Elgato EyeTV HD DVR for Mac
Updated EyeTV 3.4 software will enable streaming of live or recorded TV on Apple’s iPad
Elgato debuted the world’s only DVR solution which provides full access to premium cable or satellite TV content on a Mac — EyeTV HD. Customers can now watch record, edit and enjoy cable and satellite in high-definition, including all their premium channels. EyeTV HD includes a unique dual-format capture mode that records in iPad and iPhone formats at the same time, allowing users to stream live and recorded TV to an iPhone or iPad using the optional EyeTV app.
Easy Setup
EyeTV HD is a breeze to setup and use; simply connect EyeTV HD to the outputs of the cable or satellite receiver with the included component cables, and to the computer via USB. Then position the included infrared channel changer cable nearby. The EyeTV software setup assistant takes you through a simple configuration process and in just a few minutes you’ll be enjoying all your premium content like never before.
Unique dual-format capture mode
EyeTV HD also has a unique dual-format capture mode so that you can record in iPad and iPhone formats at the same time. EyeTV HD enables super-fast exports to iTunes from EyeTV. It is also possible to stream live TV, including high definition TV, to iPad or iPhone, using the optional EyeTV for iPhone/iPad app.
Superb quality digital TV recordings
EyeTV HD records in the pristine H.264 format for a crystal clear, high-definition digital picture. The H.264 format delivers beautiful image quality and a superb compression ratio, which produces smaller file size when compared to MPEG-2 recordings. H.264 can match the best possible MPEG-2 quality at up to half the data rate.
Elgato EyeTV HD DVR - Back
Capture HD and SD video from a camcorder or VCR
EyeTV HD can capture video from analog and digital sources such as a VCR or a camcorder. EyeTV HD includes component inputs for HD sources, as well as S-Video and composite inputs for standard definition sources. Simply connect the video source to your computer using the included breakout cable, then watch and even record the picture on your computer as an EyeTV recording.
Archive recordings
EyeTV HD also comes with Toast Basic disc-burning software so you can archive your favorite movies and TV shows and save space on your hard drive.
Award-winning software
EyeTV HD comes with EyeTV 3, the award-winning TV software for Mac. Watch, pause, and rewind live TV — at the desk or on the couch. Search the Program Guide using multiple criteria, and record one show or create Smart Series Guides to record the entire season of a TV series. Edit recordings, and share them with other Macs on the network. EyeTV can even export TV shows to iTunes automatically for playback on iPhone or iPad.
EyeTV 3 includes one year of free data from TV Guide, with optional renewal for only US$19.95 per year. An optional EyeTV app is available to stream live or recorded TV to an iPhone or iPad. Smart Series Guide functionality requires a TV Guide subscription.
System Requirements
  • Macintosh: 2.26 GHz Intel Core 2 Duo processor or better, Mac OS X v10.5.8 or later
  • 2 GB RAM, built-in USB 2.0 port
  • Cable or satellite receiver with analog video and audio outputs (component output required for HD)
  • Internet connection required to download Program Guide data.
Elgato EyeTV HD DVR Box
What’s In The Box
  • EyeTV HD recorder
  • EyeTV 3 TV software for Mac (CD-ROM) Infrared remote control with battery pack
  • EyeTV infrared channel changer
  • USB cable (6 ft)
  • Component video cable (6 ft)
  • Stereo audio cables (6 ft)
  • Breakout cable for composite and S-Video inputs
  • PDF product manual (CD-ROM)
  • Quick start guide
Availability
EyeTV HD is available from the Elgato Online Store and from the Apple Store at a price of US $199.95.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
