Dual Function Component Solutions Deliver Signal Extension to 300 Meters
Connectivity solutions provider Gefen is pleased to announce the availability of three new system integrators designed for audio/video systems using the component video format. Ideal for large scale home entertainment systems, digital signage applications and high profile audio/video installations, all three solutions perform two functions in a single-box solution, streamlining equipment for an easy installation.
The 4×4 Component Audio over CAT5 Matrix enables a direct connection between any four component video sources and four displays while supporting digital and analog audio inputs and outputs. Individual receivers located at any of the remote displays connect back to the source using just one CAT-5 cable. Up to 300 meters may be traversed with a perfect replication of audio and video resolutions to 1080p. Remote receivers can be purchased individually to tailor the system, which provides seamless matrix switching among all eight devices.
Two new distribution amplifiers from Gefen enable audio/video systems using the component format to split and deliver two or four identical signals. Optional extension of both audio and video up to 300 meters at 1080p full HD using industry-standard CAT-5 cable makes these distribution amps indispensable for new or retrofit installations.
The 1:2 and 1:4 Component Audio over CAT-5 Distribution Amplifiers both operate with the same methodology. One component video input is split and sent to two or four displays with audio input and output in analog RCA and digital TOSlink and S/PDIF formats. Signals can be connected locally on the distribution amp or extended to long-distance locations.The extension of multiple audio formats with component video is achieved through individual receivers for each remote display. Users can purchase receivers only for the displays that require extension, enabling them to tailor the system to their needs.
All three solutions are engineered to account for CAT-5 cable skews so video is delivered with full quality representation at distances up to 300 meters. Gefen supplies high performance CAT-5 cables in various lengths.
LG StanbyME 2 Portable TVs
HDTV 4K & 8K TV
LG's new StanbyME 2 is a portable smart touchscreen TV with a detachable design, QHD screen, built-in battery, and flexible placement.
Pro-Ject E1.2 Turntable Top Black Pro-Ject E1.2 Turntable Top Black
Pro-Ject E1.2 delivers audiophile-grade performance at a budget price. A real entry-level winner with serious upgrades and no gimmicks—just sound.
Cambridge Audio Melomania P100 SE White Headphones in hand Cambridge Audio Melomania P100 SE White Headphones in hand
Cambridge Audio's Melomania P100 SE brings audiophile-grade ANC, 100-hour battery life, and aptX Lossless Bluetooth in a sleek £249/$299 package.
Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On
A/V Furniture & Accessories
Tired of sharing a stained IKEA couch with your dog? The Revelation Luxury chair from Audio Advice brings heat, massage, USB-C, and legit comfort...
Epson ProCinema LS9000 projector. Epson ProCinema LS9000 projector.
With true 4K resolution, a bright colorful image and a motorized lens for maximum flexibility, Epson's new Pro Cinema LS9000 offers a lot of...
Onkyo C-30 CD Player Black Front Onkyo C-30 CD Player Black Front
CD Players
Onkyo's new Icon C-30 CD player brings audiophile tech at a surprising price. Discover why physical CDs still matters at Audio Advice Live 2025...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
