In-Wall Speakers
DALI’s Phantom E-WR Speaker Series Will Take On The Elements: ISE 2024 Barcelona
The outdoor CI market is hot and rather wet apparently. The DALI PHANTOM E-60 and E-80 WR in-ceiling speakers will be available from March, priced at $450 and $550 respectively.
DALI Phantom E-80 WR In-ceiling Speakers in Kitchen Lifestyle
ISE 2024 has begun in Barcelona and it is very clear that the CI market is going to be a key focus going forward for a number of loudspeaker brands like DALI. New products like the DALI PHANTOM E-WR In-ceiling loudspeakers make a lot of sense and we have already seen new weatherproof models from Focal, Sonus faber, and Theory Audio Design that are designed specifically for this market.
Consumers are spending more time outdoors and that includes the migration of their multi-room audio systems into the backyard and on their decks.
The ability to withstand the elements is crucial and there has even been movement on the part of brands like Focal and Theory Audio Design to offer loudspeakers that can withstand the rigours of marine environments in coastal areas and on boats.
The DALI PHANTOM E-WR series has been designed to deliver unparalleled audio performance in environments traditionally challenging for high-fidelity sound systems — including spaces with high humidity and temperature extremes.
As a result of DALI’s CI engineering expertise, with the PHANTOM E-WR Series, DALI have delivered a product line-up that offers tailored CI solutions for both indoor and outdoor applications.
DALI Phantom E-60 WR In-ceiling Speaker with grille
Key Features
Engineered Weather Resistance: The PHANTOM E-WR Series is robustly constructed to endure temperatures from -20°C to +60°C and can handle up to 100% humidity levels. Boasting an IP65 rating — ensuring protection against indirect water spray, dust, and sand — the PHANTOM E-WR line-up is suitable for a wide range of installations — from bathrooms to patios, and more.
Advanced Driver Technology:
  • Bass/Midrange: The PHANTOM E-WR series incorporates a DALI-designed driver featuring a waterproof polypropylene cone and natural rubber surround (the E-60 WR features a 6.5-inch driver; E-80 WR an 8-inch driver). This configuration ensures minimal sound coloration, high structural rigidity, and efficient self-damping. The result is an uncoloured, natural midrange, and a deep, rich low-frequency performance.
  • Tweeter: Both the PHANTOM E-60 WR and E-80 WR adopt a 25 mm textile dome tweeter, engineered for extended high-frequency response. The tweeter is housed in a decoupled unit which is forward-mounted to prevent colouration from bass/midrange vibrations which enhances the clarity and detail of the upper frequency range.
Optimised Acoustic Design: With a 5° tilt in its drivers within the ceiling mount chassis, the PHANTOM E-WR series ensures precise acoustic dispersion directed towards the primary listening area. This innovative design not only optimises sound delivery, but also minimises driver and baffle resonance, thereby reducing distortion and further refining sound quality.
Superior Crossover Integration: The PHANTOM E-WR series employs a passive crossover network, integrated at 3.3 kHz, which has been designed with the same meticulous attention to detail as DALI’s award-winning loudspeakers. This integration ensures seamless blending of frequencies for a harmonious audio experience.
Installation Flexibility: Designed from the ground up to ensure straightforward installation, the PHANTOM E-WR series feature swing-out dogleg clamps that require no specialist tools. Additionally, it offers midrange and high-frequency level adjustments, to provide users with extensive configuration options for a host of different acoustic environments.
Enhanced Environmental Durability: The PHANTOM E-WR series incorporates numerous refinements for maximum environmental resilience. These include: a conformally coated crossover, stainless steel clamp screws, epoxy coated grille magnets, and humidity-resistant level adjustment switches.
DALI Phantom E-80 WR In-ceiling Speakers in spa lifestyle
DALI’s PHANTOM E-WR series represents a significant stride in combining environmental resilience with high-performance audio technology.
Testament to DALI’s pursuit of acoustic perfection, the PHANTOM E-60WR and E-80WR have been meticulously engineered to meet the rigorous demands of both professional installers and audiophiles.
Specifications
PHANTOM E-60 WRPHANTOM E-80 WR
MSRP$450$550
Driver6.5-inch Wide Dispersion8-inch Wide Dispersion
Tweeter25 mm Textile Dome25 mm Textile Dome
IP RatingIP65IP65
Operating Environment (Temperature)-20°C to +60°C-20°C to +60°C
Operating Environment (Humidity)≤ 100%≤ 100%
Frequency Level AdjustmentNormal (0dB), Mid+/High+ (+3dB) optionsNormal (0dB), Mid+/High+ (+3dB) options
Thermal Switch ProtectionYesYes
Tilted DriverYes (5°)Yes (5°)
Installation MethodDogleg clamp in a standard apertureDogleg clamp in a standard aperture
Paintable Magnetic GrilleYesYes
Price & Availability
The PHANTOM E-60 WR and PHANTOM E-80 WR will be available from March, priced €299/£299/$450 and €399/£399/$550 respectively.
For more information: dali-speakers.com
HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
