Crystal Acoustics THX-3D12 HT System at CES South Hall 26115
Crystal Acoustics at CES ’06
South Hall 2 Booth 26115
New! THX-3D12 5.1 Speaker System
Truly Affordable THX Select Certified High End Speaker System
Just what is the THX-3D12 Speaker System with THX Select Certified Subwoofer?
• A truly affordable 5.1 THX Select Certified High End Speaker System
• 10″ and 12″ Active Powered THX Select Certified Subwoofers
• Adjustable sub crossovers optimize each speaker system’s performance
• THX Select Certified Subwoofer guarantees powerful bass for movies and music Incorporates ground-breaking technologies like our Top Mounted Spherical Free Air Rotating Tweeters and Electronic Protection
Why THX?
• THX specifications guarantee great sound anywhere in the room with every seat as good as the next
• THX recreate speaker arrays on movie theater walls
• Controlled dispersion frees you from narrow listening area of conventional speakers
• Optimizes a 500-seat movie theater as well as your favorite room at home
• THX Select Certified specifications guarantee great sound everywhere in your room
• THX Select Certified best for multichannel and stereo music too!
• Speaker placement easy using low-diffraction swiveling tweeters
• Aim tweeters at listening position for best sound
• Feel you’re in the middle of action films from your favorite couch
• Groove to your music from anywhere you listen
• Half the price of the competition and double the quality for the money
• Factory Direct is our secret to extreme high quality at incredibly low prices
Crystal Acoustics is a preeminent THX OEM speaker manufacturer known throughout Europe and Asia under the trade name Crystal Audiovideo Ltd. Their client list is impressive but not available to the public for obvious reasons. Speakers are manufactured to tight THX Select Certified specifications in their own factory in China guaranteeing a vivid THX music and movie theater experience right in your own home.
The right speakers, the right looks, the incredibly right prices, at just the right time! Visit us at www.crystalaudiovideo.com for more information!
Press Information Contact:
Jonathan Scull • Scull Communications • jscull@scullcommunications.com
212.807.0519 • www.scullcommunications.com
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
