Denon PMA-50 Lifestyle Stereo Amplifier
Denon PMA-50
Denon today announced a $600 stereo amplifier for serious hi-fi listeners looking for a compact and high quality design that meets their lifestyle. The new PMA-50 Stereo Amplifier features next generation music playback options by offering a unique range of digital inputs, including optical, coaxial, USB-B, and even wireless Bluetooth connectivity.
The PMA-50 features Denon’s original sound technologies such as Advanced AL32 Processing and DAC Master Clock design developed for premium Hi-Fi components, to dramatically enhance the music listening experience. The amplifier section incorporates DDFA technology from CSR. The output stage circuit has a discrete construction, which realizes higher signal-to-noise-ratio, and lower distortion compared to conventional class D amplifiers. This advanced amplifier system delivers superior audio fidelity along with high amplifier efficiency at 50-watts into 4 ohms. A subwoofer pre-out is at hand for adding even more bass to the sound.
There are multiple digital inputs (2 optical and 1 coaxial) for compatibility with digital audio sources, along with an analog stereo input for legacy analog sources. And notably, music lovers can enjoy superior audio fidelity with the latest high-resolution audio sources thanks to a USB-B connection to a PC or Mac to play high-res PCM and DSD audio tracks. PCM tracks up to 24-bits/192-kHz and 2.8MHz and 5.6MHz DSD tracks are supported. To eliminate PC-induced digital noise via the USB input, the PMA-50 features a dedicated noise isolation block prior to the digital amplifier.
Denon PMA-50 back
Moreover, favorite audio tracks can be played from portable devices via the PMA-50’s Bluetooth connectivity, which features quick and easy pairing via the Bluetooth button on the front panel. For even faster pairing, the PMA-50 features NFC (Near Field Communication). By activating an NFC-enabled Bluetooth device and placing it next to the N mark on the PMA-50 (located on the side panel), it’s instantly paired with no need for manual passcode entry. For CD-quality audio playback, the PMA-50 features the latest generation CSR aptX Low Latency decoding, which provides optimum time synchronization when playing back audio from video sources with no lip sync issues.
The PMA-50 is equipped with a dedicated headphone amplifier circuit that features a high speed ultra-low distortion wideband op amp that’s paired with a fully discrete final output stage. In order to accommodate the widest range of headphone types, the PMA-50 features an adjustable headphone impedance control, with three settings for low, medium, and high impedance headphones. These provide proper matching of headphone impedance and amplifier gain.
The stylish and elegant compact chassis features deluxe finishes including soft aluminum matte with bright silver tone accents and glossy and matte black surfaces. It is sized to fit just about anywhere, including home and office desktops, home studios, and it can be positioned horizontally as well as vertically. Removable feet and screw caps make re-configuring a breeze. For total convenience, the supplied remote control features an ergonomically-designed layout that includes a cursor keypad, source select and volume controls, setup menu and back buttons, a Bluetooth button and a display dimmer button.
Price and Availability
The Denon PMA-50 is expected to be available January 2015 in black/silver for $599.
Features
  • 50-watt into 4 ohms full digital power amplifier for powerful and detailed sound
  • Advanced AL32 Processing and DAC Master Clock Design
  • 2x optical, coaxial and USB type B digital inputs capable of 192kHz/24bit High Resolution Audio
  • USB-B Input supports DSD 2.8MHz and 5.6MHz High Resolution Audio
  • Computer noise isolation block
  • Bluetooth built in, with aptX Low Latency and NFC
  • High quality headphone output with gain control to support a wide range of headphones
  • Subwoofer pre-out
  • Horizontal or vertical placement
  • Clear view OLED – shows input source indication – rotates automatically with horizontal or vertical positioning of unit
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Find out everything the HEOS app can do to simplify and manage a whole-home audio system with Denon and Marantz gear.
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
Cyber Monday 2025 delivers huge savings on Audioengine, Denon, SVS, Samsung and more. The best home audio and TV discounts of the year are...
Phil Jones from Harman reveals what makes Denon and Marantz A/V receivers unique to help you decide which model is right for your home...
Check out huge discounts on Bowers & Wilkins, Denon, Audioengine, Andover, Polk Audio and more for two days only.
Dirac Live Active Room Correction for select Denon and Marantz A/V Receivers and Preamp/Processors is now available for $299 extra.
