Denon DA-300USB DAC and Headphone Amplifier
Denon announced the DA-300USB, their first stand-alone high-definition USB digital to analog converter (DAC) and headphone amplifier for audiophile playback of digital music files.  Equipped with a range of advanced digital technologies, the DA-300USB connects via asynchronous USB to the computer and features the ability to decode both PCM (traditional digital audio format) and DSD (Direct Stream Digital – the advanced digital audio format of SACD). The new DA-300USB DAC also boasts Denon’s advanced AL32 processing along with high-precision, 32-bit, 192-kHz digital-to-analog conversion technologies that delivers astounding sound quality.
Users simply connect the minimalist DAC via its USB-B port to receive top-quality computer audio—via headphones like the Denon Music Manic AH-D600, powered speakers or directly to their stereo system—for computer-stored music files or streaming audio over the Internet. The USB-B input allows computer-stored music files or streaming audio from Internet music, video and film services to be processed and played via the DA-300USB for the best-possible sound quality. The computer recognizes the DA-300USB as an external soundcard, and bypasses its own lower-quality audio electronics. Any digital audio format that can be played from the computer’s own media player can be processed by the DA-300USB—including MP3/MP4, AAC, ALAC, WAV and FLAC HD (up to 24 bit, 192 kHz) and DSD (the native file format for SACD; in 2.8MHz and 5.6MHz resolution).
The digital audio stream from the computer to the DA-300USB is transferred in bit-transparent, asynchronous mode to ensure a bit-perfect data stream for high-definition advanced AL32 processing and high-precision digital-to-analog conversion.
Denon’s advanced AL32 processing and high-precision 32-bit, 192-kHz digital-to-analog conversion delivers audio quality that far exceeds usual high-definition, wide-bandwidth conversion techniques. In the same way that advanced Blu-ray players can deliver full HD video from standard-definition DVD, the advanced AL32 processor up-converts and up-samples all input signals to a 32-bit, 192-kHz high-definition data stream that is interpolated, using a highly advanced proprietary algorithm, to provide a full-scale, accurate reproduction of the original sound recording.
The advanced AL32 processor is matched with a high-precision 32-bit, 192-kHz digital-to-analog conversion circuit to fully exploit the advanced AL32 high-definition processing. Quantization noise, inherent in standard-resolution digital-to-audio conversion, is rendered inaudible. Digital processing and filtering artifacts are moved beyond the range of human hearing to reproduce pure, high-quality analog output signal.
The DA-300USB is an attractively styled, ultra-compact unit. Measuring approximately 7 x 7 x 2 inches, it can be positioned either horizontally or vertically (using the supplied clip-on stand) for compatibility with any desktop audio or hi-fi system. The minimalist front panel has a power button, headphone output and volume control, a touch input selector switch, and an OLED display that shows the selected input, headphone volume and input signal resolution. Orientation of the display changes with horizontal or vertical positioning of the unit.
Denon DA-300USB DAC Back
Features
  • High-definition DAC with one USB-B, one coaxial two optical digital inputs
  • High-quality audio components for rich, open, detailed sound
  • Denon advanced AL32 processing and high-precision 32-bit, 192-kHz digital-to-analog conversion for exceptional high-definition audio quality
  • DAC master clock design for distortion-free, fully transparent sound stage
  • Noise-isolating circuit design prevents distortion via USB connection from computer-generated digital noise; ensures fully transparent and spatially accurate sound stage
  • Universal bit-transparent, asynchronous playback of digital audio file formats and streaming audio from PCs via USB-B; up to 24 bit, 192 kHz and DSD2.8 and DSD5.6 native support by DoP (DSD audio over PCM frames)
  • 3x SPDIF (coaxial/optical) inputs for upgrading sound from other digital audio devices (up to 24 bit, 192 kHz) with the DA-300USB’s advanced high-definition signal processing
  • High-quality analog signal (line level) output and headphone amplifier stage for connection to hi-fi amplifiers or desktop speaker systems and superb listening with all kinds of headphones.
  • Simple plug-and-play operation for connection to PCs and other devices with digital audio outputs
Price and Availability
The Denon DA-300USB will be available March 2014 for $499.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
CES 2025 has evolved from the home audio/video show it used to be in the “old days” to a showcase for advanced technology in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Cyber Monday 2024 deals you won't want to miss out on from SVS, RSL, THX, Technics, Creative, Denon, Samsung and more.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
Bring function, style and entertainment to any educational experience with tech that kids will absolutely love.
