CES 2022: DALI KATCH G2 Portable Bluetooth Speaker
The DALI KATCH G2 portable Bluetooth Speaker has been unveiled at CES 2022 and we are very excited to review this in February.
DALI KATCH G2 Portable Bluetooth Speaker in Chilly Blue Lifestyle
2021 saw the emergence of some heavy hitters in the portable Bluetooth speaker category; the Sonos Roam and Bang & Olufsen Beosound A1 that we just reviewed before Christmas. As Bluetooth technology improves, the sound quality of these loudspeakers is getting better with each new product cycle. One of the more understated portable Bluetooth loudspeakers was the original DALI KATCH and even though it delivered excellent sound quality — it got lost in the shuffle.
CES 2022 is underway and we’ve already secured the new DALI KATCH G2 Portable Bluetooth Speaker for review in February.
DALI is now distributed by Lenbrook Americas and that raises the stakes for this particular portable Bluetooth loudspeaker. Lenbrook is the parent company of NAD, PSB, and Bluesound and delivers far greater access to retail opportunities for this new speaker going forward.
DALI manufactures excellent loudspeakers and while it is more popular abroad than in N. America — we suspect that’s going to change in 2022 and beyond.
I’ve seen both the Roam and Beosound A1 in my local Verizon dealer and I confirmed with the manager (not a huge market sample but anecdotal evidence) that both sell really well. The DALI is more expensive than either speaker but we suspect it’s going to do quite well.
DALI KATCH G2 Portable Bluetooth Speaker in Iron Black Lifestyle
The KATCH G2 features DALI’s stylish Danish design and renowned build quality and is proof listeners should not compromise on sound quality or design when choosing a Bluetooth portable speaker.  “Since its launch, the KATCH has been a runaway success”, says Jason Zidle, Lenbrook Americas’ new DALI Brand Manager. “It’s only natural that we improve upon the KATCH. With its exceptional sound, contemporary colors, and elegant design, the KATCH G2 is the ultimate portable package, offering a true DALI sound experience.”
Sound Construction
The aluminum body of the compact and portable DALI KATCH G2 has enough inner volume for its dual woofers to deliver a considerable amount of low-end punch. The sound from the DALI KATCH G2 is rendered by a 2-Way stereo speaker system with a larger passive membrane supporting the woofer in the otherwise closed cabinet. In contrast to the original KATCH, the DALI KATCH G2 cabinet now has an internal wall dividing it into two inner volumes, creating improved channel separation.
By placing a full set of drivers on both sides of the DALI KATCH G2, an almost perfectly omnidirectional dispersion pattern is created. True to DALI heritage, this creates an immense prime listening area whether used indoors or outdoors. This effect is further enhanced by the internal wall dividing it into two inner volumes, for improved channel separation. Clear and Warm EQ settings permit tailoring the performance to personal tastes, with Warm adding to the bass presence.
Connection Made Easy
The KATCH G2 incorporates Bluetooth 5.0 and higher audio quality with Qualcomm aptX, aptX-HD, and AAC. The upgraded Bluetooth allows for a stronger connection with less dropouts, so listeners can be further away for the device with continued easy listening. The devices can connect using the traditional Bluetooth method, or through using NFC (near-field connection).
KATCH G2 in Iron Black
The DALI KATCH G2 is equipped with a 3.5mm stereo mini-jack input, making it easy to connect a non-Bluetooth device. The mini-jack input is auto-sensing, eliminating the need for an additional button to play music. Pressing the Bluetooth button with the mini-jack connected allows listeners to toggle between the mini-jack input and Bluetooth. Directly next to the mini-jack input is a USB charge connector and a power connector. The USB charge connector not only allows for charging on-the-go but is also able to drive a Chromecast Audio dongle or Amazon Echo for easy home network integration.
Two make a stereo pair
Another new feature is the ability to use two DALI KATCH G2 units, paired together via Bluetooth, to form a wireless dedicated left/right stereo pair.The connection uses one DALI KATCH G2 as the primary and the other DALI KATCH G2 as a secondary unit. The TWS (true wireless stereo) mode has several advantages: Besides adding true stereo imaging, the extra drivers work together to deliver a significantly higher undistorted sound pressure level and improved bass quality and extension – perfect for parties.
The two channels are powered by Class D amplifiers of 25 watts each, and DSP (digital signal processor) straightens the frequency response to near perfection.  The DSP’s built-in DAC delivers a balanced stereo signal to the amplifier stage. This keeps the amplifier design simple, but effective, transforming up to 95% of the battery power to output power. The amplified audio signal is sent unfiltered to the woofer and via a simple crossover to the tweeter.
Under the Hood
Taking inspiration from the original DALI KATCH, the DALI KATCH G2 features solid rounded housing, with new design elements integrating a genuine leather carrying strap color matched to the front grilles, and a golden DALI coin logo affixed to the top of the unit. The KATCH G2’s also has an increased battery life by 25 percent from the original KATCH. Listeners can enjoy music for up to 30 hours without recharging their device.
DALI KATCH G2 Parts Exploded
Within the sleek body are two tweeters that bring the high-end and upper mid-range to life, while a pair of woofers produce remarkably low and forceful mid-range and bass. Together, the two sets of drivers function in acoustic harmony with two oversized rectangular passive radiators to deliver a detailed, powerful, and coherent audio signal above and beyond anything heard before in a portable Bluetooth speaker.
The large surface area of the 21 mm light-weight soft dome ensures better extension into the midrange frequencies and seamless integration with the woofer in the all-important mid-range. The strong neodymium magnet delivers high power handling and high sensitivity with detailed, accurate and agile high-frequency reproduction.
The 3.5” woofer uses an aluminium membrane with a soft fabric dust cap and is housed in an unconventionally designed, ultra slim chassis to get maximum excursion into true low-frequency reproduction. The stiff aluminium cone allows the woofer to move as much air a possible even at mid-range frequencies, and the combination of aluminium and fabric works to lower surface resonances, retaining detail and clarity.
DALI KATCH G2 Portable Bluetooth Speaker in Caramel White
KATCH G2 in Caramel White
Price & Availability
The DALI KATCH G2 is available for $499.99 (US MSRP) in three contemporary colors: Caramel White, Iron Black and Chilly Blue.
For more information: KATCH G2
1 Comment
1 Comment
  1. Stuart Lindsey
    June 7, 2022 at 11:08 am
    Just purchased. Easily the best bluetooth speaker i have heard. Vocals are stunningly clear and detailed. The bass us excellent, couldn’t expect more from a cabinet this size. Expensive but, imo, worth it.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
