Easy-Doks CR19 Speaker Dock with Keyboard
CR19 Speaker Dock
The Easy-Doks CR19 charges and docks up to 3 devices simultaneously, displaying your devices in one place at all times. The Easy-Doks CR19 lets you continue using your devices while charging with the included docking/charging stand, Bluetooth keyboard and speaker system. Easy-Doks CR19 charges all phones (including iPhones, Androids & Blackberrys), tablets (iPads, Galaxys, Kindles, etc.), MP3 players (iPods, etc.), headsets, Bluetooth speakers, and more at the same time, for a professional looking charging/docking solution.
The CR19 features Smart Current Detection (SCD) Technology to charge each device individually, adjusting the flow to ensure proper charging to each device to avoid harmful over-charging, which reduces battery longevity. The CR19 also features a “Tidy-Cable” organizer to keep cables neat; an FM stereo alarm clock radio with remote for waking up with music; a long-life battery Bluetooth full keyboard, which is easier to use than the keyboards that are supplied with devices; and a speaker system, which lets you listen to one device while charging the devices at the same time.
“The Easy-Doks19 is a great solution, especially when you are at home or work and need something to hold up your tablet and want to type on your tablet while charging. Also, I never liked the tablet’s keypad. I like to use a full keyboard instead. And just like any Bluetooth keyboard, you still need a charger for a USB hub. We are also offering that with the Easy-Doks 19,” said Jack Strauser, CEO and inventor of Easy-Doks, LLC.
Features:
  • Organizes: Holds any 3 portable devices (including phones) all at the same time, in one location.
  • Charges: Charges 3 devices using SCD (Smart Current Detection) to adjust the current flow to ensure proper charging to each device.
  • Plays: Displays and lets you listen to one device on its high quality speaker system while charging devices.
  • Clock Radio: Lets you wake up to FM stereo alarm clock radio with time, alarm, and sleep functions.
  • Bluetooth Keyboard: Connects to full long-life battery Bluetooth keyboard for easy typing.
  • Compatible cradle for smartphones and MP3 players.
  • Surge protection built-in.
  • Tidy-Cable organizes cables.
  • Battery backup for power outages.
  • Compatible with any smart device.
  • 4W output power.
  • AC/DC Adaptor (UL approved).
  • AC 110V/50Hz~AC 240V/60Hz.
Price and Availability
The Easy-Doks CR19 will be available February 2013 priced at $84.99. It comes with 3 charging ports, Bluetooth Keyboard, Alarm Clock, Speaker System, docking station, 3 USB charging cables, AUX cable, AC adaptor, and cradles. Additional Easy-Doks versions are also available (see list below). www.easy-doks.com
Additional Versions Available with One to Six USB Charging Ports
  • CR15 (3 charging ports) $34.99
  • CR30 (4 charging ports) $79.99
  • CR19 (3 charging ports & Bluetooth keyboard) $84.99
  • CR34 (6 charging ports) $99.99
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
