Devialet Astra & Astra Opéra de Paris: Storming the Bastille of Integrated Amplifiers, One Decibel at a Time
If you’re ready to embrace French audiophile decadence with a side of revolutionary flair, the Devialet Astra range is your ticket to the high table. Just don’t forget—let them eat DACs.
Devialet Astra and Astra Opera de Paris Integrated Amplifiers in Bronze and Gold
Devialet isn’t exactly known for subtlety—and thank God for that. With the new Devialet Astra and Devialet Astra Opéra de Paris integrated amplifiers, the French audio insurgents have fired another sonic cannonball straight through the ancien régime of high-end hi-fi. These aren’t just amplifiers—they’re declarations of war on bulky boxes, dusty traditions, and anything that smells remotely like compromise.
Wrapped in precision engineering and just enough gold to make a Bourbon sweat, the Astra duo is here to remind you that the revolution didn’t end in 1799—it just went wireless, networked, and unapologetically luxurious. Liberté, égalité, fidélité sonore.
French Audio Engineering Takes No Prisoners
Devialet didn’t just show up to the hi-fi party—they stormed the gates back in 2010 with the D-Premier and a little something called ADH amplification, flipping the script on what an integrated amp could be. Fast forward fourteen years and 250 patents later, and the French rebels are back at it with the Devialet Astra (bronze) and Devialet Astra Opéra de Paris (gold): two integrated amplifiers that serve as both a technical statement and a gauntlet thrown at the powdered feet of the old guard.
Designed in Paris and built in France—because of course they are—these sleek units are all about sonic revolution. Devialet isn’t chasing retro nostalgia or rack-stacking excess. Instead, Astra delivers cutting-edge performance, surgical precision, and connectivity options sharper than a sabre from the Napoleonic cavalry. And yes, the Opéra de Paris edition dresses to kill—draped in gold like a revolutionary general marching into battle, powdered wig optional, decadence mandatory.
devialet-astra-angle
CEO Jacques Demont isn’t mincing words either. Astra isn’t just a product—it’s a rallying cry for purity, detail, and emotional depth in playback. Devialet wants you to feel the music like it’s charging at you from the stage at full tilt, not just sit back and admire specs on a brochure.
Backed by a team of nearly 100 engineers and designers headquartered in Paris, Devialet has spent over a decade redefining acoustics across electronics, mechanics, and signal processing. What started as a radical concept has matured into a full-blown empire of innovation—still flying the flag of minimalist design, now borrowing some swagger from Art Deco with just the right dose of Parisian arrogance.
This isn’t just hi-fi. It’s a sonic insurrection—with style.
devialet-astra-dual-front-top
Devialet Astra is available in solo or dual configurations.
Devialet Astra: The Guillotine Blade of Audiophile Engineering
Beneath Devialet Astra’s brutally elegant aluminum shell—so clean it could double as Napoleon’s shaving mirror—beats the bleeding heart of France’s most advanced hi-fi machine. It looks minimalist on the outside, with just a screen and two buttons (how très Devialet), but under the hood it’s an all-out sonic revolt.
You get a preamp, power amp, DAC, streamer, and phono stage—all marching in perfect digital formation inside one box. It’s not just integration, it’s domination. In solo mode, Astra delivers 2 x 300 watts at 4 ohms. Link up two of them and you’re looking at 2 x 600 watts. Viva la stereo separation. Its frequency response doesn’t just stretch—it storms the Bastille.
ADH: Analog and Digital in Revolutionary Unity
Devialet’s ADH (Analog Digital Hybrid) tech makes its return in a more compact, thermally optimized form—still blending Class A’s finesse with the raw power of Class D. It’s Robespierre with a blueprint: ruthless in execution, efficient by design, and engineered to impress. Naturally, it’s Hi-Res certified—because nothing says revolutionary precision like ticking every spec box.
SAM, RAM, and DAC Magic Wire: No Stone Left Un-toppled
SAM (Speaker Active Matching) scans your passive loudspeakers like an acoustic surveillance drone and aligns signal and pressure with surgical precision—pulling from a secret library of over 1,200 profiles. Bass hits harder. Timing? Flawless. No prisoners.
RAM (Record Active Matching) lets the phono stage reconfigure itself with the accuracy of a Parisian tailor, adjusting EQ to your cartridge and pressing. It doesn’t care if your LP is a Japanese import or a battered first pressing from 1972—it adapts, conquers, and extracts every gram of fidelity.
And then there’s Magic Wire, which parks the DAC just five centimeters from the output stage, minimizing signal loss like a guillotine minimizing necks. No noise. No distortion. Just raw, revolutionary clarity.
