Devialet Announces Gemini True Wireless Noise Cancelling Earbuds
At $299, Devialet’s first-ever wireless earbuds come feature packed with noise cancellation and touch controls, along with an app for setup and fine tuning.
Devialet Gemini Wireless Earbuds in Charging Case
Stylish Buds
Devialet, the company known for expensive oval shaped Phantom speakers, has announced their first wireless earbuds called Gemini. Reasonably priced, by Devialet’s standards, at $299 — Gemini brings a lot to the table, including noise-cancellation, touch controls and voice assistant integration with Siri or Google Assistant.
Devialet Gemini Wireless Earbuds Interior View
Gemini’s shape is designed to fit every type of ear. They come with XS/S/M/L eartips for a snug fit along with an app that guides the user which tips fit best. You’ll certainly need a perfect fit and the most finely tuned ears of any of animal on the planet to hear Gemini’s lowest claimed frequency response of 5 Hz. Human hearing just doesn’t extend that low. Not even whales or elephants can hear 5 Hz, which bottom out at 7 Hz and 14 Hz respectively (source Wikipedia). So don’t be fooled by the 5 Hz low frequency spec. It’s either meaningless marketing speak or an error.
Getting back to reality. The Gemini Earbuds are rated IPX4 for water resistance, and claim battery life of 4 to 8 hours, depending how they are used and if noise cancellation (ANC) is on or off. They come with a Qi Wireless / USB-C charging case that fully recharges the earbuds in 1.5 hours. The case itself requires 3.5 hours to fully recharge. So with combined charging/re-charging Devialet claims 24 hours of battery life, since the case can provide three recharges before needing recharging itself. It’s the same type of claim every wireless earbud manufacturer is making nowadays, so watch out for it.
The Devialet Gemini earbuds connect using Bluetooth 5.0 BLE/2.4GHz along with aptX technology (where compatible). Noise cancellation is offered at three different levels: low, high, and plane. Plus, Devialet’s companion mobile app lets users customize sound quality with a 6 band equalizer. The app also can re-configure touch controls. The default settings are Press one time to play or pause, Press and hold to switch between Active Noise Cancellation and Transparency modes, and Double-press to activate Voice Assistant (Siri or Google Assistant).
Price & Availability
The Devialet Gemini True Wireless Earbuds with Active Noise Cancellation (ANC) will be available November 25, 2020. Pre-order now for $299 at devialet.com.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
In-depth review compares three of the best luxury portable Bluetooth speakers on the market from Brane, Soundboks and Devialet.
If you're looking for a better sounding alternative to Apple AirPods, these are the best true wireless earbuds of 2021 so far.
Fendi and Devialet team up to unveil a luxury portable wireless speaker wrapped in iconic Fendi branding on the Milan runway.
Earbuds & In-Ear Headphones
Do the Bowers & Wilkins Pi7 S2 True Wireless Earbuds deliver the outstanding performance of their larger on-ear siblings?
