DALI Introduces Flagship OBERON 9 Tower Loudspeakers
DALI adds a flagship tower to its high performance OBERON Series of loudspeakers.
DALI OBERON 9 Tower Loudspeakers in walnut with and without grille
They are clearly burning the midnight oil at DALI because this is the second major new loudspeaker announcement in under 8 weeks. That’s the sign of a healthy market and manufacturer that clearly understands that consumers want more affordable high-end products. The NAD/DALI relationship is off to a very good start. DALI today announced a new flagship floorstanding loudspeaker to its highly popular OBERON Series called the OBERON 9 (US MSRP $2,499/pr). It features a dedicated 7” midrange, two long-throw 9” woofers and a 1.14″ soft dome tweeter in a true three-way design.
The OBERON 9 joins the OBERON Series as its largest loudspeaker, which include speakers for a complete home theater or smaller listening rooms. In addition, DALI’s OBERON C series wireless active speakers offers three models with built-in amplification and wireless capabilities.
  • OBERON 1 Bookshelf Speakers ($599/pr)
  • OBERON 1 C Wireless Active Bookshelf Speakers ($1,499/pr )
  • OBERON 3 Bookshelf Speakers ($899/pr)
  • OBERON 5 Tower Speakers ($1,199/pr)
  • OBERON 7 Tower Speakers ($1,499/pr)
  • OBERON 7 C Wireless Active Tower Speakers ($2,499/pr)
  • OBERON 9 Tower Speakers ($2,499/pr)
  • OBERON ON-WALL ($749/pr)
  • OBERON ON-WALL C Wireless Active On-wall Speaker ($1,798/pr)
  • OBERON VOKAL Center Speaker ($549 each)
DALI’s patented SMC (Soft Magnetic Compound) is used in the OBERON 9’s midrange/woofer magnet systems to provide improved flux linearity, reduced magnetic hysteresis and a significant reduction in harmonic distortion. These SMC benefits result in longer listening pleasure, and excellent low-level detail.
DALI OBERON 9 Floorstanding Loudspeakers See Through
The OBERON 9’s enclosure is designed to optimise rigidity and minimise panel resonance while providing an excellent foundation for the drivers. The OBERON 9 woofer/midrange driver cones are made from a mix of paper and wood fibre that provide a stiff, lightweight and well-behaved structure that reproduces micro details with high accuracy.
The pair of 9″ drivers have a combined membrane area that is 12% larger than a 12″ woofer. This allows a higher maximum sound pressure level, which leads to an effortless reproduction of the dynamics in the music. The OBERON 9 is coupled with a new larger soft dome tweeter.
The oversized 29mm soft dome membrane uses an ultra-lightweight weave fabric and is optimised for a larger bandwidth in its lower frequency area. This ensures the optimal handover from the midrange woofer to the tweeter, creating a well-balanced, coherent upper midrange. Compared to most soft dome tweeters on the market, the DALI dome material is less than half the weight (0.060 mg/mm2).
DALI OBERON 9 Tower Loudspeakers in walnut front and back
The large but elegant cabinet delivers exceptional deep bass and large room performance. However, this speaker is surprisingly delicate and will impress with its ability to render any music or movie soundtrack naturally and lifelike even at lower volumes.
The driver materials, crossover design and geometry used in the OBERON 9 has been selected to achieve a wide dispersion pattern. This ensures a well-integrated sound, even when listening at a significant off-axis angle. An added benefit is seriously reduced harmonic distortion and diffractions causing frequency distortion.
DALI OBERON 9 claims to offer exceptional performance for music and movie lovers alike while its wide dispersion pattern makes placement much easier than with rival speakers. With its distinctive Danish design, the OBERON 9 features an elegant aluminium base to reduce resonance.
DALI OBERON 9 Tower Loudspeakers in black and walnut without grille
Price & Availability
DALI OBERON 9 loudspeakers will be available late March 2021 in Black Ash and Dark Walnut finishes for $2,499/pair.
OBERON Towers Compared
ProductOBERON 9OBERON 7OBERON 5
Frequency Range (+/-3 dB) [Hz]35 – 26,00036 – 26,00039 – 26,000
Sensitivity (2,83 V/1 m) [dB]90.588.588
Nominal Impedance [ohms]466
Maximum SPL [dB]113110108
Recommended Amplifier Power [W]50 – 40030 – 18030 – 150
Crossover Frequency [Hz]780/3,4002,3002,400
Crossover Principle test3-way2-way2-way
High frequency driver, Quantity1 x 29 mm1 x 29 mm1 x 29 mm
High frequency driver, Diaphragm typeSoft Textile DomeSoft Textile DomeSoft Textile Dome
Midrange driver, Quantity1 x 7″
Midrange driver, Diaphragm typeWood Fibre Cone
Low frequency driver, Quantity2 X 9″2 X 7″2 X 5.25″
Low frequency driver, Diaphragm typeWood Fibre ConeWood Fibre ConeWood Fibre Cone
Enclosure typeBass ReflexBass ReflexBass Reflex
Bass Reflex Tuning Frequency [Hz]3139.543
Connection InputSingle WireSingle WireSingle Wire
Magnetic ShieldingNoneNoneNone
Recommended PlacementFloorFloorFloor
Recommended Distance From Wall [cm]20 – 8020 – 8015 – 80
Dimensions With Base (HxWxD) [mm]1172 x 260 x 4061015 x 200 x 340830 x 162 x 283
Weight [kg]37.114.810.8
Accessories IncludedManual Rubber Feet Spikes Front GrilleManual Rubber Feet Spikes Front GrilleManual Rubber Feet Spikes Front Grille
About DALI
DALI, (Danish Audiophile Loudspeaker Industries), was established in 1983, and grew out of Scandinavia’s leading audio retail chain. Now distributed in 65 countries, and with more than 35 years of experience and global recognition, DALI holds unwavering dedication to sound that has advanced the state of the art, inspiring music and cinema lovers and challenging the competition to catch up. DALI is driven by raw passion for music and an honest reproduction in the domestic environment. Continuous development and refinement of new technologies remains core to DALI’s quest to create the best loudspeakers in the world. For more information, visit DALI-SPEAKERS.com
About Lenbrook
The Lenbrook Group of Companies is a privately held Canadian corporation who are the owners of NAD Electronics, PSB Speakers, Bluesound and Bluesound Professional. Formed in 1978, Lenbrook initially was a national distributor of electronics and communications products in Canada and has grown to become a leading global supplier to over 80 countries around the world.
Lenbrook Americas, a wholly owned subsidiary of Lenbrook International, is responsible for the sales and marketing of NAD Electronics, PSB Speakers, Bluesound and DALI in both the U.S. and Canada. Additionally, it also distributes Tivoli Audio and Master & Dynamic in Canada.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Craft Recordings Reissues Sought After 1957 Thelonious Monk Mono Mix In 180-gram Vinyl, All Analog Remastered Original Jazz Classics Series.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
