GoldSolution Software announces the release of Driver Magician 3.21, a unique utility for the Windows operating system that backs up, restores, updates and uninstall device drivers with ease.
A device driver is a specific type of computer software, it acts like a translator between device and programs that use the device. All devices in computers will be useless without correct drivers. We often meet the situation where we lost device drivers diskettes or we don’t know what devices are in computers. It will take a lot of time to find correct drivers on the Internet.
Driver Magician offers a professional solution for anyone who wants to back up device drivers for easy restoration. It identifies all the hardware in the system, extracts their associated drivers from the hard disk and backs them up to a location of your choice. Then when you format and reinstall/upgrade your operating system, you can restore all the “saved” drivers just as if you had the original driver diskettes in your hands. After one system reboot, your PC will be loaded and running with the required hardware drivers.
What’s more, Driver Magician has a built in database of the latest drivers with the ability to go to the Internet to receive the updates. It saves lots of time to find the correct drivers and mature new drivers will obviously increase the performance of hardware. If there are unknown devices in your PC, Driver Magician helps you to detect them easily and quickly with its built in hardware identifier database.
Driver Magician is the right choice for device driver backup, restoration and update. It is both affordable to every computer user and a real value.
System Requirements
Driver Magician will run under Windows 98, Me, 2000, XP, 2003 and Vista on an Intel-based 586 PC or greater. The program requires 32 MB of RAM and 5 MB disk space to install.
Price and Availability
Driver Magician is available now. The price for single user license is $29.95 USD. A trial version is available from the GoldSolution Software web site at:
http://www.drivermagician.com
EVALUATION COPIES ARE AVAILABLE ON REQUEST
