DALI’s KORE Flagship Loudspeakers Will Run You $120,000: That’s A lot of Herring
The $120,000 DALI KORE Loudspeakers are a state-of-the-art assault on your ears and wallet.
DALI KORE Flagship Floorstanding Loudspeakers
6,179 plates of herring in Copenhagen to be precise.
Bang & Olufsen raised a few eyebrows with the release of the $115,000 BeoLab 90 loudspeakers — but the DALI KORE at $120,000 USD are more likely to pass the proverbial smell test. That’s not a fish joke. Maybe it is.
2024 Update: The DALI KORE’s original launch price in 2022 was $110,000 USD. The price has been changed within the article to reflect the current retail price.
The Danish manufacturer is widely respected in Europe and Asia and it might shock some audiophiles to learn that DALI is the second largest manufacturer of loudspeaker cabinets in the world. Klipsch still holds that title.
Their audiophile loudspeaker line ranges from $500 to $25,000 pair, so its rather shocking to see the company throw the kitchen sink into a state-of-the-art loudspeaker.
Lenbrook Americas, a distributor of high-performance and high-value audio components, is showing the DALI KORE flagship speakers at the 2022 Toronto AudioFest. Attendees are the first in North America to hear the DALI KORE.
Tip: Toronto Audio Fest Program
DALI KORE Loudspeaker With and Without Grille
A Little Background
DALI first announced the KORE in September 2022, and represents what can be developed when no limits are placed on the product team. The acoustic engineering and industrial design enunciate subtle musical detail, rich dynamics, and lifelike imaging that is unexpected. The KORE is assembed in Nørager, Denmark.
According to Lars Worre, CEO of DALI: “There is so much to be proud of in this speaker…We set out to test the limits of what our product team could do, and the process was utterly revealing in that not only could we see all that was possible, but it also told us where we needed partnerships to realize our ambitions.
Core Features (not a pun!)
The KORE incorporates two 11-inch woofers and a 7-inch mid-range driver, produced with the brand’s signature wood fibre cones and honeycomb sandwich paper-pulp diaphragm. This is designed to balance stiffness with nuanced movement for optimal frequency and dynamic response.
High frequencies are handled by an all-new EVO-K hybrid 35mm dome and soft fabric ribbon tweeter, tuned to deliver the high-frequency octaves between 15 and 30kHz with the dome tweeter elegantly crossing over to the midrange driver.
The drivers are controlled by a patented dual voice coil design with next-generation SMC (Soft Magnetic Compound) material that prevents electromagnetic forces from interfering with the circuitry that precisely regulates coil movements.
DALI KORE Loudspeaker Cut through
In addition to its sonic quality, DALI has also made sure that the KORE’s design is visually pleasing. The KORE comes with an Ammara Ebony finish, featuring elegant golden veining through a rich and warm ebony wood.
The cabinet features 17 layers of birch wood veneer, with each layer oriented so the wood grain is perpendicular to the one below it. The layers are adhered together by a glossy lacquer that creates a very stiff and low-resonance cabinet that can withstand the daily wear and tear of residential furniture.
The KORE’s cabinet is further reinforced with a 34 kg concrete base, a die-cast aluminum mid-range and tweeter baffle assembly, and strategically placed woofers. The KORE features optimized horizontal and vertical dispersion without distortion from standing waves or crosstalk.
From Krestian Pedersen, DALI Head of Product Management: “DALI KORE is the culmination of everything we have learned about speaker design and manufacture since 198…Each pair takes us a week to produce, with a combination of hand-crafted care and precision tools, and none leave our premises without thorough testing for what we hope is life-long musical enjoyment.
DALI KORE Loudspeaker Parts Exploded
DALI KORE Specifications
Frequency Range
(+/- 3 dB)
26 Hz – 34 kHz
Sensitivity88 dB @ 2.83 volts
Nominal Impedance4 Ohm
Minimum Impedance3.2 Ohm @ 72 Hz
Recommended Amplifier Power50 – 1,000 watts
Maximum SPL118 dB
Bass Drivers2 × 11-1⁄2 inch Balanced Drive SMC
Midrange Driver7 inch Balanced Drive SMC
Hybrid High Frequency Driver35 mm (1.4″) soſt textile dome
Hybrid Super High Frequency Driver10 × 55 mm (2.2″) ribbon
Crossover Frequencies390/2,100/12,000 Hz
Low Frequency Enclosure Type2 × 72 litre reflex loaded
Reflex Tuning Frequency22 Hz
Midrange Frequency Enclosure TypeAenuated open back line
Enclosure ConstructionCurved 28 mm birch laminate composite with aluminium die-cast, thermoset resin and cast composite structural elements
Enclosure FinishesGloss Lacquer Ammara Ebony veneer with contrasting textured finishes
ConnectionsCustom designed, machined and gold-plated terminals suitable for bare wires, spade terminals and 4 mm plugs. Bi-wire/Bi-amp capable
Dimensions
(H × W × D)
1,675 x 448 x 593 mm
(66 × 17.6 × 23.3 inches)
Weight148 kg
(326 lbs)
Shipping Dimensions
(H × W × D)
1,950 × 800 × 1,200 mm
(76.7 × 31.4 × 47.2 inches)
Shipping Weight246 kg
(542 lbs)
According to Jason Zidle, DALI Brand Manager Lenbrook Americas: “While the brand has wide acclaim in other parts of the world, it is our hope that DALI KORE makes a gutsy statement for the brand in Canada and the United States…Combined with the artisanal nature of their production, only retailers who are capable of reinforcing the exceptional level of design and manufacture that DALI KORE represents will be allowed to carry the product.
