Denon AVR-X3300W A/V Receiver Announced
Denon AVR-X3300W A/V Receiver with Remote
Denon today announced the mid-range AVR-X3300W 7.2-channel 4K Ultra HD Network A/V Receiver.  This model joins the recently introduced step-down AVR-X1300W and AVR-X2300W AV receivers, offering the latest future-ready features, best-in-class user interface and immersive 3D sound.
The Denon AVR-X3300W is equipped with low impedance drive capability, to provide operational stability with speakers rated at 4 ohms and the video engine offers yet another upgrade, it can upscale standard and high definition analog and digital video content up to 4k Ultra HD 50/60 Hz resolution for the ultimate viewing experience. The dual HDMI outputs support different program sources, allowing users to enjoy a surround movie in the main room and a separate stereo program with video from a different source in a second room. A 7.2ch pre-out section, an RS232 port and flexible amp assignment options further satisfy even demanding custom installers in regards to multi-zone listening and home automation.
Surround Experience
The AVR-X3300W A/V Receiver features Dolby Atmos decoding for the definitive home theater experience, especially when playing the latest blockbuster movie soundtracks. Add to that a free DTS:X update is scheduled for later in 2016 to allow the ability to drive overhead or upward-firing speakers for an incredible 3D audio experience. Users can also choose between Dolby Surround and DTS Neural: X upmixers (via update) to create 3D sound from both legacy Dolby or DTS material.
Denon AVR-X3300W A/V Receiver - Rear
Video
In terms of video, the AVR-X3300W is fully prepared for current and future high-resolution video formats. This model is compatible with the latest HDMI 2.0a and HDCP 2.2 specifications on all eight of its HDMI inputs. And it’s ready for 4K Ultra HD Blu-ray disc players, set-top boxes and other 4K Ultra HD sources with 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, High Dynamic Range (HDR), 21:9 video, 3D, and BT.2020 pass-through support on every input. The AVR-X3300W can upscale existing standard and high definition analog and digital video content to 4K Ultra HD resolution, breathing new life into favorite legacy sources.
It is certified by the Imaging Science Foundation for video quality, and equipped with the full suite of ISFccc advanced video calibration controls. A more extensive array of inputs, control options, and a second zone pre-out along with a RS232 port gives the AVR-X3300W the ability of a truly versatile AV control center.
Wireless Connectivity
To partner with the incredible sound, full wireless connectivity is attained with built-in Bluetooth for music streaming from a smartphone, and Wi-Fi easily connects to a home network. Dual antennas and dual band support guarantee a strong network signal even in Wi-Fi-crowded environments. Once connected, it opens up nearly unlimited streaming music sources and playback options, including Apple AirPlay, Internet Radio, Pandora, Spotify Connect, and SiriusXM. High Resolution audio formats like FLAC, AIFF or DSD (all the way up to 192kHz/24-bit and DSD5.6MHz) are fully supported bringing users even closer to the music. For total convenience, a front USB port can be used to connect either USB storage devices or an iDevice to playback music and charge at the same time.
Denon AVR-X3300W A/V Receiver - Front
Amplifier
The powerful amplifier section features discrete high current output devices on all channels, and all amp channels are configured identically. Rated at 105 watts (8 ohms, 0.08%THD, 20Hz~20kHz), the AVR-X3300W has the ability to drive even demanding loudspeakers, down to 4 ohm impedance, on all channels. With the AVR-X3300W’s multi-room capability, users can enjoy two different sources in different rooms at the same time for added enjoyment.
Easy Set-Up/Control/Energy Smart
The AVR-X3300W is engineered for easy set-up, control and energy efficiency. With the exclusive Denon Setup Assistant along with the Quick Start Guide, setting up this receiver is quick and easy. Room calibration with Audyssey MultEQ automatic room acoustic measurement and correction system matches the installed speakers to the individual room’s acoustics, for the smoothest, most natural tonal balance. Audyssey Dynamic Volume offers real-time volume adjustment; while Audyssey Dynamic EQ improves a system’s surround sound effects at low volume levels. Once set up, the new Denon 2016 AVR Remote App available on iOS, Android and Kindle Fire makes daily control simple and convenient. Lastly, the receiver includes a smart ECO mode that can automatically save significant electrical power without influencing the overall performance
Price and Availability
The Denon AVR-X3300W Network A/V Receiver is expected to be available in July 2016 for $999.
Features
  • 7.2 channel AV Receiver, 105W per channel at 8 ohms, 20-20kHz, 0.08%THD
  • Built-in Wi-Fi with 2.4GHz/5GHz dual band support; built-in Bluetooth
  • 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR and BT.2020
  • 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 2 HDMI outputs
  • Dolby Atmos (up to 5.1.2) and DTS:X (via firmware update)
  • AirPlay, Internet Radio, Pandora, Spotify Connect, SiriusXM, DLNA 1.5
  • DSD (2.8/5.6MHz), FLAC, ALAC, AIFF and WAV support
  • Advanced Video Processing with analogue to HDMI conversion and full rate 4K Scaling
  • Audyssey MultEQ XT32, Dynamic Volume, Dynamic EQ and SUB EQ HT
  • Advanced Multi-Room options; 7.2ch Pre-out; RS232 Control
  • Color-coded speaker terminals, Setup Assistant
  • Denon 2016 AVR Remote App
  • Intelligent ECO mode with off/on/auto setting
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
CES 2025 has evolved from the home audio/video show it used to be in the “old days” to a showcase for advanced technology in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Cyber Monday 2024 deals you won't want to miss out on from SVS, RSL, THX, Technics, Creative, Denon, Samsung and more.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
