DALI IO-4 & IO-6 Over-ear Wireless Headphones
Custom-designed wireless headphones are available with or without Active Noise Cancellation in two colors.
DALI IO Headphones worn on model
With or Without Noise Cancelling
Lenbrook Americas today formally announced the launch of DALI IO headphones to the U.S. market. Two “over ear” models to start, the IO-6 ($499 U.S. MSRP) is an Active Noise Canceling (ANC) wireless headphone while the IO-4 ($399) offers similar features and performance without ANC. Designed for the modern music lover, both IO models deliver remarkable sound quality utilizing a large 50mm driver with Neodymium magnet in a closed-back design. Bluetooth 5.0, AAC and aptX HD provide wireless freedom and convenience though either model can be used wired, if so desired.
DALI IO-4 and IO-6 Wireless Headphones
Performance
Since 1983, DALI has enjoyed a worldwide reputation for engineering excellence in loudspeakers. The company leveraged their decades of speaker expertise with the IO headphones by taking a ‘ground up’ approach in how to improve on the state of the art. Starting with a custom-designed 50mm driver, utilized in both the IO-6 and IO-4, DALI engineers chose a paper fiber diaphragm, similar to what is found in their most expensive speaker designs. They then used an optimized neodymium magnet system to achieve low distortion, minimal coloration and accurate dynamics.
DALI IO-6 Headphones in Iron Black folded
Connectivity
DALI IO headphones are designed primarily with wireless Bluetooth use in mind. For the best possible Bluetooth performance, they support the latest high-quality audio codecs: AptX, AptX HD and Apple AAC. For fast battery charging and best possible quality, DALI IO headphones use a USB-C connector which supports digital audio and allows music to be streamed in CD quality from a Windows or Mac OS computer. Use of a USB-C connectoralsoavoids the common failures with micro-USB connectorsresulting from incorrect insertion.
In addition to Bluetooth and USB connection, IO headphones also incorporate a traditional wired analog jack input located on the left ear cup. The wired input enables connection to legacy sources and in-flight entertainment systems and works when the headphones are switched either on or off. When the headphones are switched “off” they operate in a simple passive mode; none of its control functions will be operational. Use in passive mode means that a drained battery need not interrupt headphone listening.
DALI IO-4 Headphones in Caramel White
Ease of Use
DALI engineers also focused on ease of use and intuitive operation. Their design solution was to have the three main control buttons elegantly integrated into the design of the right ear cup. The logo plate is the multi-function button for controlling Play, Pause, Next, Previous, Take Call and End Call. The upper and lower part of the ear cup outer ring, which surrounds the logo plate, control Volume Up and Down respectively. To further support the user experience, the IO headphones feature voice prompts that provide feedback on the state of operation, connectivity, battery level and ANC mode (IO-6 only). On/Off, Pairing and Battery Level are also indicated visually by two multicolor LED indicators on the right ear cup.
Comfort
The best sounding headphones are less compelling if they are not comfortable to use for long periods of time. For IO models, DALI chose a circumaural (aka over ear) format which surrounds the ears and rests on the head. This maximizes comfort while reducing air leakage to retain sound. DALI then designed ear pads constructed from memory foam, where a comfortable, acoustically superior seal over the ears is guaranteed. This in turn ensures perfect sonic performance, while the soft synthetic leather finish adds maximum durability. With all headphones susceptible to bass leakage, leading to low frequency variations, DALI IO’s ear pads have been designed specifically to deliver sound with minimum bass leakage, ensuring the audio will always sound as originally intended.
DALI IO-6 Headphone functions
IO-6 with ANC
DALI IO-4 Headphone functions
IO-4 without ANC
Design Differences
While both DALI IO-6 and DALI IO-4 offer the same level of cutting-edge audio technologies for the ultimate in high-performance, the IO-6 differs from the IO-4 by incorporating active noise cancellation (ANC), to cut out any sound disturbances from the outside world as well as adding a separate, more powerful, amplification section. However, in forgoing ANC, the IO-4 is able to double its battery life to an incredible 60-hours per charge.
To complete the package, IO models are supplied with:
  • USB-C cable for charging and computer audio use, as well as
  • 3.5mm jack cable for connection to traditional audio sources and in-flight entertainment systems
  • High quality travel case to protect the headphones when not in use. (IO-6 only)
Key Features
  • 50mm Drivers, Free Edge, paper fiber cone. Designed and manufactured by DALI.
  • Optimized Neodymium magnet for high power handling
  • Wireless Connections: Bluetooth 5.0, AAC, aptX, aptX HD
  • Can be used in wired mode via 3.5mm Mini Jack stereo USB-C
  • Functions: Power ON/OFF, Bluetooth Pair, Release
  • Volume up/down, Play/pause/skip track, Take call
  • Hands-free: Clear Voice Communication (CMC)
  • Active Noise Cancelation (ANC), Transparency, ANC Off Modes (IO-6)
  • Battery: Up to 60-hours (IO-4) Up to 30 hours (IO-6)
  • Available in Caramel White or Iron Black
Price & Availability
Both IO models will be available in Iron Black or Caramel White and available to order now, with deliveries commencing in November 2019.
  • DALI IO-4 – $399
  • DALI IO-6 – $499
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Technics latest wireless headphones boast up to 60 hours of battery life and feature 8 mics for noise-cancellation whether listening to music or talking...
Bang & Olufsen's top-of-the-line luxury wireless noise cancelling headphones feature Dolby Atmos with head-tracking in a stunning new design.
Beoplay H95 are the best Bang & Olufsen wireless headphones ever built which include advanced noise cancellation and 38 hours of battery life.
At $229, the Sennheiser ACCENTUM Plus wireless headphones add touch controls, Hybrid Adaptive Noise Cancellation, a travel case and more.
The Final Audio UX3000 wireless noise cancelling headphones have raised the bar for performance at only $149.
Six new models featuring upgraded battery performance, support for Bluetooth 5.3, and Harman's advanced Personi-Fi 2.0 technology.
Shure took an already good wireless noise cancelling headphone in the AONIC 50 and improved it without raising the price or cutting corners. It’s...
