Eclipse Unveils TD307MK3 Ovoid Shaped Table-top Speaker
The Eclipse TD307MK3 is the continuation of classic Japanese speaker design in a package that is far more affordable.
Eclipse TD307MK3 White Speaker Angle Lifestyle no grille
Great industrial design never gets old.
ECLIPSE has launched a new loudspeaker, the company’s first new model in seven years. The new TD307MK3 is a compact, full-range speaker for the modern music lover. Several years in the making, the TD307MK3 benefits from the latest ECLIPSE technologies, ready to deliver today’s high-resolution music. It directly replaces its predecessor, the TD307MK2.
Developed and refined in the Kobe factory in Japan, the new TD307MK3 features the same technologies as ECLIPSE’s upmarket models at a fraction of the price. Highly flexible, the TD307MK3 can be used for more than just music; a clever integrated mounting bracket with angle adjustment enables wall- or ceiling-mounting for a range of A/V applications, including custom installation projects.
Eclipse TD307MK3 White Speaker Angle with grille
Eclipse TD307MK3 White Speaker Rear
At the heart of the new TD307MK3 is a new high-performance 6.5 cm full-range fibreglass drive unit upgrade (the first time fibreglass has been used in the TD307 series). The new driver is supported by 12 key improvements, many of which help it deliver its full potential.
A new, larger ‘repulsive’ neodymium main and sub-magnet system have been implemented to provide greater power for the new driver. The magnet system not only increases efficiency, but perfectly complements the material, helping to deliver a wider frequency response, especially in the bass region: the TD307MK3 has an 80 Hz – 25 kHz range.
The new fibreglass cone also benefits from greater speed, lower vibration, greater dynamics and a lower noise floor. Vibration has been reduced by 50% over its predecessor and ECLIPSE’s engineers have achieved an 80% increase in linearity.
Eclipse TD307MK3 Black Speaker with TV Front
The unique ovoid cabinet now has a greater volume to provide an improved environment for the new driver which now moves a greater volume of air. Further improvements include a new, improved terminal arrangement, that accepts both bare wire and banana-terminated speaker cables, plus a new cable-routing design, with the ability to both accommodate larger cables and obscure them from view (for desktop users).
The TD307MK3 also benefits from ECLIPSE’s established, time-proven proprietary technologies, including the diffusion stay, where the drive is internally mounted onto a vibration-eliminating five-pillar stay, and the mass anchor, giving a solid support for high-speed cone movements.
Eclipse TD307MK3 White Speaker Base Swivel
Achieving great sound quality for music, movies or TV is simple with the integrated angle adjustment which provides -25 to 30 degrees of movement when placed horizontally, plus 0 to 90 degrees when used on a wall or ceiling.
Commenting on the new model, Masaya Shirai, ECLIPSE’s Sales Executive (outside Japan) said, “There are lots of great loudspeaker systems in the UK, however, there is something unique in what ECLIPSE does in terms of ‘sound space reproduction’. We are proud to launch the TD307MK3 which achieves sound space reproduction just as well as ECLIPSE’s higher-performance models. We hope music lovers will to find an opportunity to experience them and ‘see’ artists perform in front of them, instead of just listening to loudspeakers.”
Eclipse TD307MK3 Black Speaker Side
Specifications
  • Frequency response: 80 Hz-25 kHz(-10 dB)
  • Efficiency/sensitivity: 80 dB/Wm
  • Input resistance (rating/max): 12.5 W/25 W
  • Impedance: 8 Ω
  • Maximum dimensions: 135 × 212 × 184 (WxHxD in mm)
  • Weight (per speaker): Approx. 2 kg
How it works
Eclipse TD307MK3 Loudspeaker Cut away
Price & Availability
The Eclipse TD307MK3 is available now in black or white, priced at £300 each/£600 per pair.
For more information: eclipse-td.com
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Can an innovative 17-year old speaker designer with a familiar last name breathe new life into the jaded audiophile loudspeaker industry?
As Black Friday 2024 approaches, Amazon and KEF are teaming up with big discounts on some of the company's best loudspeakers.
This $2500 table-top stereo system bundles a Ruark R610 Music Console with a pair of Sabre-R bookshelf speakers.
