Definitive Technology Debuts Mythos Series On-Wall Speakers & Passive Soundbars: CEDIA 2023
The new Definitive Technology Mythos Series includes several on-wall LCR and passive soundbar speaker solutions starting at $1,199 USD.
Definitive Technology Mythos On-Wall LCR-85, LCR-75 and LCR-65 On-wall Speakers Lifestyle
In conjunction with its forthcoming Dymension CI Series in-wall and in-ceiling speakers, Definitive Technology has also revealed its forthcoming Mythos series on-wall speaker lineup.
The new Mythos speaker line includes three on-wall LCR home theater speakers and three on-wall passive soundbars.
Designed to match the sleek proportions of 65-inch, 75-inch, and 85-inch TVs from leading manufacturers, the Mythos Series achieves a seamless, minimalist look that complements any home decor.
Tip: The Mythos LCR speakers and passive soundbars adhere to VESA wall-mount specifications.
Definitive Technology Mythos Passive Soundbar Lifestyle
Features
Multi-Speaker Array: 5, 7, or 9 drivers are integrated in the specific LCR models, and 11 or 13 drivers for the 3C Passive Soundbar models
Definitive Technology Mythos LCR-85 On-wall Soundbar Front
XTDD Drivers (Xtra Thin Dynamic Dome Drivers): These drivers have a thin profile but still allow the Mythos speaker series to have the power, clarity, dynamic range, and extended response you’d expect from speakers that have more physical depth. The XTDD drivers are used for both the mid-range and woofers.
Tip: The woofers for the 3C passive soundbars also incorporate Anodized Aluminum in their construction.
Definitive Technology Mythos LCR-85 XTDD Drivers
Aluminum Oxide Dome Tweeters: This is a rigid design that supports precise high-frequency sound imaging.
Definitive Technology Mythos Aluminum Oxide Dome Tweeter
Timbre-Matched: The Mythos Series is timbre matched with both the Dymension Series tower and center-channel speakers, as well as the forthcoming Dymension CI Series.
Aircraft Grade Aluminum Cabinet: Sturdy construction in conjunction with separate acoustic chambers in the 3C passive soundbar models.
Precision Crossovers: This provides for a smooth transition between mid-bass and high frequencies.
Definitive Technology Mythos Precision Crossover
Microperforated Powercoated Steel Grills: This provides a stylish aesthetic while still providing optimum acoustic transparency.
Exterior Finish: The LCR speakers and passive soundbars come with a black anodized aluminum finish.
Weatherproof: The Mythos series features an IP66 rating. These speakers can not only be used indoors but outdoors as well. Expand your outdoor entertainment setup with better audio.
Thin Profile: Since the Mythos series is designed for on-wall placement, having a thin depth is desirable. The Mythos LCR speakers and 3C passive soundbars all feature a space-saving depth of only 1.89 inches.
Adjustable Extensions:  For better visual matching, height, and width extension is provided for a better match for LG, Samsung, and Sony TVs.
The flexibility of the Mythos series allows integrators to create customized audio setups, mixing and matching speakers based on specific project requirements. The Mythos Series blend of high-performance sound and design aesthetics makes it a perfect solution for both home entertainment spaces and light commercial installations.
Definitive Technology Mythos On-Wall Installation Example
Mythos Dimensions
LCR ModelsLCR-65LCR-75LCR 85
Tweeter1 x 1-inch1 x 1-inch 1 x 1-inch
Midrange2 x 3.5-inch2 x 3.5-inch
Woofer4 x 3.5-inches4 x 3.5-inch6 x 3.5-inch
Frequency Response (-3dB)120 Hz to 20 kHz120 Hz to 20 kHz120 Hz to 20 kHz
Impedance4 ohms (8 ohms compatible)4 ohms (8 ohms compatible)4 ohms (8 ohms compatible)
Sensitivity (2.83v/1m)88dB88dB88dB
Recommend Amp Power60 watts60 watts60 watts
Dimensions32.6 x 6.25 x 1.89-inches37.7 x 6.25 x 1.89-inches41.8 x 6.25 x 1.89-inches
Weight10 lbs12 lbs14 lbs
Definitive Technology Mythos LCR-85 Speaker Grill On/Off
3C Passive Soundbar Models3C-653C-75 3C-85
Tweeter (Center Channel)1 x 1-inch1 x 1-inch1 x 1-inch
Tweeter (L/R Channels)2 x 1-inch2 x 1-inch2 x 1-inch
Midrange (Center Channel)2 x 3.5-inch2 x 3.5-inch
Midrange (L/R Channels)2 x 3.5-inch
Woofer (Center Channel)4 x 3.5-inch4 x 3.5-inch4  x 3.5-inch
Woofer (L/R Channels)4 x 3.5-inch4 x 3.5-inch4 x 3.5-inch
Frequency Response (-3dB)120Hz to 20kHz 120Hz to 20kHz120Hz to 20kHz
Sensitivity (2.83v/1m)88 dB88 dB88 dB
Recommend Amp Power80 watts80 watts80 watts
Dimensions (WHD)56.5 x 6.25 x 1.89-inches65.8 x 6.25 x 1.89-inches72.8 x 6.25 x 1.89-inches
Weight22 lbs20 lbs17 lbs
Pricing and Availablity
  • LCR-65 (best for 65-inch TVs): $1,199
  • LCR-75 (best for 75-inch TVs): $1,499
  • LCR-85 (best for 85-inch TVs): $1,799
  • 3C-65 (best for 65-inch TVs): $1,399
  • 3C-75 (best for 75-inch TVs): $1,999
  • 3C-85 (best for 85-inch TVs): $2,399
The Definitive Technology Mythos Series on-wall LCR and Passive Soundbar speakers are scheduled to become available in October 2023 at Definitive Technology.com or authorized dealers and installers
Tip: CEDIA 2023 attendees will be able to see and hear them at Booth #3012 from September 7-9.
Related: See more coverage from CEDIA Expo 2023
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced from $2,250 to $7,000 per pair, Monitor Audio's Gold Series 6G loudspeakers include six models for stereo or home theater setups.
Denon's latest A/V Receiver offers 11.4 channels of amplification and 13.4 channels of audio processing as an AV preamp. Coming early 2024.
In-Wall Speakers
At 62 lbs per speaker you'll need some serious muscle to get Alida CSC mounted to your wall or ceiling.
Hi-Fi Components
In this episode eCoustics team members talk about their favorite moments from their hi-fi journeys this year.
In-Wall Speakers
Revel introduces its flagship PerformaBe in-wall speaker line priced from $1,500 to $3,500 each.
The all-day event will be held at CEDIA HQ in Fishers, Indiana featuring three breakout sessions exploring the benefits of executive coaching in the consumer...
Audio Cables
Modular HDMI cables designed for the rigors of custom installations with support for 8K/60Hz or 4K/120Hz at distances of up to 1,000 feet.
