Crystal Acoustics SmArt System at CES South Hall 26115
Crystal Acoustics at CES ’06
South Hall 2 Booth 26115
New! SmArt Speaker Systems
With THX Select Certified Subwoofers
Colorful Easy To Change High Gloss Side Panels
Adapts to Any Room Style
Crystal Acoustics’ new 5.1 SmArt Speaker System with THX Select Certified Subwoofer and Interchangeable Side Panels on all enclosures instantly changes the system’s looks with optional extra sets of side panels!
We Know You Live In Your Home
Not In Your Home Theater System!
Get Smart with Crystal Acoustics (Highly Intelligent) SmArt System!
• The first high performance speaker system with interchangeable side panels
• Handsome high gloss lacquer or attractive real wood veneers
• Choose from exciting colors like Ferrari Yellow and Piano Black with more coming soon
• Easy to place slim-line design easily integrates into any decor
• Glass Top Panel 10″ 120W THX-10SUBt also elegant and practical side table
• THX Select Certified Subwoofer guarantees powerful bass for movies and music
• Design meets THX specifications with accompanying THX Select Certified Subwoofer
• THX Select Certified specifications guarantee great sound everywhere in your room
• Feel in the middle of the action from your favorite couch
• Groove to your music from anywhere you listen
• Half the price of the competition and double the quality for the money
• Factory Direct is the secret to extreme high quality at incredibly low prices
Crystal Acoustics is a preeminent THX OEM speaker manufacturer known throughout Europe and Asia under the trade name Crystal Audiovideo Ltd. Their client list is impressive but not available to the public for obvious reasons. Speakers are manufactured to tight THX Select Certified specifications in their own factory in China guaranteeing a vivid THX music and movie theater experience right in your own home.
The right speakers, the right versatile looks, the incredibly right price, at just the right time! Visit us at www.crystalaudiovideo.com to learn more!
Press Information Contact:
Jonathan Scull • Scull Communications • jscull@scullcommunications.com
www.scullcommunications.com • 212.807.0519
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