Availability and Pricing
DALI KORE will begin arriving at very select North American dealers in November 2022, starting with Soundlux in Miami, FL, and followed by Simply Stereo in Chicago, IL, and Origin HiFi in Austin, TX, in early 2023 for an expected launch price of $110,000 USD.
As of 2024, the current retail price is $120,000 a pair (USD).
DALI KORE Loudspeaker Base
10 Comments
10 Comments
  1. ORT
    October 21, 2022 at 3:20 am
    Beautiful.
    “…Only God creates. The rest of us just copy.”- Michelangelo
    Mayhap these were inspired by the Pillars of Heaven itself that hold upright the famed pearly gates?
    At least we know the dark monolith of “2001 A Space Odyssey” had nothing to do with them…Those were surrounded by the simian-like precursors of the modern frAudiophile. Not music enthusiasts by any stretch of the imagination and one shudders to think of what the majestic soundtrack to that film might be if Hollyweird ever becomes so desperate (and it will) as to remake.
    In the wonderful musical, “My Fair Lady”, What does Eliza sing? “Wouldn’t it…Be loverly”?
    Ugh…One imagines that today they would give that musical masterpiece a form and title steeped in their own inimitable style and seeking inspiration in the original title of the play call it, “Pigmaleon”. The children will have to pause and seek adult guidance on that one as its meaning is twofold, LOL!
    My lack of that kind of money denies me from ever owning such a pair of beautiful speakers, but my upbringing prevents me from disparaging any that can and do.
    Loverly indeed.
    ORT
    Please pardon any and all errors these past two or so days as I am not yet even close to being close to “me” but they are working on it. 😉 And my thanks to Mr. Silva for the article!
  2. Guy H.
    October 22, 2022 at 4:11 pm
    110k for carpenters work, absorb!
    Compare this piece to a speakers like the Magico S7, we’re Science meets sophisticated material and exemplary production, costing closer to half the price of the Kora and you can understand something is wrong.
  3. Mark Shaheen
    October 23, 2022 at 1:52 pm
    Price in Europe is 88k Euros or $85,000. Once again Dali wholesaler is marking them up by a wide margin.
  4. Tim
    October 23, 2022 at 11:20 pm
    Your kidding right?
    I guess with this new , insane inflation…. makes sense.
    • Ian White
      October 23, 2022 at 11:37 pm
      Tim,
      There are at least 20 loudspeakers I can think of (off the top of my head) that are over $100,000. I’ve heard a few over $200,000 and none of them impressed me.
      DALI isn’t unique here, but I’m surprised that they went down this road.
      PSB has resisted and I highly doubt Paul Barton will do that.
      It’s not inflation. It’s the desire to sell 10 of these to people who will show them off to their friends.
      IW
      • Tim
        October 24, 2022 at 4:17 pm
        Ian,
        Couldn’t agree more …
        They lost me when I first read about the $15k Koetsu cart and the $95k Walker TT back then.
        JMHO but these prices are in spooky territory now !
  5. Adina Hirschmann
    October 24, 2022 at 10:47 am
    IMHO, they resemble outdoor waste receptacles, leak excess noise through the rear and vibrate the floor , that could disturb the neighbors and void your lease.
    • Ian White
      October 24, 2022 at 12:58 pm
      Adina,
      That’s one way of looking at it.
      What kind of jazz do you love?
      Ian White
  6. John P
    October 29, 2022 at 7:53 am
    If I had that much herring I would gladly swap it for speakers. I would swap it for practically anything that wasn’t herring.
    • Ian White
      October 29, 2022 at 3:08 pm
      John,
      A plate of herring in Copenhagen is $17 USD. The price might be going up on the speakers. Already.
      Ian White
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Craft Recordings Reissues Sought After 1957 Thelonious Monk Mono Mix In 180-gram Vinyl, All Analog Remastered Original Jazz Classics Series.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Podcasts
Rune Skov, Gryphon Audio Designs' Global Sales Director joins us on the podcast from Denmark to discuss the brand's Nordic Noir ethos.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
