Denon DL-A110 Celebrates DL-103 & 110th Anniversary
Denon is celebrating its 110th Anniversary with a new version of the DL-103 cartridge. The Denon DL-A110 MC phono cartridge is $599.
Denon Anniversary Edition DL-A110 Moving-coil phono cartridge
Denon is 110 years old. There are few audio manufacturers who can make that claim. The Japanese manufacturer has had a lot of successful products over the past century, but the DL-103 moving coil phono cartridge wins the popularity and longevity award with room to spare. To celebrate the success of the DL-103 and its 110th Anniversary, they have introduced the Denon DL-A110 Anniversary model for $599.
Before you search online and start sending nasty emails that the stock DL-103 only retails for $300, there’s something rather unique about this run of the Denon DL-A110.
Denon DL-A110 Anniversary Edition Phono Cartridge Bottom
Denon introduced the DL-103 in 1962 for professional broadcast use, and it has proven to be of the most popular and reliable phono cartridges of its kind. The low output moving coil design (0.3mV) requires a higher mass tonearm; opening the door to used Fidelity Research, SME, or EMT arms or more expensive modern arms from Kuzma, or Jelco (which recently decided to cease production). Jazz listeners have long prized the DL-103’s tonal balance and open presentation that make both brass instruments and vocals come alive.
The DL-103 requires at least 60dB of gain to come alive; sticking a step-up transformer between the affordable DL-103 and the moving magnet input of your phono stage can be a transformative experience when everything is set-up correctly. Third party manufacturers have been offering modified DL-103 variants for the past few years at considerable expense, but our advice would be to stick with the stock model from Denon.
So what’s so special about the new Denon DL-A110?
Denon DL-A110 Anniversary Edition Phono Cartridge Top
The cartridge appears to be a stock DL-103 using copper wire that is hand-spun in the Denon Audio Works Factory in Shirakawa, Japan. Same headshell without proper markings on the pins. Exact same installation issues with a fixed headshell and the slotted sides and mounting screws. At least they’re being consistent.
What is really unique and a throwback to the original design is a new Anniversary Edition silver-graphite headshell. If you own a vintage Thorens, Yamaha, or any turntable with a removable headshell with the the bayonet fitting that originated on the Ortofon SPU in 1958 — the Denon DL-A110 might be a dream come true.
Assuming that your tonearm is a medium-high mass design.
The headshell doesn’t change anything in regard to the tracking force (2.5g) or getting the VTA exactly right; make sure that the top of the cartridge is parallel to the record surface.
Denon DL-A110 Anniversary Edition Phono Cartridge in Case
Denon DL-A110 Anniversary Edition MC phono cartridge with exclusive silver-graphite headshell and included carrying case.
The DL-A110 comes in a fancy velvet-lined box with stylus cleaning brush.
Is that worth an extra $300 over the stock DL-103?
Maybe for someone with a Yamaha YP-701 or Thorens TD-160 Super Reproduction from Vinyl Nirvana with a Jelco or SME tonearm.
If you own a fixed headshell, it really doesn’t make that much sense.
I’m about two weeks in with the DL-A110 and so far I’m hearing two differences over the stock DL-103; an uptick in detail that makes horns sound even more live, and an even better sense of pace. The cartridge is still a stock DL-103 but the graphite headshell seems to be imparting some character of its own on the sound. I have a SUT coming in about a week and will be able to try the DL-A110 with some other phono stages that I have on hand.
For more information: Denon Anniversary DL-A110 MC Phono Cartridge (denon.com)
Where to buy: $599 at Amazon | Crutchfield | Denon.com
Continue reading: Best Affordable Phono Cartridges
2 Comments
2 Comments
  1. Andy Mclachlan
    October 23, 2021 at 1:00 pm
    I HAVE THE DL-A110 VERY SATISFIED FOR THE MONEY.
    ALTHOUGH I PREFER MY HANA UMAMI 7 TIMES THE PRICE.
    • Ian White
      October 23, 2021 at 3:37 pm
      I’ve been using the Denon for a few months and I love it. It’s pretty expensive (this version) compared to a stock DL-103 but it was also much easier to setup and swap between tables.
      I do have 2 SUTs right now that are making a huge difference.
      The Hana EL is one of my favorite cartridges. I have it on another Thorens and it’s wonderful with my Croft phono preamp and a SUT.
      Ian
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ask an Expert
Are you a recent convert to vinyl playback? Are you records not sounding as great as you would have hoped? Your phono cartridge installation...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Craft Recordings Reissues Sought After 1957 Thelonious Monk Mono Mix In 180-gram Vinyl, All Analog Remastered Original Jazz Classics Series.
CES 2025 has evolved from the home audio/video show it used to be in the “old days” to a showcase for advanced technology in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
