In-Wall Speakers
DALI Phantom K-60 LP & M-675 In-Wall Speakers: CEDIA 2022
The DALI Phantom CI Series has expanded with two new models that will be on display next week at CEDIA 2023. Have space issues? These might work for you.
DALI Phantom M In-Wall Speakers with Custom Grille
CEDIA 2022 begins next week after the Jewish High Holidays and DALI already has some news for custom integrators looking for high-end solutions for their clients. The Danish loudspeaker manufacturer is now represented by Lenbrook Americas and they have some major updates to the the DALI Phantom Series being unveiled in Dallas. The new Phantom K-60 LP and Phantom M-675 represent an expansion of the comprehensive range of DALI CI loudspeakers, providing both high-quality sound performance and ease of installation.
Both loudspeaker systems are designed and engineered by DALI in Denmark.
DALI’s new partnership with Lenbrook has been paying dividends with the brand expanding into a much wider range of retailers across North America. We recently sat down with DALI to discuss their new expansion and growing range of products.
DALI Phantom K60-LP In-ceiling Speakers Back
Your Problem Solver: The DALI PHANTOM K-60 LP
The DALI PHANTOM K-60 LP is an in-ceiling CI speaker that combines class-leading acoustic performance with extreme low profile dimensions. Its shallow form factor makes it a ‘problem solver’ for a myriad of installation challenges where more conventional installation speakers are sometimes limited.
Despite a depth of only 36.5 mm, the sound of the PHANTOM K-60 LP belies its size, offering an impressive acoustic performance — particularly considering its dynamic range and bass response.
The PHANTOM K-60 LP was specifically designed to help installers overcome challenging spaces. Its low-profile form factor and the shallow, innovative design of the K-60 LP can help navigate hurdles that can be caused by pipes, wires, HVAC, vapor barriers or physically shallow ceiling or wall depths. The DALI PHANTOM K-60 LP is priced at $599 USD each and will be available in October 2022.
Innovative Driver Design and Architecture
The K-60 LP features a newly designed bass/midrange driver derived from the award-winning DALI KATCH G2 wireless Bluetooth speaker. The driver and diaphragm design significantly reduces the speaker’s overall depth — without compromising structural rigidity, performance or diaphragm displacement.
This new driver architecture makes it possible for the K-60 LP to be extraordinarily slim, while retaining the superior sound quality that DALI is known for — making it an option for custom integrators dealing with space constraints.
One highly visible and key attribute to the K-60 LP’s performance is the complex 3D form of its pressed and anodized aluminum diaphragm. The selection of this material was necessary in to achieve the necessary rigidity for its low profile driver architecture, which also incorporates seven localized stiffening ribs.
These not only provide further rigidity but also provide a channel for the voice-coil lead-out wires, allowing for increased excursion.
As a direct result of its complex geometry, the bass/midrange diaphragm maintains pistonic motion, helping it to perform more efficiently than other low-profile designs on the market.
DALI Phantom M-675 In-Wall Speakers
DALI Phantom M-675
A Multi-Channel Solution: The DALI Phantom M-675
Meanwhile, the latest multi-channel CI loudspeaker solution from DALI is the PHANTOM M-675. As part of the M-Series, the M-675 is designed to impart spacious, involving sound — whether the listener is listening actively or passively.
Like its sibling the M-375, the M-675 utilizes DALI’s unique hybrid soft dome and ribbon tweeter. Also, similar to the M-250 and M-375, the M-675 is developed with multichannel applications in mind and can be mounted in either portrait or landscape orientation and equally suited to front, center or surround channel roles.
This makes it extremely flexible in almost any multi-channel listening scenario.
The PHANTOM M-675 features dual 7-inch drivers combined with four 7 inch passive radiators, and the bass/midrange drivers on the M-675 employ a voice-coil made of pure copper. ​
This helps provide a better low-frequency response and higher power handling. The M-675 — as well as all the M-Series speaker models — also incorporate DALI’s patented SMC technology, which minimizes hysteresis and distortion in their magnet systems, while making them operate more efficiently.
The DALI PHANTOM M-675 is priced at $2,999 each and will also be available in October.
For more information: dali-speakers.com
Related reading: See all of our CEDIA 2022 Coverage
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
In-Wall Speakers
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
