Draper Redesigned rear projection systems at InfoComm
Draper has redesigned its line of rear projection systems, making them lighter weight and easier to install.
The supporting frame is now constructed of unitized framework of blue extruded aluminum with a 2″ square cross section, fabricated from 6061-T6 alloy. It is sized to fit perfectly in your projection room, based upon dimensions you furnish. Each Draper RPX unit comes ready to assemble using provided bolts and hand tools. Using the lettered parts, shoulder bolts and slots for the mirror, and pre-drilled projector cradle, Draper’s RPX units can be assembled in just a few minutes, and the six-axis adjustable platform makes short work of adjusting the projector into place.
“The concept we went into the redesign was simple,” according to Jim Hoodlebrink, information display systems manager for Draper. “We wanted to keep the superior stability and strength of our rear projection systems, while making them lighter for shipping, and shaving a lot of time off the installation process.”
With Draper’s optional Mirror Manager, even fine-tuning the picture onto the screen now takes minutes, saving even more time and money for the installer.
For an up-close look at Draper’s redesigned RPX Rear Projection Systems, stop by booth 1341 during InfoComm 2004, June 9-11 in Atlanta.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
