Chromebooks
Dell Chromebook 11
Dell Chromebook 11
Dell just announced the Chromebook 11, an affordable and highly-portable 11.6-inch laptop with an edge-to-edge glass screen providing 1366×768 resolution, powered by Intel HD Graphics, and a front-facing 720p webcam. The Chromebook is less than one inch in height and starts at 2.9lbs, making it highly portable. The Dell Chromebook 11 features 4th Generation Intel Celeron 2955U processor, up to 10-hours of battery life and 16GB embedded Solid State Drive to facilitate a fast boot-time of under 8.4 seconds. The Dell Chromebook 11 will be available in two models, one which includes 4GB of internal DDR3 RAM, and the other which includes 2G of RAM. Additional features include two USB 3.0 ports, Bluetooth 4.0, an HDMI port, and 802.11 a/b/g/n Wi-Fi.
With the addition of the Dell Wyse PocketCloud application, Dell Chromebook 11 users have access to content and applications across a “personal cloud” of devices. Users can access, edit, save and share their digital assets such as presentations, documents, photos and videos regardless of where the original documents are located. PocketCloud works across mobile devices, tablets, PCs, laptops and Chromebooks. It is tightly integrated with the Google ecosystem and leverages the Google infrastructure effectively to authenticate, discover and access users’ content and applications. The PocketCloud app will be available for download in the Google Chrome Web Store in January 2014.
The Dell Chromebook 11 easily connects to Dell’s next generation learning technologies, infrastructure and peripherals. Additionally, with Google Cloud Print, users can easily print documents, photos or emails using Google Docs and other Chrome apps.
Price and Availability
The Dell Chromebook 11 4GB configuration will be available January 2014 for $300.
The Dell Chromebook 11 2GB configuration will be available during the first quarter of 2014.
4 Comments
4 Comments
  1. Curious
    December 12, 2013 at 9:44 am
    what does embedded 16 gd SS Hard disk mean? Is it a physical hard disk with 16 GB capacity to just boot up the Windows OS?
    • bhoundtom
      December 12, 2013 at 9:55 am
      Hi,,no windows,, os is chrome,, hope that helps
    • John
      December 12, 2013 at 1:56 pm
      It means that it’s most likely soldered onto the motherboard and not removable. It’s Chrome OS instead of Windows – very very light weight with a focus of cloud storage. Most Chromebooks come with 100GB for 2 years on Google Drive (cloud storage).
      • Dan
        December 13, 2013 at 1:33 pm
        In other words…..junk move along! Just another thing Google is trying to upset the market with and bring back junk NetBooks.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
