DALI Introduces EPIKORE 3, 7 and 9 Loudspeakers
DALI adds to its EPIKORE loudspeaker range with the company’s flagship stand-mount speaker and two new floorstanders.
DALI EPIKORE 3, 7, 9 Loudspeakers
Building on over 40 years of loudspeaker research and development, the Danish loudspeaker brand DALI is expanding its EPIKORE loudspeaker series with three new speakers. The new models include the EPIKORE 3 stand-mount speaker, EPIKORE 7 and EPIKORE 9 floorstanding speakers, which accompany the previously released EPIKORE 11.
About EPIKORE
The EPIKORE line sits one step below the KORE flagship loudspeaker. However, since there is no stand-mount KORE speaker, the new EPIKORE 3 earn its spot as DALI’s best stand-mount/bookshelf speaker.
All the EPIKORE speakers share some common features that include the EVO-K™ Hybrid Tweeter module, which incorporates a 35 mm soft-dome tweeter and a 55 x 10 mm HF planar element; SMC™ Gen-2 technology for minimal distortion; custom-made in-house drivers, and Clarity Cone™ paper and wood fiber cone structure bass/mid-range drivers.
Other common features include custom-made in-house drivers, titanium voice coil formers, adjustable aluminum outriggers, continuous-flare bass reflex ports, die-cast baffles, and low-resonance cabinets
To ensure that the speakers look as good as they sound DALI has implemented luxury cabinets with exclusive high-gloss finishes and custom-made high-end binding posts.
EPIKORE 3
DALI EPIKORE 3 Loudspeakers Lifestyle
DALI EPIKORE 3
This speaker features a bookshelf/standmount design that incorporates DALI KORE technology. It is a 3-way speaker that combines a low-loss, 7-inch DALI bass/midrange driver with the unique DALI EVO-K Hybrid Tweeter module. The EPIKORE 3 features a real-wood veneer stand-mount cabinet.
The optional EPIKORE STAND that is available for EPIKORE 3 is sand-fillable and includes internal cable routing for functional stability and an uncluttered appearance.
EPIKORE 7
DALI EPIKORE 7 Loudspeakers Lifestyle
DALI EPIKORE 7
This is a compact floor standing model. It features a 3½-way driver configuration that combines two low-loss 7-inch DALI bass/midrange drivers with the unique DALI EVO-K Hybrid Tweeter module. It is designed to deliver a great listening experience for medium and large-sized rooms.
EPIKORE 9
DALI EPIKORE 9 Loudspeakers Lifestyle
DALI EPIKORE 9
The is a 4-way floor standing designed to deliver a high-performance audio experience for large rooms. It incorporates two, low-loss SMC Gen-2 8-inch woofers, a low-loss SMC Gen-2 6½-inch Clarity Cone Technology midrange driver, and the unique DALI EVO-K Hybrid Tweeter module.
The advanced curved cabinet combines Continuous Flare port reflex loading with the rigidity and beauty of real wood.
EPIKORE 11
DALI EPIKORE 11 Loudspeakers Lifestyle
DALI EPIKORE 11
Previously released, the EPIKORE 11 is the top floorstanding model in the series. It incorporates a 4½-way speaker configuration with four, low-loss 8-inch SMC Gen-2 woofers, a low-loss SMC Gen-2 6½-inch Clarity Cone Technology midrange driver, and the signature DALI EVO-K Hybrid Tweeter module. The EPIKORE 11 is designed to be the best option for large-sized rooms.
