EarFun’s Tune Pro Wireless Headphones: 120-Hour Battery Life & Hybrid ANC — Peace & Quiet Until AI Takes Over
EarFun Tune Pro Hybrid ANC Wireless Headphones offer 120-hour battery, and AI calls for peanuts—just don’t expect a fancy case or Hi-Res Bluetooth. Big features, $70 price, minor compromises.
EarFun Tune Pro Wireless Headphones Black
EarFun, founded in China in 2018, has built a reputation for packing serious tech into budget-friendly earbuds—and they’ve quietly been doing the same with full-size headphones. After launching the well-received Wave Pro in 2024, EarFun is back in 2025 with the Tune Pro, a feature-stuffed follow-up that punches well above its $69.99 price tag.
The new EarFun Tune Pro delivers a spec sheet that reads like something twice the price: Hi-Res Audio certification (via wired connection), hybrid active noise cancellationAI-enhanced call clarity, and a frankly absurd 120-hour battery life. Whether you’re commuting, working from home, or trying to ignore the noise of modern life, the Tune Pro aims to offer a premium listening experience without draining your wallet.
Dual Drivers, Double Trouble: Because One Just Isn’t Enough
EarFun Tune Pro Headphones - Dual Drivers
The Tune Pro doesn’t settle for your standard one-size-fits-all driver setup. EarFun crammed in a new dual-driver design that does more than just check boxes. The 40mm PET composite film driver handles the heavy lifting—deep, cavernous bass that doesn’t drown out the mids, and highs that don’t stab you in the ears.
Then there’s the 10mm LCP polymer driver riding shotgun, laser-focused on pulling more texture and air out of the top end. It’s not just marketing fluff—this setup actually delivers some punch and clarity, especially at this price. For $69.99, it’s more firepower than most budget cans are even pretending to offer.
Home Theater Mode: Budget Bangers with a Side of Spatial Trickery
Whether you’re streaming from your couch or plugging in like it’s 2005, the new Home Theater Mode throws in some real tech muscle. You get enhanced 2-channel stereo for your lossless purist moments, plus a surprisingly convincing 360-degree spatial sound mode when you want to fake the IMAX experience without dropping a paycheck. It’s a flexible setup that punches up movies, games, and music with way more immersion than most $69 headphones have any right to offer.
earfun-tune-pro-headphones-app
Hybrid ANC: Shut Out the World Without Taking Out a Loan
With Hybrid ANC that cancels up to 45dB of chaos, the Tune Pro is your budget-friendly force field against leaf blowers, crying babies, and that guy on Zoom who still hasn’t found the mute button. Flip on ANC mode and the outside world fades—letting you actually focus, decompress, or just disappear into your playlists like a socially acceptable hermit. For $69, that’s not just noise cancellation. That’s therapy.
Wireless or Wired: However You Roll, the Tune Pro’s Got You Covered
Whether you’re a wireless wanderer or a cable-clutching purist, the Tune Pro doesn’t make you choose sides. With Bluetooth 5.4 onboard, you get faster, more stable connections, better battery efficiency, and lower latency than ever before—perfect for streaming, gaming, or pretending you’re in a music video during your morning commute. Need to go old school? Plug in with the AUX cable and keep the tunes (and ANC) rolling. And thanks to multipoint support, switching between your phone and laptop is as easy as it should have been five years ago.
120 Hours of Battery Life: Because Charging is for Quitters
The Tune Pro delivers a ludicrous 120 hours of total playback—yes, you read that right. That’s nearly a full workweek of music, podcasts, and Zoom calls without begging for a charger. Compared to other headphones in the $69 price bracket, EarFun’s latest laughs in the face of low battery warnings. And if you do run out of juice (somehow), a quick 15-minute top-up nets you another 10 hours. That’s not battery life—that’s endurance training.
AI-Enhanced Clear Calls
earfun-tune-pro-headphones-enc
The Tune Pro uses an AI-powered 5-microphone array to keep your voice front and center—no matter how chaotic your environment is. Whether you’re stuck in a noisy café or trapped in another never-ending Zoom meeting, intelligent noise reduction ensures you come through loud and clear, not like you’re calling from inside a tin can.
EarFun Audio App
If you need to access your Voice Assistant of choice, you can do so straight from the headphones with a single tap. You can monitor incoming emails on your laptop while enjoying mobile gaming with the dedicated Game Mode. Game Mode can be accessed via the companion EarFun mobile app (iOS, Android), enabling the Tune Pro to deliver ultra-low latency times. The EarFun app provides additional features, such as the ability to fine-tune your sound settings with the multi-band equalizer, adjust noise cancellation, and more.
