Edifier just released the futuristic looking, oval shaped e25HD Luna Eclipse HD wireless stereo speakers for $250. This new model adds an Optical/Digital input, which means you can now hook them up to your TV for improved sound. However, the non-HD model (e25) can be found on Amazon for about $80 less.
The 74-watt speakers work wirelessly with any Bluetooth enabled device. They can be used wirelessly as table-top, bookshelf, or PC speakers, as well as wired to a TV. Touch sensitive controls – located on the left side of the speaker – control volume, power and track change with a swiping motion when in Bluetooth mode.
Each speaker contains a 3/4″ (19mm) silk dome tweeter and a 3″ (76.2mm) full range speaker drive, producing a total of 74 watts RMS. In addition, each speaker contains two 3″ / 76.2mm passive bass radiators, maximizing the bass performance and listening experience. The incorporation of DSP and DRC minimizes distortion even at the highest volumes, producing clear, clean audio. Amplifiers in each speaker are professionally calibrated with an electronic crossover.
A slim, easy to use remote control also controls volume levels and power to the speakers.
Price and Availability
The Edifier e25HD speakers are available now for $249.99 US / $312.99 CDN in Gloss Black; Gloss White and Gloss Red.
Features
- Powered digital speaker system for TV and home entertainment
- Bluetooth pairing capability with Bluetooth enabled devices
- Versatile connectivity: Bluetooth 4.0, Digital Optical and Auxiliary input
- Touch sensitive controls for volume, play/pause, previous/ next track and standby
- DSP and DRC for enhanced audio performance and distortion control
- Electronic crossover & dedicated power amp to each tweeter & bass driver
- 3 inch bass driver and 3/4 inch silk dome tweeter in each speaker
- Dual 2″ x 3″ passive bass radiators for enhanced bass effect in each speaker
- Wireless remote for volume and power
Luna Eclipse Speaker Stands
Edifier’s award winning Luna Eclipse speaker series now have a customized stand, adding even more functionality and style. The perfect height to maximize your speaker performance. Each set includes 1 Satellite cable; 1 Aux Cable and 1 Optical cable. Simple to set up-no frustrating instructions. Each color is an exact duplicate and finish of the speakers-creating a seamless and elegant appearance.
- Compatible with e25 Luna Eclipse; e25HD; E235 Luna Eclipse Apollo (all Luna Eclipse speaker series)
- Includes: 1 Satellite cable 19.6 ft | 6m
- Includes: 1 – AUX Cable with Connector Plug 5.5 ft | 1.7m
- Includes: 1 Optical Cable 7.2 ft | 2.2m
- Color / Finish is exact match to speaker
- Available in Gloss Black; Gloss White and Gloss Red
- MSRP: $99.99 US / CDN $124.99
I haven’t heard the e25HD’s, but they should sound same (meaning very good) as the e25 reviewed here!
