Photos:
http://www.thomas-pr.com/136/photos/digitalfocimemorycard.html
http://www.thomas-pr.com/136/photos/digitalfocimemorycardpackaging.html
http://www.thomas-pr.com/136/photos/digitalfocimemorycardcolor.html
Release: http://www.thomas-pr.com/pressreleases/digitalfocimemorycardgateway.html
Contact:
Karen Thomas
Thomas PR
(631) 549-7575
kthomas@thomas-pr.com http://www.thomas-pr.com
DIGITAL FOCI LAUNCHES MEMORY CARD GATEWAY — MEMORY CARD READER/WRITER FOR ALL MEMORY CARDS
Lightweight & Portable — Comes in 3 Stylish Colors: Lucid Purple, Midnight Gray, and Crystal Blue
Los Angeles, CA, April 17, 2006 — Digital Foci announced today Memory Card Gateway, a high-speed USB 2.0 memory card reader/writer for virtually all memory card formats, including CompactFlash Type I/II, MicroDrive, SmartMedia, MultiMedia Card, SD Card, miniSD, Memory Stick,MS PRO, MS Duo, MS PRO Duo, and MagicGate MS.
The Digital Foci Memory Card Gateway is the central access point for your digital camera, MP3 player, cell phone, PDA, digital video camera, and computer. With USB 2.0 connectivity, Memory Card Gateway lets you easily access pictures on your digital camera memory card and transfers those pictures to your computer at high speed. You can also easily share photos, music, and other data files with your friends by transferring files from your computer to their memory card. Available in 3 stylish colors: Lucid Purple, Midnight Gray, and Crystal Blue, Memory Card Gateway is compact, lightweight, and completely self-powered via USB port. The included velcro mounting pads also let you place it wherever you want.
Memory Card Gateway features four memory card slots that let you transfer files directly between cards of different formats. The individual LED indicators for each card slot provide assurance of the connection and data transfer status. In addition, the Memory Card Gateway software driver displays picture icons for each memory card format, making it easy to identify memory card drives on the computer.
Simply remove your memory card from the digital camera, insert it into Memory Card Gateway and drag and drop your pictures into your computer. Since you can now transfer files without turning on your digital camera, MP3 player, or PDA, you will also conserve the battery life on those devices.
Digital Foci Memory Card Gateway features:
Directly reads and writes to: CF I / II, MD, SM, MMC, SD Card, MS, MS PRO, MS PRO Duo (miniSD, RS-MMC, MS Duo, and xD with adapter)
USB 2.0 connection provides high speed transfer rates of up to 480 Mbps
Individual LED indicators for each memory card slot show connection and data transfer status
Completely self-powered via USB port (no power adapter needed)
Velcro mounting pad lets you place it where you want
Compact and lightweight design makes it convenient to carry anywhere
4 memory card slots allow direct card-to-card transfer
Customized memory card picture icons and labels make identifying memory card drives on your computer easy
PC & Mac compatible
Unique style and color
Memory Card Gateway comes in 3 stylish colors: Lucid Purple, Midnight Gray, and Crystal Blue. The device measures 3.6″ x 2.1″ x 0.6″ and weighs only 1.8 oz. Memory Card Gateway includes a USB cable, Quick Start Guide, Resource Disc, and Velcro mounting pad. Priced at $29.95, Digital Foci Memory Card Gateway is available immediately online at: www.digitalfoci.com.
DIGITAL FOCI MEMORY CARD GATEWAY SPEC SHEET
Model no. MCG-120
Memory card supported CompactFlash I & II, MicroDrive,
Memory Stick, MS PRO, MS PRO Duo,
(xD-Picture card, RS-MMC, MS Duo, and miniSD with adapter)
Computer interface USB 2.0 (compatible with USB 1.1)
Transfer rate Up to 480 Mbps
Power USB power (no adapter needed)
OS compatibility Windows XP Home/Pro, ME, 2000, 98/SE
Macintosh OS 8.6 and later
Linux OS kernel versions 2.4.x and later
Driver installation required for Windows 98/SE, 2000, and Mac 8.6
Dimensions 3.6″ (L) x 2.1 (W) x 0.6 (H)
Weight 1.8 oz.
