Earthquakes MiniMKV Delivers Petite Size With Massive Sound
FOR IMMEDIATE RELEASE
Media Contact:
Jean-Paul Lefebvre — Earthquake Sound Corp.
+1.510.732.1000
+1.510.732.1095
pr@earthquakesound.com
Earthquake’s Mini MKV Delivers SuperNova Performance From a Tiny 9 x 9 Cube
Denver, Colorado September 2006 – Earthquake Sound Corporation delivers big bass from a tiny 9-inch cube, named Mini MKV. This petite beast delivers unreal bass from an extremely elegant, compact design that is sure to fill any room with unbelievably large sound.
The newest addition to the mighty line of SuperNova subwoofers is sure to send a tingle up any audiophile’s spine. SuperNova subwoofers are renown for their intense effects, realism, and bone chilling accuracy. New for 2006 the SuperNova Mini MKV is no exception, it will literally rock your soul.
Earthquake’s Mini MKV is dressed to impress with its exquisite multi layer high gloss, piano black lacquer finish. This tiny work of art is hand finished by professionals who pride their work, down to deepest pearl essence. The Mini has several layers of lacquer, which are carefully applied allowing the coats to create a bond for a thicker more robust finish. In addition the coats of lacquer are drenched in several more coats of clear coat, for a look that is extremely desirable for any taste.
Designed to integrate audiophile grade bass response into almost any existing theater, the new Mini MKV can take a system from being anemic and bent out of shape, to the fit well-balanced system that you need. The Mini MKV employ’s Earthquake patented SLAPS passive radiator technology, which allows this deceiving mini sub to dish out some 25Hz and lower. Also included are some useful tools that Earthquake kindly provided for consumer convenience. Some of these features include 180° phase adjustment, auto signal sensing ON/OFF, 110/220-volt switch able, built in 320-Watt, high efficiency digital amplifier and much more.
MORE FEATURES:
• Elegant high gloss piano-black lacquer finish
• Convenient compact size
• Automatic signal-sensing turn-on and stand-by mode
• SLAPS Patented Passive radiator technology
• RCA & high-level inputs
• Selective variable crossover
• MAX Power: 320 Watts
• Driver: 8″ high power + 8″ SLAPS
• Frequency Response: 22Hz-160Hz
• Voltage: 115V – 220V / 50-60Hz
• Dimensions (HxWxD): 10.5″ x 11.75″ x 10.5″
• Weight: 16lbs
• MSRP…$899.00
About Earthquake Sound Corp.
Earthquake’s innovative audio technologies connect millions of people around the world with the sound solutions they need. Founded in 1985 by Joseph J Sahyoun and his brother Abraham Sahyoun, Earthquake Sound designs, manufactures, and markets high performance audio systems for use in home and audio-video systems, after-market and OEM automotive systems. Earthquake’s great dealer programs and consumer warranties provide measurable profit margin, while enhancing the overall experience for users. Earthquake is headquartered in Silicon Valley with offices throughout the Americas, Europe, and Asia. For more information, visit www.earthquakesound.com
Earthquake is a trademark of Earthquake Sound Corp. All other company and product names may be trademarks of the respective companies with which they are associated. Prices and Specification Subject to change without notice.
application/mswordUpload
minimkv_release.doc (87.6 k)
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
