Dyson Zone Headphones with Air Purification Launch in the US: Dirty Air is the Mind Killer?
Dyson has launched the Zone Headphones with Air Purification in the US. If you can get past the Marvel Antman or Bane-looking face gear, then these futuristic wireless headphones might be for you.
The new Dyson Zone Headphones feel like they walked out of Dune, Antman, or one of the numerous Mortal Combat sequels; and we’re being rather serious about that.
Can you imagine Bane listening to Anthrax whilst beating the living hell out of Batman in a pair of these?
In the aftermath of the COVID pandemic, we can understand why some people are still rather paranoid about the spread of airborne bacteria — but these feel like the foretelling of a dystopian future that fill us with a form of dread.
Dyson Zone Headphones with Air Purification on man
In what might be one of the weirdest-looking audio products ever released, innovative vacuum cleaner and bladeless fan maker Dyson has unleashed its Dyson Zone Headphones with Air Purification which are designed to provide users with an immersive personalized listening experience while fighting the effects of air pollution at the same time.
The Dyson Zone can be worn as headphones only (thank goodness!) or can be paired with the detachable visor for the additional benefit of purified air delivered to your breathing zone.
Dyson Zone Headphones with Air Purification lowered on a woman
Features
Scientific Audio Engineering: Dyson states that the Dyson Zone is the result of years of research and development to ensure that first and foremost the headphones deliver ultra-low distortion, advanced noise cancellation, and faithful, full-spectrum audio reproduction. The headphones deliver immersive audio and relief from unwanted city noise with advanced active noise canceling (ANC), low distortion, and neutral frequency response for accurate sound reproduction.
High-efficiency Air filtration: The precision-engineered compressors in each earcup draw air through dual-layer Electrostatic filters and project two streams of purified air to the wearer’s nose and mouth, channeled through the non-contact visor. The Electrostatic filters capture 99% of particle pollution as small as 0.1 microns1, and the K-Carbon, potassium-enriched carbon filters capture prevalent gases most associated with city pollution, including NO2 and SO2
Dyson Zone Headphone Parts
Dyson Zone Headphones with Air Purification See- thru
Tip: Dyson claims that filter efficiency tested to ISO 29463 adapted at max flow setting by an independent third-party laboratory. Capture rates may differ depending on real-life usage.
The My Dyson App: This provides real-time feedback and control.  Ther app can be used to adjust the airflow speed, switch between transparency and isolation mode, adapt equalization to preference, and more. An onboard sensor in the headphones monitors the air for NO2 levels, which is via the app, along with real-time environmental noise levels. The app is available for iOS and Android.
Dyson Zone Headphones  App Screenshot
Specifications
  • Speaker Drivers: 40mm neodymium with 16 ohm impedance.
  • Microphones:  8 for noise canceling support (4 on each side) and two for phone call support.
  • Playtime (Battery Life): Up to 50 hours for audio-only / up to 4 hours in low-flow air filtration mode.
  • Wireless Connectivity: Bluetooth ver 5.0
  • Active Noise Cancelling (ANC): Up to 38 dB with total attenuation up to 40 dB. Noise monitoring is performed 384,000 times per second via noise-canceling microphones.
  • Frequency Range: 6 Hz – 21 kHz
  • Distortion: 0.08% at 94 dB 1 kHz
  • Filter life: Up to 12 months
  • Colorways: Ultra Blue & Prussian Blue / Prussian Blue & Bright Copper
  • Dimensions (HWD): 7.24 x 11.81 x 3.98 inches
  • Weight: 1.4 pounds
Dyson Zone Headphones with Air Purification detached on a Woman
Dyson Zone Headphones (as headphones only)
Package Contents
  • Dyson Zone™ headphones with air purification (Ultra Blue/Prussian Blue)
  • USB-C Charging Cable
  • Visor Cleaning Brush
  • “Quarter Turn” Hard Case
  • Visor Sleeve
  • 2 x Electrostatic Carbon Filters
Dyson Zone Headphones with Air Purification Blue
Availability and Pricing
The Dyson Zone™ is available to purchase online for $949 at Best Buy, Dyson.com, and in-store at Dyson Demo stores.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
