DWIN DVI Cable Extender Transmits 100 feet
LAS VEGAS – DWIN Electronics, Inc. has developed a new DVI cable extender capable of delivering uncompressed high definition video signals up to 100 feet. The new accessory works with DWIN’s TransVision 3+ high definition video projectors and DWIN’s new HD-Series plasmas.
DWIN will display the technology at the 2005 CES show at the Las Vegas Convention Center, Booth 20656 — South Hall 1, LVCC.
Suggested retail price for the DWIN DVI Cable Extender is $245. When combined with the required DWIN-proprietary DVI cables, the system is competitive with fiber optic-based cable for similar lengths.
The DVI Cable Extender is designed primarily to respond to the needs of custom installers to enable multi-room high definition video systems beyond the reach of conventional DVI cables. Installation is flexible and easy: power is supplied by the DVI cable itself and requires no external power supply.
With DWIN’s proprietary ¾-inch circular DVI connectors, DVI cables can be easily pulled through standard one-inch conduit. Cable distances of up to 100-feet are possible using two DWIN 50-foot DVI-R cables.
The DVI Cable Extender was developed to support DWIN’s new DuoVision dual-display high definition processor. DuoVision enables two separate high definition video displays to share video gear from one central location in the home. Integrating two DWIN native-rate processor/scalers, the DuoVision controller simplifies installation of multi-room high definition systems and helps consumers avoid the added expense of separate HD video source devices.
Founded in 1985, DWIN Electronics, Inc. specializes in the design and manufacturing of high performance consumer and professional video projectors, digital video processors and displays.
Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
