Denon Teams With Devon Turnbull of OJAS to Reimagine the DL-103R Moving Coil Cartridge
In collaboration with Devon Turnbull, the Denon DL-103o moving coil phono cartridge contains a DL-103R in a stylish clear case.
Denon DL-103o and DL-103R Moving Coil Phono Cartridges
Denon has teamed up with Devon Turnbull of OJAS, renowned for his luxury Hi-Fi brand, to reimagine Denon’s DL-103R Flagship Moving Coil Phono Cartridge, as the DL-103o, a limited-edition cartridge which features a transparent casing that showcases its intricate circuitry.
Denon moving-coil cartridges feature a low-mass design that lets the cantilever move more easily, meticulously reproducing the subtlest details.
Heritage & Innovation
Building on the legacy of the DL-103, Denon’s original moving coil cartridge. The DL-103 was originally designed for professional broadcast use in 1962 and has remained a staple in audio technology, the current version is the DL-103R.
Denon DL-103R Moving Coil Phono Cartridge
Specifications
  • Cartridge Type: MC (Moving Coil)
  • Output Voltage: 0.25 mV (1 kHz, 50 mm/s horizontal direction)
  • Channel Balance: 1 dB max. (1 kHz)
  • Channel Separation: 25 dB min. (1 kHz)
  • Frequency Range: 20 Hz to 45 kHz
  • Electrical Impedance: 14 ohms ±20%
  • Load Impedance: 100 ohms min (40 ohms when using a transformer)
  • Stylus: 0.2 mm square solid diamond
  • Tracking Force: 25 mN ±3 mN (2.5 g ±0.3 g)
  • Compliance: 5 x 10-3 m/N (Using a 100 Hz record)
  • Weight: 8.5 g/0.3 oz
Denon DL-103o Moving Coil Phono Cartridge
DL-103o Highlights
The DL-103o’s low-mass stylus assembly boasts significant advantages over moving-magnet-type assemblies. The moving-coil assembly supports wider dynamics, clearer highs, and tighter transients.
The DL-103o’s conical tip is easy to set up and ensures optimal contact with record grooves for better tracking, reduced distortion, and enhanced depth and clarity.
Fine-gauge 99.9999% pure 6N copper wire coils are hand-wound with precision to the cantilever shaft supports more precise imaging and low-frequency response.
The low-compliance cartridge is easier to implement in a range of turntable setups, ensuring optimal sound quality and stability in every listening session — but attention needs to paid when selecting the appropriate tonearm.
Devon Turnbull’s clear casing design is visually stunning and provides a unique educational insight into the cartridge’s inner workings.
Devon Turnbull Examining Denon DL-103o Phono Cartridge on table
Devon Turnbull holding Denon DL-103o Phono Cartridge
Devon Turnbull
Devon Turnbull Partnership
Devon Turnbull has long been an advocate for high-quality audio experiences, and his collaboration with Denon underscores a mutual commitment to excellence and innovation in the audiophile community.
From Devon Trumbull: “For me, the exciting opportunity of working with the DL-103R is just being able to educate people about the way things work and why they work as well as they do…
Availability & Pricing
Related Reading
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
