recommended Amplification | 40 – 200 W | 30 – 150 W | 30 – 120 W | 30 – 120 W | 40 – 200 W |
Tweeter | 1 x 25 mm (soft dome) | 1 x 25 mm (soft dome) | 2 x 25 mm (horn-loaded) | 1 x 25 mm (horn-loaded) | 1 x 25 mm (soft dome) |
Mid-Bass | 2 x 170 mm (with central phase plug) | 2 x 140 mm (with phase plug) | 1 x 140 mm | 1 x 140 mm | 2 x 170 mm |
Woofer | None | None | None | None | None |
Frequency Response (±3 dB) | 43 Hz – 25 kHz | 55 Hz – 25 kHz | 65 Hz – 25 kHz | 65 Hz – 25 kHz | 53 Hz – 25 kHz |
Sensitivity(1 watt @ 1 Meter) | 93 dB | 92 dB | 87 dB | 90 dB | 93 dB |
Nominal Impedance | 6 Ω | 6 Ω | 8 Ω | 6 Ω | 6 Ω |
Minimum Impedance: | 4.5 Ω @ 180 Hz | 3.8 Ω at 187 Hz | 7.5 Ω @ 190 Hz | 4.8 Ω @ 7400 Hz | 4.6 Ω @ 202 Hz |
Crossover | 3,000 Hz | 3,500 Hz | 1,900 Hz | 3,900 Hz | 3,200 Hz |
Bass-Reflex Tuning Frequency | 57 Hz | Not Applicable | 57 Hz | Not Applicable | 54 Hz |
Dimensions (WxHxD each) | 600 x 207 x 250 mm | 470 x 176 x 180 mm | 380 x 220 x 170 mm | 207 x 181 x 290 mm | 650 x 280 X 170 mm |
Weight (each) | 12.7 kg | 9.1 kg | 5.3 kg | 5.1 kg | 13,3 kg |
The Bottom Line: Elipson Brings the French Charm—Sans the Price Hike
Elipson may fly under the radar in the U.S., but with the Prestige Facet II series, the oldest French speaker brand reminds us that not all good things come with a luxury tax. Ten models deep, this updated lineup covers just about every listening scenario—stereo, home theater, compact spaces, and larger rooms—without forcing you to choose between good sound and your next mortgage payment.
With prices starting around $550 for a pair of 6B bookshelves and topping out at $3,300 for the flagship 34F towers, there’s still room left in the budget for a solid amp or streaming source. Need proof? Just look at Elipson’s Connect 2130 Xi streaming amplifier—under $700 and built to play nice with these speakers. And if you need to round things out with some low-end thump, their Prestige Facet Subwoofers (8″, 10″, or 12″) are still in the mix—even if they haven’t received the full “Facet II” makeover yet.
That said, the competition doesn’t sleep. Acoustic Energy’s 300 Series, JBL’s Stage 2 lineup, and even Q Acoustics’ latest 5000 Series offer strong contenders at similar or lower price points. But Elipson brings something different: a bit of design elegance, a sense of heritage, and a refusal to shout when a wink will do. Très bien.
Pricing & Availability
The Elipson Prestige Facet II Speakers are priced as follows in Euros. US pricing forthcoming. Available through Authorized Dealers.
- Floorstanding Speakers
- Bookshelf Speakers
- Center Channel Speakers
- Surround Speaker
- 7SR – €499.00 (pair)
- Height Speaker
- 6ATM – €499.00 (pair)
- LCR (Left/Center/Right) Speaker
- 14LCR – €469.00 (each)
Related Reading