Forget user “settings.” This is a full reimagining. Astra is configurable down to your room, your ears, your taste in speakers, and your mood. The only thing missing is a tricorne hat and a national anthem.
DOS3: Devialet’s New Operating Regime
Running the show beneath Astra’s polished aluminum shell is Devialet DOS3—a new operating system designed to unify the entire Devialet product line under one digital tricolor. It’s the backbone of a connected future, built to manage both present and yet-to-be-declared innovations. Think of it as the central command post for your music rebellion.
Devialet Astra supports a wide range of current streaming protocols—AirPlay, Google Cast, Roon Ready, Spotify Connect, TIDAL, and UPnP—so integration with your existing setup is straightforward. With Wi-Fi 6 and Bluetooth 5.3 on board, it’s ready for today’s connectivity standards and whatever’s around the corner.
Advanced Configurator: Your Audiophile Command Center
With the new Advanced Configurator—available through the Devialet app or web interface—you’re not just tweaking settings. You’re strategizing like Napoleon before Austerlitz. Volume, phono stage parameters, input assignments, EQ, stereo balance, power modes, and even screen brightness are all fully customizable. Want different input setups for your digital transport and your turntable? No problem. Prefer to darken the screen so it doesn’t light up your listening room like the Champs-Élysées at midnight? Handled.
You can store over 20 custom settings to fine-tune Astra for different setups or moods. Precision meets simplicity.
devialet-astra-amps-rear
Intelligent Inputs. Revolutionary Flexibility.
The rear panel is a triumph of form and function. Devialet didn’t waste a millimeter. These are multimode, fully configurable inputs and outputs, rare in this category and executed with precision. Coaxial, optical, USB-C, Ethernet, dual-band Wi-Fi, analog line, and dedicated phono—they’re all packed in and ready for your stack, streamer, or stubborn legacy gear.
CategoryDetails
Wi-FiWi-Fi 6 (b/g/n/ac/ax) 2×2
EthernetRJ45
USBUSB-C 2.0 (Data Port)
Digital Coaxial InputsUp to 4x RCA
Digital Optical Inputs2x TOSLINK
Analog InputsUp to 2x RCA Stereo
Phono StageMM/MC with 13 EQ Curves & Extensive Cartridge Loading Options
Set Limits Like a Ruler
Don’t want to blow out your speakers—or your sanity—by accidentally blasting volume during your 2 a.m. jazz session? Set default and max volume levels. Rule your system with the calm precision of a digital despot.
Devialet Astra Opéra de Paris: Gold-Leaf Excess for the Bourgeois Audiophile
For those who feel standard aluminum isn’t quite decadent enough for their ears, Devialet has crafted the Astra Opéra de Paris Edition—a gilded tribute to musical royalty, hand-leafed in 23-carat gold by the master artisans at Les Ateliers Gohard. The same folks who restore the Palais Garnier and make sure Versailles still glimmers like the Ancien Régime never ended. It’s the kind of amplifier that makes you want to listen to La Marseillaise with a goblet of Burgundy in one hand and your phone in the other, streaming via Roon.
devialet-astra-opera-de-paris-top
These numbered editions aren’t just golden showpieces—they’re a sonic flex. Every unit features the same uncompromising engineering as the standard Astra, with ADH, SAM, RAM, Magic Wire, and full DOS3 OS control, but draped in enough opulence to make Louis XIV blush.
Devialet’s ongoing partnership with the Opéra National de Paris isn’t just about audio wizardry—it’s also a flag-waving celebration of la grande nation. Seven years deep, this collaboration is equal parts culture, tech, and French exceptionalism. Because why settle for “just good sound” when you can turn your entire listening room into a monument to République-level refinement?
Gold isn’t just for royalty, crypto bros, or overcompensating Versailles enthusiasts anymore. The Opéra de Paris Edition turns your amp into both a precision audio machine and a gleaming tribute to French excess—like Louis XIV decided to moonlight as an acoustic engineer. It’s got Wi-Fi 6, Bluetooth 5.3, and every streaming protocol that matters, but let’s be honest—you’re really buying it to remind your dinner guests that your taste is impeccable and your ancestry possibly treasonous.