Comparison
DALI EPIKORE 3, 7, 9, 11 Loudspeakers
Epikore 3Epikore 7Epikore 9Epikore 11
Price (pair)£9,999 / €9,999£19,999 / €19,000£29,999/ €29,999£39,998 / €39,998
Speaker TypeBookshelf / Stand-mountFloorstanding FloorstandingFloorstanding
Frequency Range (±3 dB)42 – 34,000 Hz 35 – 34,000 Hz 29 – 34,000 Hz 29 – 34,000 Hz
Sensitivity (@ 1 m for 2.83 V)85 dB 88 dB88 dB89 dB
Nominal impedance6 Ohm6 Ohm4 Ohm4 Ohm
Maximum SPL108 dB110 dB112 dB116 dB
Crossover frequency2,800 / 12,500 Hz800 / 2,500 / 12,500 Hz400 / 3,100 / 12,500 Hz170 / 370 / 3,100 / 12,500 Hz
Crossover Principle3-way3.5 way4-way4.5-way
Recommended Amplifier Power40 – 250 Watts40 – 400 Watts40 – 500 Watts40 – 1,000 Watts
High Frequency Driver(s)1 x 10mm × 55 mm planar magnetostatic tweeter
 1 × 35 mm soft dome
1 × 35 mm soft dome
1 × 35 mm soft dome
1 × 35 mm soft dome
High-Frequency diaphragmPlanar magnetostatic
Soft woven fabric
Soft woven fabric
Soft woven fabric
 Soft woven fabric
Low/Mid Frequency Driver(s)1 × 7 inch2 × 7 inch2 × 8 inch
1 × 6½ inch
4 × 8 inch
1 × 6½ inch
Low/Mid frequency DiaphragmClarity Cone™ paper and wood fiberClarity Cone™ paper and wood fiberClarity Cone™ paper and wood fiberClarity Cone™ paper and wood fiber
Connection input(s)Bi-wireBi-wireBi-wireBi-wire
Enclosure typeBass reflexBass reflexBass reflexBass reflex
Bass Reflex Tuning Frequency39 Hz33 Hz27 Hz24 Hz
Other featuresN/AN/AN/AN/A
Recommended PlacementStand or ShelfFloorFloorFloor
Recommended distance from the rear wall35 – 120 cm35 – 120 cm35 – 120 cm35 – 120 cm
Dimensions (HWD) 470 × 250 × 420 mm
18.5 × 9.8 × 16.5 inches
1120 × 380 × 420 mm
44.1 × 15.0 × 16.5 inches
1310 × 422 × 554 mm
51.6 × 16.6 × 21.8 inches
1602 × 422 × 554 mm
63 × 16.6 × 21.8 inches
Weight with Grille (each)22.0 kg
48.5 lbs
40.5 kg
89.3 lbs
64.0 kg
141.1 lbs
72 kg
158.7 lbs
Shipping weight (pair)51.2 kg
112.9 lbs
97.6 kg
215.2 lbs
143.0 kg
315.3 lbs
177 kg
 390.2 lbs
FinishesHigh Gloss Black (Shadow Black grille)
High Gloss Walnut (Shadow Black grille)
High Gloss Maroon (Shadow Black)
Accessories (pair)4 × Terminal jumpers
1 × Cleaning cloth
2 × Magnetic front grille
8 x Rubber Feet
8 × Magnetic spike feet
1 × Cleaning cloth
4 x Floor protection pads
1 × Cleaning cloth
1 × Cleaning cloth
Optional AccessoriesEPIKORE STANDN/AN/AN/A
Spike Thread SizeM6M12M12M12
DALI EPIKORE 3 and EPIKORE 7 Loudspeaker Front and Rear
Initial Impression
2024 continues to see a lot of high-end loudspeaker releases, but the question is “How Much Are You Willing to Pay?” in the quest to get the best possible listening experience. The DALI EPIKORE series is visually stunning in high gloss finishes and its Hybrid Tweeter module could give it an edge over competing ranges from Focal, Bowers & Wilkins and Monitor Audio among others.
However, if the new EPIKORE series is out of your budget, DALI offers several other choices, such as the RUBIKORE and Oberon speaker lines.
Pricing & Availability
The EPIKORE series is available from Authorized Dealers  in three exclusive premium finishes — High Gloss Black, High Gloss Walnut, and High Gloss Maroon.
Related Reading
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