Lightweight Comfort & Portability
The Tune Pro’s ergonomic, lightweight frame is built for long hauls—whether you’re working all day or zoning out on a cross-country flight. Soft, breathable ear cups create a secure seal without clamping your skull like a vice, and when it’s time to move, the foldable design slips easily into your bag without hogging space. No bulk, no fuss—just comfort that goes the distance.
earfun-tune-pro-vs-wave-pro-headphones
Tune Pro (left) vs. Wave Pro (right)
Comparison
Tune Pro (2025)Wave Pro (2024)
Price$69.99$59.99
Earphone TypeOver-Ear Closed BackOver-Ear Closed Back
Speaker Drivers40mm + 10mm Dual Drivers40mm DLC dynamic coil Driver
Bluetooth Version5.45.3
Bluetooth CodecsSBC, AACSBC, AAC, LDAC
Bluetooth MultipointYesYes
Bluetooth Wireless Frequency2.402GHz-2.480GHz        2.402GHz-2.480GHz
Wireless Range15m (without obstacle)15m (without obstacle)
Wired ConnectionYesYes
Microphones 5 (AI Enhanced)5 (AI Enhanced)
ANC (Active Noise Cancellation)Hybrid ANC up to 45dB & Anti-Wind NoiseHybrid ANC up to 45dB & Anti-Wind Noise
Hi-Res AudioYes (wired connection only)Yes
Battery Capacity1100mAh800mAh
Charging time3 hours2 hours
Battery Life (ANC OFF)120 hours80 hours
Battery Life (ANC ON)80 hours55 hours
Power Input5V/1ADC 5V/1A
FinishBlackBlack, Oat White
Dimensions195.3 x 164.9 x 81.4 mm
(7.69 x 6.49 x 3.21 inches)
159.7 x 82.4 x 210.8 mm
(6.29 x 2.44 x 8.3 inches)
Weight289.5g (10 oz)268g (9.45 oz)
In The BoxEarFun Tune Pro
Aux Cable
USB-C Cable
User Manual
EarFun Wave Pro
Aux Cable
USB-C Cable
User Manual
Travel Case
earfun-tune-pro-headphones-angle
The Bottom Line
The EarFun Tune Pro packs impressive tech—hybrid ANC, Bluetooth 5.4 with multipoint connectivity, wired Hi-Res audio support, AI-assisted calls, and an outstanding 120-hour battery life—into a lightweight, comfortable design, all for a surprisingly low price. On the downside, it lacks Hi-Res Bluetooth codec support and doesn’t come with a carrying case, which might annoy travelers. Still, if you want full-size wireless headphones loaded with features and value, the Tune Pro is a smart, budget-friendly choice that punches well above its weight.
Price & Availability
The EarFun Tune Pro is available for $89.99 $69.99 at Amazon for direct from EarFun.
If you prefer the EarFun Wave Pro, it is available for $79.99 $59.99 at Amazon.
1 Comment
1 Comment
  1. Anton
    May 29, 2025 at 5:12 pm
    Look like cheap Chinese crap. Sorry to be crass but all of that driver tech does not impress even at $70.
Ruark MR1 MK3 Desktop Speakers with iMac
Ruark MR1 Mk3 desktop speakers deliver high-res sound, versatile connectivity, and compact design. Add the RS1 subwoofer for deep bass without taking up space.
Nothing CMF Buds 2 Cases all colors Nothing CMF Buds 2 Cases all colors
Earbuds & In-Ear Headphones
Nothing’s CMF Buds 2 earbuds feature Dirac Opteo technology for superior sound clarity, deeper bass, and hybrid ANC—all in an affordable, durable package perfect...
beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile
Beyerdynamic DT 990 PRO X adds detachable cable, 48-ohm impedance, STELLAR.45 drivers, and improved comfort—all for just $199.
Clearaudio Compass Turntables in Black and Silver with lid up front Clearaudio Compass Turntables in Black and Silver with lid up front
Discover the Clearaudio Compass, a German-engineered entry-level turntable built for audiophiles. Precision, style, and performance—ready to shake up Rega, Pro-Ject, and VPI.
Sennheiser BTD-700 with Momentum4 Headphones Sennheiser BTD-700 with Momentum4 Headphones
Dongle DACs
Sennheiser BTD 700 Bluetooth dongle boosts wireless audio with aptX Lossless, low latency, and Auracast—plug & play high-def sound for any device.
Pro-Ject Travel Set in Black and Silver Pro-Ject Travel Set in Black and Silver
Take real hi-fi on the road—no, not some tinny Bluetooth box. The Pro-Ject Travel Set is proper stereo, not sound for peasants. Fits in...
Father's Day Gift Guide 2024 Best Tech and HiFi Gifts
Upgrade Dad's digital lifestyle with gifts he'll enjoy all year and beyond this Father's Day. New Hi-Fi, Headphones, Home Theater and more!
Over-Ear Headphones
HiFiMAN Susvara Unveiled delivers refined planar magnetic sound with improved comfort and a natural soundstage. Discover why it needs a powerful amp and how...
Over-Ear Headphones
HiFiMAN’s Isvarna closed-back headphones combine dynamic bass with planar clarity in a unique dual-driver design, redefining what closed-back planar-magnetics can achieve.
Digital Music Systems
Three years in the making, Qobuz Connect is here and it's available on more devices than you might think.
Over-Ear Headphones
HiFiMAN HE1000 Unveiled Review: Discover how this near flagship planar magnetic open-back headphone delivers natural tone, detailed mids, and wide soundstage—if your amp's up...
Over-Ear Headphones
Think sub-$100 headphones can’t impress? Think again. The Kiwi Ears Ellipse punches above its price with surprising bass, solid imaging, and comfort—just don’t expect...
Over-Ear Headphones
Explore the HiFiMAN Arya Unveiled: detailed review of its sound, design, comfort & performance. Is this the best Arya headphone yet?
Over-Ear Headphones
Focal goes open-back on a budget—sort of. The Hadenys brings surprising bass, polite tuning, and typical French flair for $495. Balanced cable lovers? C’est...
Over-Ear Headphones
Focal Azurys deliver detailed sound, strong bass, and solid build quality at under $500. A top choice for closed-back headphone fans.
