Denon Debuts PMA-1700NE Integrated Amplifier
Denon’s latest integrated amp has a built-in MM/MC phono stage for vinyl playback, plus digital decoding of DSD and hi-res audio, but not MQA.
Denon PMA-1700NE Integrated Amplifier Silver
Integrated amplifiers provide source input connectivity and switching, varying degrees of audio decoding or processing, and provide power for running speakers. However, unlike a stereo or home theater receiver, an integrated amplifier doesn’t receive AM/FM radio transmissions and is typically limited to a two-channel stereo configuration. However, if you don’t need all the AV receiver frills, then a two-channel integrated amp might be the best choice as the center of your home audio system
Denon PMA-1700NE Integrated Amplifier Silver Left Angle
PMA-1700NE
With that in mind, Denon is on hand at the High-End Munich show with two new integrated amplifiers, the PMA-1700NE (70W x 2) and less expensive PMA-900HNE (50W x 2). The one spotlighted in this article is the PMA-1700NE.
The PMA-1700NE is the successor to the PMA-1600NE and the PMA-900HNE is the successor to the PMA-800NE.
Core Features
According to Denon, the  PMA-1700NE incorporates a vibration-resistant design featuring a six-block chassis configuration and direct mechanical ground. Gold-plated speaker terminals and analog source inputs aid in providing solid connectivity and prevent corrosion with long-term use.
Denon PMA-1700NE Integrated Amplifier Top Front Open
Amplifier Type: UHC (Ultra High Current)-MOS Singled Ended Push-Pull
Power Output: 70 watts x 2 (8 ohms, 20hz to 20khz, .07% THD), 140 watts x 2 (4 ohms, 1 khz, .7% THD)
Audio Processing (Advanced AL32 Processing Plus): This feature supports high-resolution 384khz/32-bit input signals as well as provides the best possible sound quality from any source via its signal restoring algorithms.
USB DAC: This feature ensures optimum quality from digital audio sources coming in through the USB port, including suppressing jitter and additionally optimizing digital-to-analog conversion.
Digital Isolator: This feature helps to reduce digital noise from USB and Digital Optical/Coaxial connected sources.
TV Audio Standby: This feature enables the PMA-1700NE to detect an incoming digital signal source (such as from the digital optical feed from a TV) and automatically turn the amplifier on.
Source Direct: This feature allows you to optimize the quality of analog audio sources by turning off unneeded digital audio input and processing features of the PMA-1700NE to eliminate any interference that may affect analog audio quality.
EQ Settings: Bass, Treble, Midrange
(A/B) Speaker Terminals: The PMA-1700NE incorporates two-channel amplification, but you can connect two sets of speakers, and switch between them, or power all four at once.
Inputs: Phono (1 – with built-in MM and MC equalizer), RCA Line In (4), Optical (2), Coaxial (1), Headphone (1 – front panel with automatic speaker shut-off).
External Preamp Input Terminals: This feature allows you to connect an external preamp and use the PM-1700NE’s power amplifier section and bypass its own preamp functions.
Remote Control and front panel controls are provided.
Denon PMA-1700NE Integrated Amplifier Silver Front with Remote Control
Pricing & Availability
The Denon PMA-1700NE Integrated Amplifier will be available in Black or Silver with an MSRP of $2,099 (USD) sometime in June 2022.
1 Comment
1 Comment
  1. ORT
    May 30, 2022 at 1:47 am
    In the real world where the fragile egos of the frAudiophilians can NOT exist, there is neither need or want for MQA, aka: “The FARCE”.
    Why did I make this post? Because the gods begged me to do so. And I have a sense of righteous indentation…”n’ sheit. Nah. I just like this PMA-1700NE and am thrilled Denon chose not to make it…Here it comes…You know I am gonna do it…”Render Fluid”. 😉
    Hope fully the world will get that one. 😉
    I am such a toad. 🙂
    ORT
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
CES 2025 has evolved from the home audio/video show it used to be in the “old days” to a showcase for advanced technology in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
