DuraLabel 4000 Label / Sign Printer
The DuraLabel 4000 Label & Sign Printer was introduced today by Graphic Products, Inc. prints on vinyl tapes and die-cut labels 1″ to 4″ in width.
Designed to print with speeds up to three inches per second and with clear 203 dpi resolution, the compact DuraLabel 4000 thermal transfer label printer produces 1″ to 4″ width labels and signs for numerous applications like pipe marking, 5S labeling, chemical hazards, OSHA safety information, machinery and equipment, identification marking and electrical panels.
One key component of the DuraLabel 4000 labeler is the cutter. Two cutter options exist: a manual cutter and an automatic cutter. According to Foos, the cutter plays a larger role in determining which cutter option a facility will select upon purchase because it is one of the more expensive parts of a label printer.
“It may seem simple, but the cutters are really a highly engineered precision cutting tool. A manual cutter gives us the ability to greatly reduce the initial cost of the printer for the customer, yet the option to upgrade to the automatic cutter at any time is available to them,” said Foos.
Utilizing a USB 2.0 communications interface, the new labeler works with any Windows® 2000, Windows® XP, Windows® VISTA or Windows® 7 operating system.
Every DuraLabel 4000 comes bundled with DuraLabel's DuraSuite labeling software, which includes an expansive library of over 700 industrial symbols and pictograms updated to comply with current ANSI and OSHA standards. DuraSuite also comes with over 500 label templates for simple and fast design.
Premium vinyl tapes are available in over 30 colors, and ribbons are available in seven colors. Some black ribbons are specifically engineered to resist oils and chemicals. All DuraLabel labeling supplies and ribbons are designed to withstand harsh environments often associated with industrial environments both indoors and outdoors.
For more labeling options, many specialty supplies can be used with the DuraLabel 4000. Specialty labeling supplies include the following:
  • Arc Flash Die-Cut Labels
  • RTK Die-Cut Labels
  • High-Tack Tape
  • Two-Color Vinyl
  • Self-Laminating Wire Wrap
  • Oily Surface Tape
  • Cold Storage Tape
  • Tamper-Evident VOID Tape
  • Phosphorescent Tape
  • Reflective Vinyl Tape
DuraLabel 4000 (w/Manual Cutter) DuraLabel 4000 Printer (w/Auto-Cutter)
SKU: DL4000MC SKU: DL4000
Price: $899.00 (USD) $1,199.00 (USD)
About Graphic Products Inc.
Graphic Products is a leading label printer and labeling supplies dealer, supplying to industries since 1970. It is the manufacturer of DuraLabel brand printers. It also carries many labelers made by other manufacturers and stocks brands such as Brady, Kroy, Brother, K-Sun, Dymo and Varitronics. It also stocks supplies for discontinued label printers. Graphic Products specializes in same-day shipping to meet its customers' just-in-time delivery requirements.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
