ELAC and ADSUM’s Special Edition Debut ConneX Powered Bookshelf Speaker System Offers Modern Hi-Res Support and Retro Vibes
ELAC collaborates with Brooklyn based clothing company Adsum on new Designer Series wireless speakers for $649/pair.
ELAC Debut ConneX Adsum Powered Speaker Pair White
The retro vibes are strong with this one. ELAC has announced a partnership with the Brooklyn-based fashion label ADSUM. The first result of this partnership is the creation of a special edition version of the ELAC Debut ConneX powered bookshelf speakers.
ELAC’s Fresh Look
This collaboration combines the Debut ConneX with a blend of minimalist design while retaining its established audio performance features. These bookshelf speakers offer a soundbar’s straightforward functionality and convenience while delivering the superior sound quality and visual appeal expected from top-tier separate powered speakers.
ELAC Debut ConneX Adsum Powered Speaker Lifestyle
From Joe Riggi, CEO of ELAC Americas Inc.: “ELAC and ADSUM’s partnership melds advanced audio engineering with urban streetwear aesthetics, setting new standards for style and acoustics,…
The collaboration between Adsum and ELAC goes beyond cosmetic changes; it represents a comprehensive redesign. Adsum contributed an exclusive tubular metal stand and magnetic detachable grilles. The design overhaul also features a modernized cabinet with squared-off edges, freshly painted cabinets, and a new remote control, complemented by custom-colored cables to complete the distinctive look.
The Debut ConneX speakers are designed to be the perfect audio companion for the space-conscious city dweller. Its abundant inputs make it adaptable for everything from cinematic viewing and video gaming to DJing and hosting last-minute gatherings. The speakers are compact enough to blend into any space, yet powerful enough to fill an apartment with neighbor-rousing sound – the ideal speaker set for the city lifestyle.
ELAC Debut ConneX Adsum Passive Speaker Rear
Rear of ELAC Debut ConneX Adsum passive speaker.
ELAC Debut ConneX Overview
The ELAC Debut ConneX system consists of one powered speaker and one passive speaker that are linked together. You can select either speaker for use as the left or right channel.
The powered (primary) speaker houses the amplifiers for both speakers. The primary speaker includes all the physical source connections as well as a Bluetooth antenna. The audio signals needed for the passive (secondary) speaker are transferred from the primary speaker via traditional speaker terminals and wire.
ELAC Debut ConneX Adsum Speakers Front and Back
Connections
  • HDMI (ARC/CEC)
  • USB (24-bit/96kHz)
  • Analog Line/Phono (Switchable)
  • Digital Optical
  • Bluetooth (aptX)
  • Subwoofer Line/Preamp output
  • Passive Speaker terminals
HDMI-ARC/CEC Support: HDMI-ARC allows you to listen to TV sound by providing access to the HDMI-CEC feature on your TV. This enables you to use your TV’s remote to control the volume of the Debut ConneX speakers. Elac also provides a dedicated remote control for the Debut ConneX if you prefer.
Vinyl Support: The Debut ConneX speakers have a built-in switchable MM phono preamp. You can connect both traditional turntables and turntables with their own built-in phono preamp.
USB Input: This allows connection to a PC for listening to music files (No drivers required). When connected to a PC or Mac you can use them to control speaker volume. Hi-res audio up to 24-bit/96kHz is supported.
Bluetooth: The Bluetooth receiver supports aptX allowing for “CD-quality” audio streaming from compatible smartphones, tablets, and computers. Using Bluetooth, you can stream from compatible platforms like Qobuz, TIDAL, Spotify, and Amazon Music HD.
XBass: ConneX includes ELAC’s XBass Enhancer. This provides additional bass extension and output (can be turned off).
Subwoofer Output: In addition to XBass, a subwoofer output is included for connection to an external powered subwoofer if preferred.
ELAC Debut ConneX Adsum Speaker Driver Exploded
Specifications
  • Speaker Type: (1) Powered Speaker, (1) Passive Speaker. Both speakers have a Bass Reflex rear vent.
  • Amplifier Type: Class D
  • Amplifier Power: 50 Watts x 2 (no standardized reference provided)
  • Tweeter: 3/4-inch Soft Dome (each speaker)
  • Woofer: 4-1/2-inch Polypropylene (each speaker)
  • Frequency Response:
    • 66Hz—25,000Hz (Anechoic)
    • 50Hz—25,000Hz (In-Room)
  • Maximum System Output (SPL): 102dB @ 1m
  • Dimensions (WHD for Each Speaker): 5-1/2 x 9-5/8 x 8-inches
  • Weight:
    • Powered Speaker: 7.6 lbs
    • Passive Speaker: 6.3 lbs
ELAC Debut ConneX Adsum Speaker Internal Vent Path
Included Accessories
  • Metal Stands
  • Batteries
  • Power Cord
  • Remote Control
  • Cloth Bag
  • Speaker Wire
  • User Guide
  • HDMI Cable
Accessories included with ELAC Debut ConneX Adsum Speakers
Price & Availability
The ELAC Debut ConneX Adsum Designer Series speakers (model DCB41-DS) are available for $649.98/pair at Crutchfield.
3 Comments
3 Comments
  1. larry
    March 16, 2024 at 3:50 am
    This seems like a smartly designed product having the right combination of features and connectivity options. Add a Wiim Mini and you’ve got a nice-looking small system.
    • Ian White
      March 16, 2024 at 6:50 pm
      Larry,
      I really love the looks of the loudspeakers. And I agree obout adding a WiiM Pro Plus.
      Best,
      Ian White
  2. sorrel
    March 21, 2024 at 3:46 pm
    I have a genuine question: Can one easily remove the two logos from the speaker grilles?
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Can an innovative 17-year old speaker designer with a familiar last name breathe new life into the jaded audiophile loudspeaker industry?
As Black Friday 2024 approaches, Amazon and KEF are teaming up with big discounts on some of the company's best loudspeakers.
This $2500 table-top stereo system bundles a Ruark R610 Music Console with a pair of Sabre-R bookshelf speakers.