Specifications
CategoryDetails
Streaming ServicesAirPlay, Google Cast, Spotify Connect, Tidal Connect, UPnP, Roon Ready (RAAT)
Daisy ChainingUp to 8 Devices
Phono StageAdvanced (MM / MC)
Pre-OutYes (Mono / Stereo)
BluetoothBluetooth 5.3 (AAC, SBC)
FinishesLight Bronze / 23k Gold Leaf (Opéra de Paris)
Power Supply100–240V AC
ConstructionMachined Aluminum Block, Anodized, Laser-Engraved, Shot-Peened
Exclusive TechADH® Next-Gen, SAM®, RAM®, Magic Wire® DAC
Dimensions (W x D x H)386mm x 386mm x 47mm
Weight7.2 kg
devialet-astra-amps-gold-bronze
The Bottom Line
Devialet doesn’t just make amplifiers—they make statements louder than a guillotine drop in 1793. The Devialet Astra and the Devialet Astra Opéra de Paris aren’t for the faint of heart or the thin of wallet, but then again, neither was Versailles.
Here’s how the noblesse oblige breaks down:
Devialet Astra Light Bronze Edition
  • Solo Configuration (2x300W @ 4Ω): $20,000
    That’s twenty grand for a single unit—enough juice to power your speakers and remind you you’ve made it.
  • Dual Configuration (2x600W @ 4Ω): $40,000
    Because one simply cannot storm the Bastille with half a revolution.
Devialet Astra | Opéra de Paris Edition
  • Solo Configuration (2x300W @ 4Ω): $25,000
    Hand-gilded in 23-carat gold by Les Ateliers Gohard—because your amplifier should match your powdered wig.
  • Dual Configuration (2x600W @ 4Ω): $50,000
    That’s right, fifty grand for a dual stack dripping in sonic opulence and Parisian drama. Think of it as the Marie Antoinette of hi-fi: extravagant, exquisite… and probably not long for this world if the peasants ever find out.
In short, if you’re ready to embrace French audiophile decadence with a side of revolutionary flair, the Astra range is your ticket to the high table. Just don’t forget—let them eat DACs.
Viva La Revolution… If Your Wallet Can Handle It.
For more information: devialet.com
2 Comments
2 Comments
  1. Anton LeBlanc
    May 12, 2025 at 9:32 pm
    “Let them eat DACs” might be the best line from a hi-fi article in years.
    The gold one is grotesque looking in a “I want one and 3 French tarts” kind of way. Is it really $50K?
    The basic model at $20K is still very expensive but as you said, it’s an entire system minus the speakers. And it’s the size of a large pizza box.
    Do they have any stores on the West Coast? I’ve seen videos from their Paris flagship and it was tempting.
    • Ian White
      May 12, 2025 at 10:50 pm
      Anton,
      That’s a rather low bar. Having not heard it, impossible to say but I have listened to their speakers more than a few times and not my sack of French bread. I’ve heard their earlier amplifiers with other speakers and it was good. $20K for a complete system in one box with that level of connection flexibility is actually not a bad deal if it sounds like a $20K system. They make good stuff. At least it is different. I’d be curious to see how it handles Maggies.
      IW
PMC prophecy9 Speakers Lifestyle
Discover PMC's latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
WiiM Amp Ultra Integrated Amplifier WiiM Amp Ultra Integrated Amplifier
WiiM Amp Ultra merges the brains of the Ultra and the brawn of the Amp Pro—now with a touchscreen and HDMI ARC for your...
WiiM Sound, WiiM Sub Pro and WiiM Ultra Lifestyle WiiM Sound, WiiM Sub Pro and WiiM Ultra Lifestyle
The WiiM Sound smart speaker and WiiM Sub Pro deliver budget-priced multi-room wireless music streaming. Should Sonos be worried?
Focal Diva Utopia Wireless Loudspeakers High Gloss off white, dune and black Focal Diva Utopia Wireless Loudspeakers High Gloss off white, dune and black
Focal's Diva Utopia wireless speakers now come in Black, Dune, and Off White High Gloss finishes. At $49,499, these beauties are the audio equivalent...
Dan Clark Audio Noire XO Open-back Headphones on stand lifestyle Dan Clark Audio Noire XO Open-back Headphones on stand lifestyle
At $1,299, the Dan Clark Audio NOIRE XO open-back planar magnetic headphones puts more expensive audiophile headphones on notice.
Mother's Day Gift Guide 2025 for Audio Video TV Lifestyle Projectors and Gadgets
Upgrade Mom's home audio and video experiences this Mother's Day with 10 gift ideas she'll absolutely love -- and you might too.
Flagship integrated amp featuring Purifi Eigentakt Hybrid Digital amplifier technology, built-in BluOS multi-room streaming, 32-bit DAC, full MQA decoding, and Dirac Room Correction.
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
In-depth review compares three of the best luxury portable Bluetooth speakers on the market from Brane, Soundboks and Devialet.
