Denon AVR-E200, E300 and E400 A/V Receivers
Denon AVR-E400 A/V Receiver
Denon Remote AppDenon today announced three new budget-priced E-Series A/V receivers, including the 7.1-channel AVR-E400 and the 5.1-channel AVR-E300 and AVR-E200. The two top models, AVR-E400 and AVR-E300, feature Apple’s AirPlay, allowing users to stream their iTunes music whether from Mac or PC, as well as music stored on their iPhone, iPad, or iPod touch. Those models also feature compatibility with the Denon Remote App, so users can control almost every aspect of their multimedia experience, including browsing Internet radio and files on a media server, playlist creation, volume, input selection, surround sound modes and menu navigation. In addition they will connect with Pandora, SiriusXM, vTuner and Spotify and can view photos via Flickr.
Denon AVR E-Series GUI SetupThe E-Series provides a new more intuitive easy-to-use Setup Assistant for simple system setup and configuration. Thanks to the vibrant on-screen graphical display, which combines large, clear text and icons, users can easily make all necessary adjustments and settings during setup, optimizing their receiver for any speaker system or source components. The exclusive Denon Setup Assistant walks users through the entire setup process (AVR-E300 & AVR-E400 Only). For total sonic accuracy, the AVR-E400 and AVR-E300 both feature Audyssey MultEQ automatic room acoustic measurement and correction system to provide the best tonal balance to any listening environment, along with Audyssey Dynamic EQ and Audyssey Dynamic Volume.
Denon AVR-E400 7.1 Network Home Theater Receiver
Denon AVR-E400 A/V Receiver - front
The new AVR-E400 7.1 Receiver exemplifies Denon’s legacy of providing powerful surround sound performance with advanced networking technology and total user flexibility. For example, users can configure the AVR-E400 for a full 7.1-channel system, or choose to have a 5.1 channel system in the main room and connect a pair of stereo speakers located in another room so others can enjoy great stereo sound from a different source! For total system connectivity, the AVR-E400 is equipped with 6 HDMI inputs including 5 on the rear panel along with 1 on the front panel, which lets users connect an HDMI-equipped camcorder, game console or other portable multimedia device.
The AVR-E400’s sophisticated video processor includes SD-to-HD up-conversion, along with 4K Ultra HD (3840×2160) for the next generation of 4K Ultra HDTVs. A hallmark of Denon’s legendary sound quality is the use of identical power amp circuitry for all channels, including an all-discrete power amplifier output stage design. Rated at a maximum of 185 watts for each of the 7 channels, the AVR-E400 provides high power and wide dynamic range with low distortion for a superb surround sound listening experience. All three E Series receivers feature this unique Denon power amp circuitry and design.
Denon AVR-E300: 5 HDMI Video Inputs with 1080p and 3D Pass-through
Denon AVR-E300 A/V Receiver - front
Denon’s new AVR-E300 receiver is rated at a maximum of 175 watts for each of its 5 channels, and is equipped with 5 HDMI inputs including 4 on the rear panel along with 1 on the front panel, which lets users quickly and easily connect your HDMI-equipped camcorder, smartphone or other portable multimedia device. Thanks to the AVR-E300’s HDMI Standby Pass-through (featured on all E-Series units), users can enjoy a program from either cable or their satellite tuner without the need to even turn the receiver on, which is ideal for casual viewing of newscasts and other programming. And with their built-in USB ports, both the AVR-E300 and AVR-E400 support digital music playback and charging from an iPod, iPhone, iPad, or USB device.
Denon AVR-E200: Entry Level 5.1 Receiver
Denon AVR-E200 A/V Receiver - front
Rated at a maximum of 165 watts for each of its 5 channels, the affordable, entry level AVR-E200 A/V Receiver delivers thrilling 5.1 channel surround, featuring the latest Dolby and DTS high definition surround sound decoding that lets users enjoy the ultimate surround sound experience with DVD and Blu-ray movies and concerts. The HDMI 5.1 Receiver also features Denon’s easy to use Quick Select function, which provides 4 Quick Select buttons on the front panel and on the remote control that let you instantly choose from the Cable/Satellite, Blu-ray, Game and Aux inputs. For total flexibility, users can customize the audio parameters for each source one with their preferred sound setting. The AVR-E200 is equipped with 4 HDMI inputs, including 3 on the rear panel and 1 on the front panel.
Denon AVR-E200 A/V Receiver - back
Denon AVR-E200
Denon AVR-E300 A/V Receiver - back
Denon AVR-E300
Denon AVR-E400 A/V Receiver - back
Denon AVR-E400
All E-Series receivers feature Denon’s new color-coded speaker terminals and supplied matching color cable tags to ensure correct speaker cable hookup right out of the box. For even more setup simplicity, Models AVR-E400 and AVR-E300 both feature Denon’s new Easy-Connects “push-in” type speaker wire connections making the sometimes difficult task of connecting speaker wires easier than ever before. The simplified remote control features discrete source selection buttons that let users choose their preferred source with the touch of one button (no need to toggle through all the inputs to get to a preferred source component).
Price and Availability
  • Denon AVR-E200 (5.1-channel) → $249
  • Denon AVR-E300 (5.1-channel) → $399
  • Denon AVR-E400 (7.1-channel) → $599
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
CES 2025 has evolved from the home audio/video show it used to be in the “old days” to a showcase for advanced technology in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Cyber Monday 2024 deals you won't want to miss out on from SVS, RSL, THX, Technics, Creative, Denon, Samsung and more.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
