In-Wall Speakers
DALI Phantom M-80 A In-Ceiling Speaker and CI AMP-4750 DSP Unveiled at ISE 2025
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
DALI PHANTOM M-80 A in-ceiling speaker and PHANTOM CI AMP-4750 Amplifier
ISE (Integrated Systems Europe) 2025 begins this week in Barcelona and runs through February 7th; the show has become one of the most important for the CI industry which uses the annual event to show off the latest in TVs, architectural (in-ceiling/in-wall) speakers and other components to distributors and retailers in the E.U.
DALI, a regular exhibitor at the show, is on hand to demonstrate two additions to its Custom Install product line; the PHANTOM M-80 A in-ceiling speaker, alongside the new PHANTOM CI AMP-4750 DSP 4-Channel Amp.
From Michael Munch, CI Business Development Manager at DALIThe PHANTOM M-80 A expands the PHANTOM series and offers more options for discreet in-ceiling installations. The DALI M-80 A offers movie fans a wide range of immersive surround sound possibilities when combined with the existing PHANTOM range. The PHANTOM CI AMP 4750 DSP is a powerful and smart 4-channel DSP amplifier which can be the heart of a home theatre system but can also be used with traditional DALI hi-fi speakers which offers great flexibility.”
DALI PHANTOM M-80 A
The PHANTOM M-80 A is an in-ceiling speaker that combines the DALI electro-acoustic design with angled directional dispersion to provide high-end performance where in-ceiling speakers may be the choice of installation. It is suitable for both stereo and home theater installations.
The PHANTOM M-80 A incorporates a 7-inch bass/midrange driver, angled at 25°, to provide sound dispersion that can be beamed in one direction if desired. This beaming capability enables optimum dispersion for specific audio installations needed to maximize sound quality at the listening position. The M-80 A also features compass-style direction indicators further to configure dispersion to suit the installation.
DALI PHANTOM M-80 A in-ceiling speaker tweeter
Specifications
Model DALI PHANTOM M-80 A
Price (Each)US: $1,100
EU: €799
UK: £699
Product TypeIn-Ceiling Speaker
Frequency Range (+/- 3dB)48 – 27,000 Hz
Nominal Impedance6 ohms
Maximum SPL106dB
Crossover Principle2-way
Crossover Frequency2,500 Hz
Recommended Amplifier Power50 to 200 watts
High-Frequency Driver (Tweeter)1 x 28mm (soft dome)
High-Frequency Diaphragm (Tweeter)Soft woven fabric
Low/Mid Frequency Driver (Mid-Woofer)1 x 7-inches
Low/Mid Frequency Diaphragm (Mid-Woofer)Wood fiber cone
Connection InputSingle Wire
Enclosure TypeOpen Back
Installation LocationIn-Ceiling
Recommended PlacementLCR or Surround
Outer Dimensions Including Grill289 x 138.5 mm
(11.38 x 5.46 inches)
Outer Dimensions Excluding Grill278 x 138 mm
(10.84 x 5.44 inches)
Cut-out Dimensions281 mm
(10.28 inches)
Mounting Depth134 mm
(5.28 inches)
Recommended Rear Volume25 liters (Phantom Universal Backbox)
Ceiling/Wall Thickness (total dog-leg span)5 – 52 mm
(2 – 2.05 inches)
Weight (including Grill)2.8 kg
(6.16 lbs)
FinishWhite
Included  AccessoriesManual
Cut-out Template
Front Grill
Optional AccessoriesClassic Square and Design Grills,
Phantom Universal 26 Backbox
Pre-Construction Kit
DALI PHANTOM CI AMP-4750 Front Angle
DALI PHANTOM CI AMP-4750 DSP
The DALI PHANTOM CI AMP-4750 DSP amplifier is designed to provide high-performance and configurable audio power amplification for all DALI PHANTOM custom-install loudspeakers and subwoofers.
The AMP-4750 DSP is a full rack width, 2U format four-channel power amplifier rated at 750 Watts per channel (2 pr 4 ohm single-ended connectivity).
AMP-4750 can be used with both traditional speaker impedances as well as 70V and 100V speaker systems, making it suitable to power both indoor and outdoor speakers.
DALI PHANTOM CI AMP-4750 Rear Connections
The AMP-4750 DSP provides four analog inputs and one stereo S/PDIF digital input. In addition to speaker connectivity, the amp also has both digital and analog audio outputs.
