Earbuds & In-Ear Headphones
Edifier’s NeoDots Wireless Earbuds Are Feature Packed: Preview
At $129.99, Edifier’s Neodots support LDAC, noice cancellation, multipoint connectivity and low latency gaming with 17 hours of battery life.
Edifier Neodots True Wireless Earbuds with Charging Case Black
Edifier has earned a reputation for making speakers at very reasonable price points, but they also offer an extensive line of earbuds. The NeoDots True Wireless Stereo earbuds are the latest entry featuring a hybrid driver unit combined with a digital signal processor for optimum sound quality.
Let’s dig a little deeper to see if the NeoDots might be the right solution for you.
Hybrid Driver Units
The core of the NeoDots is their Hyper Drivers. Hybrid Driver Units (Balanced Armature and 10mm dynamic drivers) combine with digital signal processing and an active crossover to deliver sound output with high resolution and low distortion and extend the noise cancellation depth to -48dB.
Edifier Neodots True Wireless Earbud Hybrid Driver
The combination of dynamic drivers and balanced armature drivers supports a wide frequency response. The dynamic drivers manage low frequencies, whilst the balanced armature drivers handle mid and high frequencies.
This synergy results in a well-rounded sound profile that enhances the listening experience across different music genres and audio content.
Digital Signal Processor (DSP)
To take full advantage of the Edifier’s Hype Driver technology, a digital signal processor (DSP) is included. This supports enhanced audio quality by optimizing balance and clarity, while the active crossover divides audio signals sending low frequencies to the dynamic driver and mid/high frequencies to the balanced armature (BA) driver. This dual-driver arrangement supports improved sound quality, offering improved clarity, and detail.
Edifier Neodots True Wireless Earbuds Lifestyle
Hi-Res Audio
Edifier claims that the NeoDots have Hi-Res Audio Wireless certification, as well as providing support for LDAC, AAC, and SBC codecs. This enables a versatile and accurate listening experience across various devices.
Hybrid Active Noise Cancellation
Along with optimized sound quality, the NeoDots also incorporate advanced noise-canceling technology. This elevates the listening experience by extending the depth of noise cancellation to -48dB, minimizing unwanted ambient sounds.
With multiple noise cancellation modes available, the earbuds can adapt to different environments, ensuring optimal audio clarity whether you’re in a busy, noisy city, or a quiet home environment.
Edifier Neodots True Wireless Earbuds have 6 microphones
Crystal Clear Calls
In addition to music listening, the Edifier NeoDots are designed to support clear phone interaction. With 6 microphones (3 in each earbud) and AI algorithms, the mics are focused on the human voice, while filtering out background noise. This results in clearer and more accurate audio during hands-free calls, ensuring that conversations are easily intelligible even in noisy environments.
Bluetooth v5.4
Bluetooth V5.4 support enhances seamless audio streaming with a stable connection and a multipoint connection enables users to switch between music, videos, and calls on two devices simultaneously. This makes it more convenient for multitasking and enhancing the overall user experience.
Low Latency Gaming
The 80ms low latency audio in gaming mode ensures that sound effects and in-game actions are synchronized in real time. This supports immersive and responsive gaming. This minimal delay allows gamers to react swiftly to audio cues, enhancing gameplay and overall performance during competitive scenarios.
Edifier Neodots True Wireless Earbuds for low latency gaming
Easy Of Use
With a press control design to avoid accidental touch and with wearing detection, the earbuds pause music when taken off and resume playback when inserted back in your ear canal.
Extended Battery Life
The NeoDots provide up to 17 hours of playtime on a single charge, with a total of 56 hours when utilizing the charging case. A 15-minute quick charge provides an additional 5 hours of use.
Edifier ConneX App
For added use flexibility, the NeoDots are compatible with the Edifier ConneX app which provides the following added features:
  • Preset EQ Options
  • Customize Your EQ
  • Rename Your Device
  • Prompt Volume Setting
  • Schedule Power Off
Edifier Neodots True Wireless Earbuds inside Charging Case Black
Specifications
  • Driver: Balanced armature driver + 10mm dynamic driver
  • Frequency Response: 20Hz – 40KHz
  • Sound Pressure Level: 92dB ± 3dB(A)
  • Bluetooth: V5.4
  • Bluetooth Protocols: A2DP, AVRCP, HFP
  • Bluetooth Audio Codecs: LDAC, AAC, SBC
  • Google Fast Pair: Yes
  • Charging Input:
    • 5V ⎓ 200mA (earbuds)
    • 5V ⎓ 1A (charging case)
  • Charging Time:
    • About 1.5 hours (earbuds)
    • About 1.5 hours (charging case)
  • Charging Port: USB-C (Type-C), Wireless Charging is also supported.
  • Playtime:
    • ANC ON: 12 hours + 28 hours
    • ANC OFF: 17 hours + 39 hours
  • IP Rating: IP55
  • Net Weight: About 64g
Edifier Neodots True Wireless Earbuds Black
The Bottom Line
The earbud product category has exploded in recent years and there are hundreds of models from dozens of brands to consider. For example, we have reported on over a dozen new models in 2024 so far.
With that in mind, whilst the Edifier NeoDots at $129.99 fall into the entry-level segment, it is certainly not short on innovative tech and features.
The Hybrid driver approach is designed to offer sonic benefits and the incorporation of the latest Bluetooth version and wireless hi-res audio streaming support make the NeoDots worth consideration.
Price & Availability
The Edifier NeoDots are available for $129.99 on Amazon
For more information: edifier.com
Related Reading
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
At $1,599, the Schiit Gungnir 2 DAC is modular, upgradable, and compatible with Schiit's new Forkbeard control system and app.
Dongle DACs
This $44 USB-C adapter adds hi-res Bluetooth wireless connectivity to devices such as iPhone that don't support aptX Lossless or LDAC.
At $799, the Denon Home Amp is a 100-watt per channel stereo streaming amplifier that works with HEOS. Just add speakers.
At $69, JLab's wireless sport earbuds offer 14 hours of battery life per earbud, noise cancellation, and swipe+touch controls for any workout.
The Shokz OpenFit True Wireless Earbuds incorporate air conduction technology in a compact, open-ear design with strong battery performance and a comfortable fit.
At CES 2024, Sennheiser is introducing three new wireless noise cancelling headphones designed for fitness, travel, or audiophiles.
JBL's SoundGear Sense and Tune 310C Earphones offer better sound quality, improved levels of comfort, and excellent value for the money.
The iFi Audio iDSD Diablo 2 portable DAC/Headphone amplifier is the first to offer support for Bluetooth aptX Lossless.
