ELAC’s BS 312.2 Bookshelf Loudspeakers Feature a JET 6 AMT Tweeter
At $1,999/pair, the ELAC Elegant BS 312.2 Bookshelf Speakers are more deep than they are tall and come with colorful grille options.
ELAC Elegant BS 312.2-GB (High Gloss Black) Bookshelf Loudspeaker Front Angle
Following the release of the ELAC/ADSUM Special Edition ConneX powered speakers, ELAC is releasing two new speaker lines for 2024, the Vela (2.0), Solano (2.0), and an addition to the Elegant line, the ELAC BS 312.2.
Features
Speaker Configuration: The BS312.2 is a 2-Way, Bass Reflex bookshelf class speaker.
Cabinet: The BS 312.2 incorporates a high-rigidity aluminum cabinet with a low material thickness that enables a unique cabinet shape. The minimal front baffle creates a scenario where the drivers do not interact as much with the speaker cabinet and listeners should hear a more focused and airy sound as a result.
ELAC Elegant BS 312.2-GB (High Gloss Black) Bookshelf Loudspeaker Front Angle and Back
Tweeter: The BS 312.2 is equipped with ELAC’s 6th generation JET 6 tweeter. Utilizing Air Motion technology, the JET 6 is designed to deliver precise highs. The JET 6 also has an extended tweeter low-frequency range for smoother transition (in conjunction with the speaker crossover) to the mid-frequencies. Other benefits include improved signal accuracy, ultra-fast transient response, and detailed resolution.
  • Linear Frequency response > 50 kHz
  • Efficiency: 92 dB / W / m
ELAC AS-XR Woofer Technology
Woofer: The woofer of the BS312.2 incorporates a Crystal Membrane with AS-XR Technology that provides increased stiffness.
The Aluminum Sandwich Membrane supports an Extended frequency range (XR) with smooth roll-off. Other features include a larger voice coil and an additional magnet ring which supports superior efficiency and higher thermal resilience. As a result, the woofer can play louder and longer without compromising speaker linearity.
ELAC Elegant BS 312.2 Base Black Angle
Aluminum Base can be used as bottom plate for LS-60 mounting and works with all ELAC models sold for the past 30 years.
Alrulastic Base: The base of the BS 312.2 combines an aluminum frame with an elastic rubber structure inlay to support acoustic decoupling. The base is available in White High Gloss or Black High Gloss.
The quoted sensitivity (87 dB) and nominal impedance of 4 ohms would suggest that these stand-mounted loudspeakers will require at least 50 watts per channel and it would be our recommendation based on past experience with other ELAC models that listeners aim slightly higher in that regard. The neutral tonal balance will require some careful system matching.
ELAC Elegant BS 312.2 Bookshelf Loudspeakers with Black Base
Aluminum Base under BS 312.2
Specifications
  • Speaker Type: 2-Way, Bass Reflex
  • Tweeter: JET 6 Air Motion Tweeter (AMT)
  • Woofer: 4.5-inch (115 mm) AS-XR Cone
  • Crossover Frequency: 3,200 Hz Hz
  • Frequency Response: 42 to 50,000 Hz
  • Sensitivity: 87 dB at 2.83 v/1m
  • Recommended Amplifier Power: 50 to 150 W/channel
  • Nominal/Peak Power Handling: 70/100 W/channel
  • Nominal Impedance: 4 Ω;
  • Minimum Impedance: 3.4 Ω @ 280 Hz
  • Binding Posts: 5-way metal (Bi-amp/Bi-wire compatible)
  • Magnetic Shielding: No
  • Cabinet Finish: Gloss Black, Gloss White
  • Accessories Included: Metal grille
  • Dimensions (WHD): 123 x  208  x 282 mm (4.8 x 8.2 x 11.1 inches)
  • Net weight (each): 15.9 lbs / 7.2 kg
ELAC Elegant BS 312.2-GW Bookshelf Speakers White with gray grille
ELAC Elegant BS 312.2-GW (High Gloss White)
Price & Availability
The ELAC BS 312.2 will be available in early May through ELAC and its nationwide dealer network at the following prices:
  • BS 312.2-GB (High Gloss Black): $1,999.98/pair
  • BS 312.2-GW (High Gloss White): $1,999.98/pair
Optional Accessories:
  • Floor Stand LS 60 – $459.98
  • Cover grille fabric in different colors – $199.98
Optional color grilles for ELAC ELEGANT BS 312.2 Bookshelf Speakers
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
The British audio company just introduced two totally redesigned in-ear ANC TWS earphones that audiophiles are sure to get excited about.
Roku's budget-friendly 4K streaming stick may not have Dolby Vision or an ethernet port, but for the price, it's hard to beat.
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