The AMP-4750 DSP is configurable via the DALI PHANTOM CI AMP CONFIGURATOR and with specific presets designed for individual DALI loudspeaker models.
Access to the AMP CONFIGURATOR interface is possible through a wired or wireless network connection to the AMP-4750 DSP, either directly from a smartphone or laptop or via a network router or switch.
DALI App
Specifications
Model DALI PHANTOM CI AMP-4750
Price EU: €4199
UK: £3999 (US pricing forthcoming)
Product Type4-Channel DSP Amplifier
Amplifier TypeUMAC Class D – Full Bandwidth PWM Modulators with Ultra Low Distortion
Frequency Range (+/- 0.5 dB, 8 Ohms, 3db below rated power)12Hz to 20kHz
Connections (Inputs)4 x Analog unbalanced (RCA),
4 x analog-balanced Euroblock connector,
1 x S/PDIF(RCA)
Input Impedance10 kOhms
Output Channels 4 x Lo-Z Loudspeaker (4 to 16 ohms),
2 x Hi-Z Loudspeaker (70V and 100V),
1 x S/PIF digital out (RCA)
Maximum Loudspeaker cable cross-section2.5mm/AWG 14 (Euroblock Standard)
Output Power @ 2 ohms4 x 750 Watts (Single Ended)
Output Power @ 4 ohms4 x 750 Watts (Single Ended),
2  x 1500 Watts (BTL)
Output Power @ 8 ohms4 x 400 Watts (Single Ended),
Output Power @ 70 volts2  x 1200 Watts (BTL)
Output Power @ 100 volts2  x 1500 Watts (BTL)
Total System Power3,000 Watts
Power Consumption700 Watts
Output Voltage80 Vrms (single-ended),
160 Vrms (BTL)
Signal-to-noise ratio (SNR)>108dB (A-weighted 20Hz – 20kHz, @ 8 ohms)
THD+N<006% (20Hz to 20kHz,  @ 8 ohms, 3 dB below rated power)
Other FeaturesShort Circuit Protection
DC Protection
Under voltage Protection
Temperature Protection
Overhead Protection
Rack Mountable
Power SupplyUREC universal mains switch mode power supply with Power Factor Correction
Operating Tempurature0 – 40 degrees centigrade
Operating Voltage/FrequencyUniversal Mains 100v/240v – 50Hz/60Hz
Power Ratings1 % THD 120 VAC and 230 Vac
Standby Power Consumption< 0.5 Watts
Outer Dimensions (HWD)88 x 440 x 332 mm
(3.5 x 17.3 x 13.1 inches)
Weight7.4 kg (16.23 lbs)
Included Accessories2 x Two-channel balanced input connector
2 x Two-channel loudspeaker output connector
1 x GPIO socket connector
1 x Main power cable
4 x Adhesive Rubber Feet
2 x Rack mount ears (mounted)
Optional AccessoriesDALI CONNECT SC F2220 speaker cable,
DALI CONNECT SC F215C speaker cable
The Bottom Line
The CI category exploded during the COVID pandemic and DALI has taken advantage of the newfound interest in multi-room audio systems and in-ceiling/in-wall speakers with a rather broad range of products. The Danish manufacturer designs and builds everything in-house (including the screws that fasten drivers to their enclosures) and the market has responded rather favorably to its products which are focused on high-end performance and strong value for the money.
Price & Availability
The DALI PHANTOM M-80 A is expected to be available beginning sometime in March 2025 for $1,100 USD per speaker (EU: €799, UK: £699).
The DALI AMP-4750 DSP is expected to be available beginning sometime during March 2025 at the following price: EU: €4199, UK: £3999, (US pricing forthcoming).
Tip: Look up Authorized DALI Dealers near you. For those attending ISE, the DALI Booth will be at  2E150 – Hall 2 (“Residential and Smart Building”).
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Are the DALI KUPID just flash and color for $600—or something more?
Daily Deals
Didn't get that A/V receiver you wanted for Christmas? No worries. Onkyo's 9.2-channel TX-RZ30 just dropped to the lowest price we've seen.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Portable Bluetooth speakers are now a billion-dollar category. We break down what actually matters — sound, battery life, ruggedness, and the models worth buying.
