Edifier S550 ENCORE 5.1 Multimedia System
Edifier S550
Edifier today introduced the S550 ENCORE 5.1 Multimedia Speaker System, which features two, 10-inch super bass drivers producing 120 Watts each, creating ground shaking audio. Combined with the 60 Watts from each of the 5 satellites, the S550 encore produces a total of 540 Watts of audio output. The wired remote with display, allows full control of input selection, volume, bass and treble adjustments, surround channel adjustment as well as a 6-level volume boost. The 6-level volume boost function allows listeners to push the S550 encore beyond the maximum volume. DRC and DSP are incorporated into the S550 Encore to keep distortion at a minimum. Super for home theater application, gaming or simply for a plug and play audio option, the S550 Encore can be connected to a variety of audio sources using the 5.1 or two stereo input options.
Features
  • 10-inch super bass driver with twin bass reflex radiators
  • 2-way satellites with splash paint finish
  • 3-1/2″ mid-range drivers and 25mm silk dome tweeters with professionally calibrated crossovers
  • Class D amplifier with Digital Signal Processing (DSP) technology
  • 5.1 channel and 2 stereo input options
  • 6-level extra volume boost for powerful effects
  • Wired controller with LCD w/ visual adjustments and settings
  • Full-functional remote control for volume/treble/bass/light adjustment, mute, input selection and standby
  • Built-in 600W high efficiency switching power supply, low standby power consumption
  • All MDF wooden enclosures to minimize acoustic resonance
Specifications
  • Power output: L/R/C/SL/SR: RMS 60W × 5 (DRC ON) SW: RMS 120W × 2 (DRC ON)
  • Signal to noise ratio: ≥85dBA
  • Input type: 5.1/CD/AUX
  • Input sensitivity: 900mV±50mV
  • Frequency response: Satellite: 130Hz~20KHz (±5dB) | Subwoofer: 42Hz~140Hz (±5dB)
  • Adjustment: Wired controller, remote control
  • Bass unit: 10 inch (260mm), dual 8 ohm
  • Mid-range unit: 3-1/2 inch (92mm), 4 ohm
  • Treble unit: Φ25mm silk dome, 6ohm
Price and Availability
The Edifier S550 ENCORE is currently available for $599.99 USD at www.edifier.us.com/SHOPEDIFIER.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
