Crystal Acoustics Boomer Bluetooth Speaker
Crystal Acoustics introduced the Boomer, a portable Bluetooth wireless speaker and speakerphone with micro-SD card slot for playing MP3 music. At only 6 x 5cm and with a weight of just 220g, the Boomer is a lot of audio excellence in a very small package. It uses Surface Bass Boost technology to improve bass performance and a HVDL (High Volume Distortion Limiter) with internal processing that uses a special algorithm to eliminate distortion at higher volumes. As a result, for a wireless speaker of its size the company says Boomer can go seriously loud – without any compromise in quality.
With its own microphone and hands-free functions, the Boomer is also a fully functioning speakerphone. The product has an attractive luxurious satin metal enclosure, and top-mounted metal speaker grille — plus it’s small enough to carry with you.
Specifications
  • Drivers: 1x 45mm
  • SSB Drivers: 1x 45mm
  • Amplifier Watts: 5W
  • Inputs: Micro-SD (MP3 playback) and 3.5mm Input
  • Bluetooth Version: 2.1 EDR
  • Profiles: A2DP, AVRCP
  • Max Range: 10m
  • Max Batteries Operation Time: 8 hr
  • Battery Charging Time: 2.5 hr
  • Battery capacity: 520mAh
  • Dimensions: 60mm x 50mm
  • Weight: 0.22 kg
Price and Availability
The Crystal Acoustics Boomer is available now for €69.99.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
