In-Wall Speakers
DALI Announces Phantom IW Sub S-100 and CI Amp-2500 DSP
DALI’s Phantom IW Sub S-100 and CI Amp-2500 DSP offer a streamlined powered in-wall subwoofer solution for home theater enthusiasts.
DALI Phantom SUB S-100 In-Wall Subwoofer Front and Back
Danish speaker maker, DALI, has announced a new Phantom in-wall subwoofer/amplifier combination that will be available through Lenbrook Americas to North American music listeners and home theater enthusiasts.
In-wall subwoofers have become increasingly popular in the CI category; DALI joins a growing list of brands like KEF, Monoprice, and SVS who have introduced new models in the category over the past 12 months. In-wall subwoofers save space and can be integrated into both the wall and ceiling for home theater systems.
Dali Phantom SUB S-100 and AMP-2500 DSP
The new combination consists of the Phantom IW Sub S-100 in-wall subwoofer and CI AMP-2500 DSP amplifier.
IW SUB S-100
Dali Phantom Sub S-100 Front and Rear
The DALI PHANTOM IW SUB S-100 builds on the foundation of the K-60 LP’s bass driver design. It features a 10-inch driver with an extremely stiff, custom aluminum cone and unites long throw capability with an ultra-shallow profile.
The S-100 is also the first DALI speaker to include CSS (Constant Surface Surround) technology which has been co-developed by Purifi Audio, Denmark. The technology offers a unique surround geometry of alternating positive and negative regions, keeping surround modulation to a minimum. The surround surface sound is always constant, no matter the position of the diaphragm.
The SUB S-100 subwoofer has been developed with the PHANTOM CI AMP-2500 DSP amplifier to achieve the best performance within an MDF cabinet (more on the amp in the next section)
Sub S-100 Specifications
  • Low Frequency Driver: 1 x 10-inches (long stroke)
  • Frequency Range (+/- 3 dB): 26 – 250 Hz
  • Sensitivity (2.83V/1m): 84 dB
  • Maximum SPL: 110 dB
  • Outer Dimensions with Grille (HWD): 657 x 412 x 107 mm / 25.87 x 16.22 x 4.22 inches
  • Cut-out Dimensions (HxW): 615 x 370 mm/ 24.2 x 14.5 inches
  • Mounting Depth: 102 mm/ 4.02 inches
  • Weight with Grille: 17.25 kg / 38.03 lbs
Phantom CI AMP-2500 DSP
Dali Phantom AMP-2500 DSP Front Angle View
As mentioned above, this amplifier was designed to match the needs of the S-100 subwoofer.
Featuring Class-D amplification (2 x 500 watts), the PHANTOM CI AMP-2500 DSP provides a lot of power with extremely high efficiency and ultra-low distortion.
Tip: The amplifier can also be bridged into a 1,000-watt mono amp.
With so much headroom, the CI AMP-2500 DSP is not only a great match for S-100 but other S and M-series in-wall speakers and subwoofers.
Tip: The AMP-2500 can power up to four SUB-S-100s.
The AMP-2500 supports rack mount placement and features an adaptive fan control, which keeps fan noise to a minimum. The amp also features a fully featured DSP (Digital Signal Processing) and configurator web interface. Its built-in DSP is tailored with model specific pre-sets to optimize DALI CI models, for the best possible sound experience.
Dali Phantom AMP-2500 DSP Rear View
Setting Options
The 2500 provides several setting options to fine-tune performance.
  • Crossover and Gain: Allow crossover and level adjustment for each amplifier channel output.
  • Speaker EQ: Provides Parametric equalization settings for each amplifier output.
  • Driver Alignment: Enables users to apply different delay times (if needed) for each output.
  • Polarity (Phase): 0 – 180 degrees.
  • Limiter: Adjustments to limit clipping or other issues.
  • Output Mode: Easy switching between Lo-Z, Hi-Z, and Lo-Z BTL connection setup options.
Tip: The AMP2500 also features Short Circuit, DC, Under-voltage, temperature, and Overload protection.
Dali Phantom AMP-2500 DSP Connections Close-up
Specifications
  • Frequency Range (+/- 0.5 dB, 8 Ω load, 3 dB below rated power): 12Hz – 20 kHz
  • Inputs: 4 x Analog unbalanced, RCA 4x Analog balanced (Euroblock connectors), 1x S/PDIF.
  • Outputs: 2 x Lo-Z speaker outputs (4 – 16 ohm), 1 x Hi-Z speaker (70V / 100V), 1x S/PDIF digital outputs.
  • Output Power (8 Ω): 2 x 250 W (SE), 1 x 1000 W (BTL)
  • Signal To Noise-ratio (20 – 20k Hz, 8 Ω load): >108 dB (A-weighted)
  • THD+N (Typical- 20 – 20k HZ, 8 Ω load, 3dB Below Rated Power): < 0.05 %
  • Standby Power Consumption: < 0.5 Watts
  • Outer Dimensions (HWD):  88 x 440 x 332 mm / 3.5 x 17.3 x 13.1 inches
  • Weight: 5.9 kg/ 13.0 lbs
DALI Configurator App
To make the wired or wireless setup easier, the DALI CONFIGURATOR app can manage sound zones, inputs/outputs, firmware updates, import of speaker presets, and access to professional EQ settings. Configuration takes only a few minutes and can even be set up from a smartphone.
From Krestian Pedersen, Dali Head of Product Management: “With the new in-wall sub and CI amplifier we are now able to offer a complete DALI CI HOME CINEMA solution which is an important step for us in order to deliver the ultimate experience”.
Price and Availability​ ​ ​
Available through Authorized Dali Dealers ​ ​ ​ ​​ ​ ​
Tip: For more details about DALI watch our podcast video with Brand Manager, Jason Zidle.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
In-Wall Speakers
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
At $1,750, are the DALI IO-12 wireless ANC headphones worth it? With precise sound, rich bass, clear mids, and long battery life, they come...
DALI KUPID delivers compact, high-performance Hi-Fi sound with custom drivers, dual-flare bass, and broad amp compatibility under $750.
Ultra luxury hi-fi loudspeakers, audiophile components, and a movie player you have to hear (and see) to believe.
DALI's flagship 16-inch subwoofer is a 1500-watt beast built to match its KORE and EPIKORE speakers, offering low distortion extension down to 18Hz.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
