Cyrus Audio Announces New Classic Series
The Cyrus Audio Classic AMP and Classic PRE are the first products in their new and improved Classic Series product category.
Cyrus Audio Classic Pre and Amp Front Angle
Cyrus Audio is a high-end audio brand based in Cambridgeshire, England, and has been at the forefront of the audio scene for nearly 40 years.
Its first product, the Cyrus One (aka Cyrus 1) amplifier launched in 1984 to much acclaim. Since then Cyrus Audio has developed a reputation for offering quality audio products which include integrated amps, CD players, power amps, and power supplies, all of which are manufactured in England.
The new Cyrus Audio Classic Series offers popular product choices for many hi-fi fans, bringing the unique look and sound of Cyrus to a global audience.
Cyrus Audio has announced the launch of two new models to kickstart the new line of products in the new and improved Classic series.
Cyrus Audio Classic AMP Front
The front panel looks the same on both Classic AMP and PRE
The first two entries in the new Classic line are The Classic AMP, an integrated amplifier, and The Classic PRE, which is a preamplifier.
Both new products retain the Cyrus audio look, but the circuit design has been re-designed and the majority of the internal components have been upgraded by the Cyrus R&D team, resulting in sound improvements.
The Classic AMP
Cyrus Audio Classic AMP Rear
Channel Configuration: 2
Amplifier Type: Class A/B
Output Power (2 channels driven):
  • 4 Ohms – 112W
  • 6 Ohms – 91W
  • 8 Ohms – 91W
Frequency Response (-3dB): <0.5Hz to >50kHz
Signal-To-Noise Ratio (SNR): >100dB
Input Connections
  • Phono Input with Ground: 1 set (Moving Magnet)
  • Analog Audio: 4 sets
Tip: Digital Optical/Coaxial inputs are PCM only.
Output Connections
  • Preamp Output: 1 set
  • Fixed Audio Level Output: 1 set
  • Headphone Output: 1
  • Speakers: One left set, One right set.
  • MC Bus (Cyrus Wired Control System): 1 in/ 1 out:
Color Options: Black
Dimensions (WHD): 215 x 75 x 365mm (8.5 x 3 x 14.4-inches)
Price (UK only provided): £1,995
The Classic PRE
Cyrus Audio Classic Pre Rear
The Classic PRE has the same features, input, output, and control connections as the Classic AMP, but instead of a built-in amplifier and speaker outputs, there are both left and right RCA preamp and balanced audio outputs for connection to an external power amplifier which is needed to power speakers.
Resource: What is a Preamplifier?
Weight: 4.4Kg (9 lbs/11oz)
Price (UK only provided): £2,595
Availability
The Classic AMP & PRE are available to order from August. You can also book a demo session at Cyrus dealer if one is near you
Additional new Classic Series are expected to be revealed over the next 18 months, including a BluOS-enabled music streamer.
To find out more about Classic AMP, PRE, and other forthcoming products in the Classic series, visit www.cyrusaudio.com.
More Cyrus Audio
Cyrus Audio I7-XR Integrated Amplifier: Review
Cyrus Audio I7-XR & Wharfedale Linton Heritage: The Audiophile System Builder
Cyrus Audio Launches Six New XR Series Hi-Fi Products
Cyrus One HD Integrated Amplifier/DAC: Review
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
The Cyrus Audio 40 series hi-fi components includes matching Integrated Amplifier, Streamer, CD Player and Power Supply for $16,480.
There were very few affordable turntables at CAF 2023 and that was a huge mistake. Did any of the tables on display strike our...
Can this $5,495 turntable compete against in a very crowded market? Cyrus is hoping that its long-term success with phono pre-amplifiers is enough for...
The $700 JBL L10cs Subwoofer is designed to complement their Classic series and studio monitor loudspeakers for a full-range experience.
The PSU-XR power supply provides a sound upgrade for all Cyrus XR components.
The integrated amplifier market is evolving and that's a very good thing for audiophiles looking in 2022.
Which CD players and DAC made our Editors' Choice 2022 list?
Does the $3,799 Cyrus Audio i7-XR compete with the most popular options from Rega, Naim, and Cambridge Audio?
