D-Link DIR-818LW AC750 Wi-Fi Router
D-Link DIR-818LW Red Router
D-Link just released a AC750 Wi-Fi Router (model DIR-818LW) available in red, teal, black, and white for $80. Featuring a sleek, cylinder shape, the routers deliver next generation 802.11ac wireless speeds and gigabit wired speeds. Designed to eliminate Wi-Fi interference for faster and more reliable Internet, the AC750 Wi-Fi Routers feature dual-band technology enabling users to perform simple Internet activities on the 2.4GHz band, and more demanding activities on the cleaner, interference-free 5GHz band. The routers are also backward compatible with 802.11a/b/g/n devices for seamless connectivity. Additionally, for fast wired connectivity, the AC750 Wi-Fi Routers are equipped with four Gigabit Ethernet ports.
Offering easy remote network management, the AC750 Wi-Fi Routers allow users to see what websites are being visited, block unwanted connections and set up automatic email alerts when unauthorized connections are made on any iPhone, iPad or Android device with the free mydlink Lite app. In addition, the routers feature a USB port that works with the free mydlink SharePort app, enabling users to stream and share photos, music and movie files directly to their mobile devices. The AC routers also support easy setup using a mobile phone or tablet with the free Quick Router Setup (QRS) app.
D-Link DIR-818LW Wi-Fi Router D-Link DIR-818LW Back Router
More about the AC750 Wi-Fi Routers
  • Next Generation AC750 Technology – increased speed, range and reliability ensure strong whole-home coverage
  • Fast Gigabit Ports – four 10/100/1000 Gigabit ports provide high-speed wired connectivity
  • Dual Band Performance – up to 433Mbps on the 5GHz band and 300Mbps on the 2.4GHz band for maximum throughput with less Wi-Fi interference
  • Backward Compatibility – works with existing Wi-Fi devices
  • mydlink Cloud Services – remotely monitor your network using your smartphone or tablet
  • SharePort – stream content from a connected USB drive to multiple mobile devices with a free mobile app
Availability and Pricing
The new line of D-Link AC750 Wi-Fi Routers (DIR-818LW) is now available in four colors (red, teal, black, and white) for $79.99 exclusively at Amazon.com through May 2014.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
